查看: 1690|回复: 4
关于图库系统的后续改写
发表于 2022-10-2 04:52:03 | 显示全部楼层 |阅读模式
请移步帖子:
http://bbs.mjtd.com/thread-186146-1-1.html
  • ;新建图块--------
  •   (defun c:sl-lib-blockadd (/ dcl_id dlg ss pt sl-blkpath ps p1 p2 ss1 ss2 ss3)
  •     (setq dcl_id (load_dialog (sl_lib_tkmm)))
  •     (new_dialog "tukuairen" dcl_id)
  •     (action_tile "edt_name" "(setq $sl_newname $value)")
  •     (set_tile "txt_name" (slmsg "新建图块" "新建圖塊" "New Block"))
  •     (set_tile "edt_name" (slmsg "新块名" "新塊名" "New Block Name"))
  •     (action_tile "accept" "(done_dialog 1)")
  •     (setq dlg (start_dialog))
  •     (if (= dlg 1)
  •       (progn
  •         (setq $sl_newname (vl-string-translate "|\\/?*:\"<>" "_________" $sl_newname))
  •         (setq sl-blkpath (strcat $sl_libpath (cdr $sl_libcurrent) "\\" $sl_newname))
  •         (prompt (slmsg "\n 选择图形:" "\n  選擇圖形:" "\n Select Graph:"))
  •         (setq ps (sl_pm2pt) p1 (car ps)  p2 (cadr ps))
  •         (setq ss1 (ssget "x"))
  •         (setq ss2 (ssget))
  •         (command "._Select" ss1 "_Remove" ss2 "")
  •         (setq ss3 (ssget "_p"))
  •         (sl:ycwt ss3) ;;隐藏其余部分
  •         (command "ZOOM" "E")
  •         (setq pt (caddr (sl_pm2pt)))
  •         (command "COPY" ss2 "" pt pt)
  •         (command "-wblock" (strcat sl-blkpath ".dwg") "" pt ss2 "")
  •         (command "._mslide" (strcat sl-blkpath ".sld"))
  •         (sl:xswt) ;;恢复隐藏
  •         (command "ZOOM" "W" p1 p2)
  •         (sl-lib-main1)
  • ;;替换当前,刷新幻灯---------------
  •   (defun sl-lib-slidereplace (/ ss pt)
  •     (slexit
  •       (slmsg
  •         "当前图,作其整图同名幻灯,存与其目录下!"
  •         "當前圖,作其整圖同名幻燈,存與其目錄下!"
  •         "The current image is a slide with the same name as the whole image and stored in its directory!"
  •       (slmsg
  •         "是否继续?请选择是否继续!"
  •         "是否繼續?請選擇是否繼續!"
  •         "Do you want to continue? Please select whether to continue!"
  •     (setq $sl_newname (cadr (assoc $sl_libindex $sl_blocklist)))
  •     (setq $sl_newname (strcat $sl_libpath (cdr $sl_libcurrent) "\\" $sl_newname))
  •     (vl-file-delete (strcat $sl_newname ".dwg"))  ;删除原有dwg文件
  •     (vl-file-delete (strcat $sl_newname ".sld"))  ;删除原有dwg文件
  •     (setq ss (ssget "x"))
  •     (command "COPY" ss "" pt pt)
  •     (command "-wblock" (strcat $sl_newname ".dwg") "" pt ss "")
  •     (command "._mslide" (strcat $sl_newname ".sld"))
  •     (sl-lib-main1)
  •   ;;选择替换----------------------
  •   (defun sl-lib-blockreplace (/ ss1 ss2 ss3 pt ps p1 p2)
  •     (command "-wblock" (strcat $sl_newname ".dwg") "" pt ss2 "")
  •     (sl:xswt) ;;恢复隐藏
  •     (sl-lib-main1)
链接:https://pan.baidu.com/s/1UCJtFdLy2DlFcLesMeYyqg
提取码:gy87
发表于 2022-10-4 13:56:09 | 显示全部楼层
建议大佬整个独立运行的
发表于 2022-10-5 16:46:58 | 显示全部楼层
建议大佬整个独立运行的
发表于 2022-10-8 22:03:52 | 显示全部楼层
你能帮忙出一个单独图库完整的程序吗?你这个看起来非常好用
发表于 2022-10-14 10:43:42 | 显示全部楼层
这个要钱的,是在推销啊。
GMT+8, 2025-5-24 21:58 , Processed in 0.253728 second(s), 23 queries , Gzip On.
