查看: 1505|回复: 1
加边框代码,怎么增加默认边框距离呢?
发表于 2022-7-31 18:05:06 | 显示全部楼层 |阅读模式
在下面连接这个贴子找到一个加边框的代码,需要手动输入边框距离,怎么增加默认边框距离呢?
http://bbs.mjtd.com/forum.php?mo ... DF%BF%F2&page=1
  • ;;加边框
  • (defun c:ttt ()
  • (setvar "CMDECHO" 0)
  • (vl-load-com)
  • (setq bx (getdist "\nEnter Around Space 输入四周间隔: "))
  • (while (progn (princ "\n选择加框物体: ") (setq ss (ssget)))
  •   (setq i -1 plst (list))
  •   (repeat (sslength ss)
  •    (setq en (ssname ss (setq i (1+ i))))
  •    (vla-getboundingbox(vlax-ename->vla-object en) 'p1 'p2)
  •    (setq plst (append plst (list(vlax-safearray->list p1)(vlax-safearray->list p2))))
  •   (setq p1 (apply 'mapcar (cons 'min plst)))
  •   (setq p2 (apply 'mapcar (cons 'max plst)))
  •   (setq p1 (mapcar '- p1 (list bx bx)))
  •   (setq p2 (mapcar '+ p2 (list bx bx)))
  •   (command "_.RECTANG" p1 p2)
  • (setvar "CMDECHO" 1)
  • (prin1)
发表于 2022-9-28 09:16:34 | 显示全部楼层
日常灌水,到此一看,期待大佬解决
GMT+8, 2025-5-1 02:53 , Processed in 0.187150 second(s), 23 queries , Gzip On.
