查看: 1733|回复: 4
迈总面板问题(求帮修改)
发表于 2022-7-18 00:16:31 | 显示全部楼层 |阅读模式
2明经币
原帖地址:
简单的自定面板函数 - AutoLISP/Visual LISP 编程技术 - AutoCAD论坛 - 明经CAD社区 - Powered by Discuz! (mjtd.com)
启动面板 点击使用一个命令后,点击空格启动的是面板,请问能否修改成 空格重复上次的命令不启动面板。
请大神帮忙修改一下 谢谢!
  • (defun c:Da ()
  •   (mai_make_panel
  •     (list
  •       (list "测试"
  •         (list "测试A1" "DaMo_GD_ZNSX")
  •         (list "测试A2" "DaMo_GD_PMFH")
  •         (list "测试A3" "DaMo_GD_JYST")
  •       (list ""
  •         (list "测试B1" "DaMo_GD_DTBL")
  •         (list "测试B2" "DaMo_GD_ZHDQ")
  •         (list "测试B3" "DaMo_GD_DQXZ")
  •       (list ""
  •         (list "测试C1" "DaMo_GD_GYZJ")
  •         (list "测试C2" "DaMo_GD_DXFX")
  •         (list "测试C3" "DaMo_GD_PLDQ")
  •   (princ)
  • (defun mai_make_panel (menulist / m n nn nnn menuname val_lst tt order_lst)
  •   (defun add_dclrow (dstr) (if dstr (setq val_lst (cons dstr val_lst))    )  )
  •   (add_dclrow "curbutton : button{width=10;vertical_margin=none;vertical_margin=none;}")
  •   (add_dclrow "curpanel : dialog{label=\"迷你自定义面板\";alignment=centered;vertical_margin=none;horizontal_margin=none;"  )
  •   (add_dclrow ":row{")
  •   (setq  len    (apply 'max (mapcar 'length menulist))
  •     order_lst (apply 'append (mapcar 'cdr menulist))
  •     n    0
  •     m    0
  •   (foreach nn menulist
  •     (add_dclrow (strcat " : boxed_column{label=\"" (car nn) "\";vertical_margin=none; horizontal_margin=none;")    )
  •     (foreach nnn (cdr nn)
  •       (setq n  (1+ n)
  •         tt (car nnn)
  •         tt (if tt
  •              tt
  •       (add_dclrow (strcat " : curbutton{key=\"but" (vl-princ-to-string n) "\";label=\"" tt "\";}"))  )
  •     (repeat (- len (length nn))
  •       (setq m (1+ m))
  •       (add_dclrow (strcat " : curbutton{key=\"butno" (vl-princ-to-string m) "\";}")) )
  •     (add_dclrow "}")
  •   (add_dclrow "}:button{label=\"退出\";key=\"cancel\";is_cancel=true;width=20;height=2.5;fixed_width=true;alignment=centered;}}"  )
  •   (setq menuname (vl-filename-mktemp "temp_pannel.dcl"))
  •   (setq nn (open menuname "w"))
  •   (foreach n (reverse val_lst) (write-line n nn))
  •   (close nn)
  •   (setq nnn (load_dialog menuname))
  •   (vl-file-delete menuname)
  •   (if (not (new_dialog "curpanel" nnn))
  •     (exit)
  •   (setq n 0)
  •   (repeat m (mode_tile (strcat "butno" (vl-princ-to-string m)) 1) (setq m (1- m)))
  •       (setq n  (1+ n)
  •         tt (car nnn)
  •         tt (if tt
  •              tt
  •       (if (= tt "")
  •         (mode_tile (strcat "but" (vl-princ-to-string n)) 1)
  •         (action_tile
  •           (strcat "but" (vl-princ-to-string n))
  •           (strcat "(done_dialog " (vl-princ-to-string n) ")")
  •   (setq nn (start_dialog))
  •   (unload_dialog nnn)
  •   (if (> nn 0)
  •     (progn (setq tt (cadr (nth (1- nn) order_lst)))
  •       (if (= (eval (read (strcat "(type c:" tt ")"))) 'SUBR)
  •         (progn (princ "\n")
  •           (eval (read (strcat "(c:" tt ")")))
  •         (progn
  •           (princ "\n")
  •           (vla-SendCommand (vla-get-ActiveDocument(vlax-get-acad-object)) (strcat tt "\n"))
  • (princ)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2022-7-22 08:02:06 | 显示全部楼层
记得论坛有人求救过,是定义一个按键重复上一次命令。自己搜下
  •               (eval(read (strcat "(defun c:q()(Vlax-Invoke-Method (Vlax-Get (Vlax-Get-Acad-Object)
  • 'ActiveDocument) 'SendCommand (strcat \"" tt "\" \" \"))(princ)))")));自定义q为重复上次命令
 楼主| 发表于 2022-7-22 09:42:42 | 显示全部楼层
  •        (progn (setq tt (cadr (nth ( ...
  • 谢谢你的回复!!!
    发表于 2024-7-16 21:37:09 | 显示全部楼层
    谢谢分享,.
    发表于 2024-7-18 10:53:36 | 显示全部楼层
    我从论坛里下载迈总面板就是已改好的。 空格直接重复上次命令
    GMT+8, 2025-5-1 12:36 , Processed in 0.205670 second(s), 21 queries , Gzip On.
