楼主: yangmz1972
请教高手,如何实现类似天正的坐标标注的算法。
 楼主| 发表于 2023-3-10 09:14:17 | 显示全部楼层
d1742647821 发表于 2023-2-27 18:50
参考我的视频
https://www.bilibili.com/video/BV1uA411D7mY/?spm_id_from=333.337.search-card.all.click
你好,再请教一下,参考你的示例,改写成vb.net代码,其中对象修改事件改成如下,但老是出错,不知道代码错在哪里,请帮忙看一下:
      Private Sub m1ModiEvent(ByVal senderObj As Object, ByVal evtArgs As EventArgs)
            Dim acDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Dim acDocEd As Autodesk.AutoCAD.EditorInput.Editor = acDoc.Editor
            Dim mt As MText = CType(m1.MText.Clone(), MText)
            mt.Contents = GetBzStr(m1.GetFirstVertex(0))
            Using aclckdoc As DocumentLock = acDoc.LockDocument
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    m1.UpgradeOpen()
                    m1.MText = mt                             ‘运行到这里,没有用,不能实现修改Mleader的文本功能,这是怎么回事?
                    acTrans.Commit()
                End Using
            End Using
        End Sub
GMT+8, 2025-5-1 14:21 , Processed in 0.137656 second(s), 17 queries , Gzip On.
