查看: 1621|回复: 3
创建匿名块
发表于 2022-11-29 16:04:28 | 显示全部楼层 |阅读模式
Option Explicit
' 创建匿名块
Public Sub CreateAnonymousBlk()
    Dim ptBase(0 To 2) As Double
    ptBase(0) = 0: ptBase(1) = 0: ptBase(2) = 0
    ' 添加块定义
    Dim objBlkDef As AcadBlock
    Set objBlkDef = ThisDrawing.Blocks.Add(ptBase, "*U")
    ' 向块定义中添加图形对象
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
    pt1(0) = -10: pt1(1) = 0: pt1(2) = 0
    pt2(0) = 10: pt2(1) = 0: pt2(2) = 0
    objBlkDef.AddLine pt1, pt2
    pt1(0) = 0: pt1(1) = -10: pt1(2) = 0
    pt2(0) = 0: pt2(1) = 10: pt2(2) = 0
    objBlkDef.AddCircle ptBase, 6
End Sub
' 获得最后创建的匿名块
Public Function GetLastAnonymousBlk() As AcadBlock
    Dim n As Integer
    For Each objBlkDef In ThisDrawing.Blocks
        ' 匿名块以*为起始字符
        If Left(objBlkDef.Name, 1) = "*" Then
            ' 消除布局块的影响
            If objBlkDef.Name <> "*Model_Space" And Left(objBlkDef.Name, 12) <> "*Paper_Space" Then
                ' 返回名称编号最大的一个块
                If Mid(objBlkDef.Name, 3) >= n Then
                    n = Mid(objBlkDef.Name, 3)
                    Set GetLastAnonymousBlk = objBlkDef
                End If
            End If
        End If
    Next
    Set objBlkDef = Nothing
End Function
' 插入一个匿名块
Public Sub InsertAnonymousBlkRef()
    Dim ptInsert(0 To 2) As Double
    ptInsert(0) = 100: ptInsert(1) = 100: ptInsert(2) = 0
    Dim objBlk As AcadBlock
    ' 获得图形中最后一个创建的匿名块
    Set objBlk = GetLastAnonymousBlk
    ThisDrawing.ModelSpace.InsertBlock ptInsert, objBlk.Name, 1, 1, 1, 0
End Sub
' 获得图形中匿名块的数量和名称
Public Sub GetAnonymousBlkNumber()
    Dim n As Integer                    ' 匿名块的数量
        ' 匿名块以*为起始字符
            ' 消除布局块的影响
                n = n + 1
                Debug.Print objBlkDef.Name
            End If
        End If
    Next
    MsgBox "当前图形中匿名块的数量是: " & CStr(n)
End Sub
 楼主| 发表于 2022-11-29 19:54:45 | 显示全部楼层
需要的复制哈
发表于 2023-9-21 20:33:08 | 显示全部楼层
怎么在你的代码上面修改获取块的外框呢
GMT+8, 2025-4-30 23:22 , Processed in 0.201226 second(s), 23 queries , Gzip On.
