查看: 3009|回复: 12
发布三领设计V2.0 所集成图库源码
发表于 2022-8-30 14:58:55 | 显示全部楼层 |阅读模式
图库系统初始源码,缘自【 7月信】的程序
在集成使用过程之中,不断改写与完善
头几天看到有人问,双击插入这个问题,三领早已集成做到了,发布下,看着改下即可。
以下是三领设计的,链接安装
链接:https://pan.baidu.com/s/1ZsNPjEZSn3BJ5Hjv7NM9iA
提取码:0u9q
  • ;;插入图块-------------------------
  •   (defun sl-lib-blockinsert (/ pt)
  •     (command "ZOOM" "0.5X")
  •     (setq pt (caddr (sl_pm2pt)))
  •     (vla-ins-b (cadddr (assoc $sl_libindex $sl_blocklist)) pt $sl_libscalex $sl_libscaley $sl_libscalez $sl_librotate)
  •     (command "MOVE" (entlast) "" pt PAUSE)
  •     (vla-explode (en2obj (entlast)))
  •     (princ)
    • ;;求屏幕(左下角 右上角 中点)-------(一级)------------
    • (defun sl_pm2pt (/ a b c d x)
    •   (setq b (getvar "viewsize")
    •     c (car (getvar "screensize"))
    •     d (cadr (getvar "screensize"))
    •     a (* b (/ c d))
    •     x (trans (getvar "viewctr") 1 2)
    •     c (trans (list (- (car x) (* a 0.5)) (- (cadr x) (* b 0.5)) 0.0) 2 1)
    •     d (trans (list (+ (car x) (* a 0.5)) (+ (cadr x) (* b 0.5)) 0.0) 2 1)
    •     e (sl:mid c d)
    •   (list c d e)   ;;c 左下  d 右上 e 中心
  • ;;插入图块--------(一级)--------------
  • ;;(vls-ins-b "\\ XYZ\\kuai" '(0 0 0) 1 1 1 0)
  • (defun vla-ins-b (bname pt xscale yscale zscale rot / mspace)
  •   (vl-load-com)
  •   (if (= (getvar "ctab") "Model")
  •     (setq mspace *Model-Space*)
  •     (setq mspace *Paper-Space*)
  •   (setq theblock (vla-InsertBlock mspace (vlax-3d-point pt) bname xscale yscale zscale rot))
  •   (princ)
  • ;;常量定义
  • (setq *Acad* (vlax-get-acad-object)
  •   *AcDocument* (vla-get-activedocument *Acad*)  ; 获取当前图档指针
  •   *Model-Space* (vla-get-modelspace *AcDocument*)
  •   *Paper-Space* (vla-get-PaperSpace *AcDocument*)
  •   *BLKS* (vla-get-Blocks *AcDocument*)
  •   *LAYS* (vla-get-Layers *AcDocument*)
  •   *ACLYS*  (vla-get-activeLayer *AcDocument*)
  •   *LTS*  (vla-get-Linetypes *AcDocument*)
  •   pi2     (* pi 0.5)
  •   pi4     (* pi 0.25)
  •   3pi4   (* 0.75 pi)
  •   2pi     (+ pi pi)
  •   3pi2   (+ 3pi4 3pi4)  ;; (* 1.5 pi)
  •   5pi4   (+ pi pi4)  ;;(* 1.25 pi)
  •   7pi4   (+ 3pi2 pi4) ;;(* 1.75 pi)
  •   $okbt ":button {label = \"确定\"; key = \"accept\"; fixed_width = true;width = 8;alignment = centered;is_default = true;}"
  •   $canbt ":button {label = \"取消\"; key = \"cancel\"; fixed_width = true;width = 8;alignment = centered;is_cancel = true;}"
发表于 2022-8-30 17:58:50 | 显示全部楼层
Dear Sir,
Thanks For Sharing Source Code ..
Some Errors  are comes
  1. (LOAD "C:/Users/SachinK/Downloads/Compressed/sltk.lsp") syntax error
复制代码
i remove this portion of code.  after remove this part code working fine.,
  1. (defun sltkgy ()
  2.
  3. )
below function is missing
  1. Command: SLTK
  2. no function definition: SLPATHno function definition: SLPATH
复制代码
 楼主| 发表于 2022-8-30 17:41:45 | 显示全部楼层
czb203 发表于 2022-8-30 16:25
三领大神什么时候分享你的代码,让我们小辈学习下~
我一直在点滴分享,主要是我没法全部一一提出来,嵌套一层层的,我可不是保守敢说原因。三领的主程序,目前只有502K,要不集成的极其紧凑,无有多余、重复代码存在,大量的函数方式。
 楼主| 发表于 2022-8-30 19:32:16 | 显示全部楼层
sachindkini 发表于 2022-8-30 17:58
Dear Sir,
是的,这个如果独立运行,是不行的,需要三领支持,丢失的函数,仅仅的个帮助罢了,里面就是显示的帮助信息。
发表于 2022-8-30 15:45:44 | 显示全部楼层
请教您这些图片
是幻灯还是图块?
如图块就方便了
幻灯还是麻烦的
谢谢
发表于 2022-8-30 16:25:16 | 显示全部楼层
发表于 2022-8-30 16:35:58 | 显示全部楼层
三领大佬咋退群了哇~
 楼主| 发表于 2022-8-30 17:39:29 | 显示全部楼层
ynhh 发表于 2022-8-30 15:45
请教您这些图片
是幻灯还是图块?
如图块就方便了
既有幻灯,也有图块啊,幻灯是界面显示,操作是DWG文件。
 楼主| 发表于 2022-8-30 17:40:31 | 显示全部楼层
magicheno 发表于 2022-8-30 16:35
三领大佬咋退群了哇~
没任何原因,因为我喝酒的原因,喝酒控制不住自己,不想麻烦打扰各位同仁。
发表于 2022-8-30 20:18:57 | 显示全部楼层
尘缘一生 发表于 2022-8-30 19:32
是的,这个如果独立运行,是不行的,需要三领支持,丢失的函数,仅仅的个帮助罢了,里面就是显示的帮助信 ...
dear sir,
ok .. thanks
GMT+8, 2025-5-24 22:07 , Processed in 0.186977 second(s), 25 queries , Gzip On.
