查看: 3353|回复: 8
图库缩略图
发表于 2022-9-7 15:07:26 | 显示全部楼层 |阅读模式
请教大神指点缩略图文图,图库卡在缩略图上了
发表于 2022-9-7 16:44:01 | 显示全部楼层
码发上来,不然人家怎么帮你?
发表于 2022-9-7 21:51:07 | 显示全部楼层
发表于 2022-9-8 07:42:00 | 显示全部楼层
  1. (defun C:tt2 (/ dcl-image dialog do1 setdata  DCLID FILELST FNAME I IMGTXT KEY RETURN#)
  2.   (defun dcl-image (key x y file)
  3.     (start_image key)
  4.     (setq max_x        (dimx_tile key)
  5.           max_y        (dimy_tile key)
  6.     )
  7.     (slide_image
  8.       x
  9.       y
  10.       (- max_x x)
  11.       (- max_y y)
  12.       file
  13.     )
  14.     (end_image)
  15.   )
  16.
  17.   (defun dialog        (/ FN I II)
  18.     (setq i -1)
  19.     (setq fname (vl-filename-mktemp nil nil ".dcl"))
  20.     (setq fn (open fname "w"))
  21.     (write-line
  22.       "tempDlg_1:dialog{label=\"PAi_Symbols图块\";spacer_1;"
  23.       fn
  24.     )
  25.     (repeat 4
  26.       (write-line " :row{" fn)
  27.       (setq ii i)
  28.       (repeat 8
  29.         (setq ii (1+ ii))
  30.         (write-line (strcat " :image_button{color=-2; width=16; aspect_ratio=0.66; key=\"Imgkey" (itoa ii) "\";allow_accept = true;}") fn)
  31.       )
  32.       (write-line " }" fn)
  33.       (write-line " :row{" fn)
  34.       (repeat 8
  35.         (setq i (1+ i))
  36.         (write-line (strcat " :text{label=\"Text\";  key=\"Txtkey" (itoa i) "\";allow_accept = true;}") fn)
  37.       )
  38.       (write-line " }" fn)
  39.     )
  40.     (write-line " :row{ok_cancel_help;}" fn)
  41.     (write-line " }" fn)
  42.     (close fn)
  43.     ;;(startapp "notepad" fname)
  44.   )
  45.   ;;fileLst库文件列表
  46.   (defun setdata ()
  47.     (setq i -1)
  48.     (mapcar (function
  49.               (lambda (x y)
  50.                 (setq i (1+ i))
  51.                 (set_tile (strcat "Txtkey" (itoa i)) x)
  52.                 (dcl-image (strcat "Imgkey" (itoa i)) 0 0 y)
  53.               )
  54.             )
  55.             ImgTxt
  56.             fileLst
  57.     )
  58.   )
  59.
  60.   ;;在这里,用根据key做不同的事情
  61.   (defun do1 ()
  62.     (cond ((equal key "Imgkey1") (alert key))
  63.           ((equal key "Imgkey2") (alert key))
  64.           ((equal key "Imgkey3") (alert key))
  65.           ((equal key "Imgkey4") (alert key))
  66.     )
  67.   )
  68.   (setq        ImgTxt
  69.          '("指北针"        "入户标志"   "区域名称"          "区域编号"
  70.            "区域指示"        "材料索引"   "物料索引"          "立面索引"
  71.            "剖面索引"        "剖面索引[V]"                  "剖面索引[H]"
  72.            "详图索引"        "铺贴起始"   "铺贴倾斜"          "特殊符号"
  73.            "总图标高"        "平面标高"   "立面标高"          "详图标高"
  74.            "引注标高"        ""             ""                  ""
  75.            ""                ""             ""                  ""
  76.            ""                ""             ""                  ""
  77.            ""
  78.           )
  79.   )
  80.   (setq        fileLst        (list "steelsec(1001eas)"
  81.                       "steelsec(1002uas)"
  82.                       "steelsec(1003gbgzgs)"
  83.                       "steelsec(1004ybgzgs)"
  84.                       "steelsec(1005gbchans)"
  85.                       "steelsec(1006ybchans)"
  86.                       "steelsec(1007chs)"
  87.                       "steelsec(1008shs)"              ""
  88.                       ""              ""              ""
  89.                       ""              ""              ""
  90.                       ""              ""              ""
  91.                       ""              ""              ""
  92.                       ""              ""              ""
  93.                       ""              ""              ""
  94.                       ""              ""              ""
  95.                       ""              ""
  96.                      )
  97.   )
  98.
  99.   (dialog)
  100.
  101.   (setq dclid (load_dialog fname))
  102.   (new_dialog "tempDlg_1" dclid)
  103.   (setdata)
  104.   (mapcar (function
  105.             (lambda (x)
  106.               (action_tile (strcat "Imgkey" (itoa x)) "(setq key $key)")
  107.             )
  108.           )
  109.           (list 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31)
  110.   )
  111.   (action_tile (strcat "Imgkey" (itoa 0)) "(setq key $key)")
  112.   (action_tile "accept" "(done_dialog 1)")
  113.   (setq return# (start_dialog))
  114.   (unload_dialog dclid)
  115.
  116.   (vl-file-delete fname)
  117.   (if (equal return# 1)
  118.     (do1)
  119.   )
  120.   (princ)
  121. )
发表于 2022-9-8 09:08:35 来自手机 | 显示全部楼层
这个好,谢谢分享!
 楼主| 发表于 2022-9-9 20:37:26 | 显示全部楼层
发错了地方。没用处。显示简化程序  发表于 2022-9-11 07:35
发表于 2022-10-12 18:06:32 | 显示全部楼层
使用这个Slide控件
发表于 2024-1-16 22:14:32 | 显示全部楼层
utopio 发表于 2022-10-12 18:06
使用这个Slide控件
大哥 这个咋用》
GMT+8, 2025-5-1 03:03 , Processed in 0.158635 second(s), 24 queries , Gzip On.
