楼主: 1028695446
【面域】面域转多段线 region to PLINE
发表于 2022-11-27 12:07:15 | 显示全部楼层
(defun c:TT (/ *error*         arcbugle         acdoc         space
                 ss         n         reg         norm         expl         olst
                 blst         dlst         plst         tlst         blg         pline
  (vl-load-com)
  (defun *error* (msg)
    (if        (/= msg "Function cancelled")
      (princ (strcat "\nError: " msg))
    (vla-EndUndoMark
      (vla-get-ActiveDocument (vlax-get-acad-object))
  (setq        acdoc        (vla-get-ActiveDocument (vlax-get-acad-object))
        space        (if (= 1 (getvar "CVPORT"))
                  (vla-get-PaperSpace acdoc)
                  (vla-get-ModelSpace acdoc)
  (if (ssget '((0 . "REGION")))
      (vla-StartUndoMark acdoc)
      (vlax-for reg (setq ss (vla-get-ActiveSelectionSet acdoc))
        (setq norm (vlax-get reg 'Normal)
              expl (vlax-invoke reg 'Explode)
        (if (vl-every '(lambda (x)
                         (or
                           (= (vla-get-ObjectName x) "AcDbLine")
                           (= (vla-get-ObjectName x) "AcDbArc")
                      expl
            (vla-delete reg)
            (setq olst (mapcar '(lambda        (x)
                                  (list        x
                                        (vlax-get x 'StartPoint)
                                        (vlax-get x 'EndPoint)
                               expl
            (while olst
              (setq blst nil)
              (if (= (vla-get-ObjectName (caar olst)) "AcDbArc")
                (setq blst (list (cons 0 (arcbulge (caar olst)))))
              (setq plst (cdar olst)
                    dlst (list (caar olst))
                    olst (cdr olst)
              (while
                (setq
                  tlst
                   (vl-member-if
                     '(lambda (x)
                        (or (equal (last plst) (cadr x) 1e-9)
                            (equal (last plst) (caddr x) 1e-9)
                     olst
                 (if (equal (last plst) (caddar tlst) 1e-9)
                   (setq blg -1)
                   (setq blg 1)
                 (if
                   (= (vla-get-ObjectName (caar tlst)) "AcDbArc")
                    (setq
                      blst
                       (cons (cons (1- (length plst))
                                   (* blg (arcbulge (caar tlst)))
                             blst
                 (setq plst (append plst
                                    (if        (minusp blg)
                                      (list (cadar tlst))
                                      (list (caddar tlst))
                       dlst (cons (caar tlst) dlst)
                       olst (vl-remove (car tlst) olst)
              (setq pline
                     (vlax-invoke
                       Space
                       'addLightWeightPolyline
                       (apply 'append
                                         (setq x (trans x 0 Norm))
                                         (list (car x) (cadr x))
                                      (reverse (cdr (reverse plst)))
              (vla-put-Closed pline :vlax-true)
              (mapcar
                '(lambda (x) (vla-setBulge pline (car x) (cdr x)))
                blst
              (vla-put-Elevation
                pline
                (caddr (trans (car plst) 0 Norm))
              (vla-put-Normal pline (vlax-3d-point Norm))
              (mapcar 'vla-delete dlst)
          (mapcar 'vla-delete expl)
      (vla-delete ss)
      (vla-EndUndoMark acdoc)
发表于 2023-8-9 10:48:31 | 显示全部楼层
6666666666666
发表于 2023-8-9 14:14:06 | 显示全部楼层
不错,来学习一下
发表于 2025-9-8 14:31:30 | 显示全部楼层
学习下楼主的好方法
GMT+8, 2025-12-7 10:54 , Processed in 0.153959 second(s), 17 queries , Gzip On.
