查看: 1936|回复: 11
大家看看这个超级炸块的乱码是什么意思,能不能翻译正确
发表于 2022-6-24 00:26:18 | 显示全部楼层 |阅读模式
;;; Copyright (C) Patrick_35
;;; 超级嵌套块炸开
(defun c:xxx(/ doc n s sel tot *errexp* decomposer)
  (defun *errexp* (msg)
    (or (member (strcase msg) '("FUNCTION CANCELLED" ""QUIT / EXIT ABORT"" "FONCTION ANNULEE" "QUITTER / SORTIR ABANDON"))
      (princ (strcat "\nErreur : " msg))
    (vla-endundomark doc)
    (setq *error* s)
  (defun decomposer(ent / ele new)
    (and (vlax-method-applicable-p ent 'explode)
         (not (vl-catch-all-error-p (setq new (vl-catch-all-apply 'vla-explode (list ent)))))
      (setq tot (1+ tot))
      (mapcar 'decomposer (vlax-safearray->list (vlax-variant-value new)))
      (vla-delete ent)
  (vl-load-com)
  (setq s *error*
        *error* *errexp*
        doc (vla-get-activedocument (vlax-get-acad-object))
        tot 0
  (vla-startundomark doc)
  (and (ssget)
      (vlax-map-collection (setq sel (vla-get-activeselectionset doc)) 'decomposer)
      (vla-delete sel)
  (setq *error* s)
  (princ (strcat "\n" (itoa tot) " objet(s) d閏ompos?s)"))
(setq nom_lisp "xxx")
(if (/= app nil)
  (if (= (strcase (substr app (1+ (- (strlen app) (strlen nom_lisp))) (strlen nom_lisp))) nom_lisp)
    (princ (strcat "..." nom_lisp " charg?"))
    (princ (strcat "\n" nom_lisp ".LSP Charg?....Tapez " nom_lisp " pour l'閤ecuter.")))
  (princ (strcat "\n" nom_lisp ".LSP Charg?.....Tapez " nom_lisp " pour l'閤ecuter.")))
(setq nom_lisp nil)
发表于 2022-6-28 23:34:02 | 显示全部楼层
;;; 超级嵌套块炸开
ABANDON"))
    (setq *error* s)
      (setq tot (1+ tot))
      (vla-delete ent)
  (vl-load-com)
  (setq s *error*
        *error* *errexp*
        tot 0
  (and (ssget)
      (vla-delete sel)
  (setq *error* s)
  (princ (strcat "\n" (itoa tot) " 个(炸开)"))
试了下数量对不上,可能是其他意思
发表于 2022-6-24 10:45:43 | 显示全部楼层
;;; 超级嵌套块炸开
    (setq *error* s)
      (setq tot (1+ tot))
      (vla-delete ent)
  (vl-load-com)
  (setq s *error*
        *error* *errexp*
        tot 0
  (and (ssget)
      (vla-delete sel)
  (setq *error* s)
 楼主| 发表于 2022-6-24 14:11:47 | 显示全部楼层
追寻 发表于 2022-6-24 13:51
你把原LSP发出来,可以帮你翻译乱码部分,已经粘贴到网页上的翻译不了,字形已经改变了
在楼下,帮忙看看,这个具体是起到了哪些作用,然后乱码删减一下,精简一下,因为使用完插件,命令行中会有乱码
 楼主| 发表于 2022-6-24 00:27:23 | 显示全部楼层
大概翻译一下,这个插件是干嘛用的,有什么特别的
发表于 2022-6-24 07:50:48 | 显示全部楼层
乱码的部分删掉就行  没什么用
 楼主| 发表于 2022-6-24 10:41:23 | 显示全部楼层
xj6019 发表于 2022-6-24 07:50
乱码的部分删掉就行  没什么用
我也不敢乱删。。。能帮忙删一下吗,精简一下
发表于 2022-6-24 13:51:57 | 显示全部楼层
 楼主| 发表于 2022-6-24 14:10:39 | 显示全部楼层
麻烦帮忙看看,
 楼主| 发表于 2022-6-29 03:34:00 | 显示全部楼层
;;; 超级嵌套块炸开
其实我发现,这个插件,不光是把块炸开了,还把图形给分解了。
GMT+8, 2025-5-1 21:04 , Processed in 0.299815 second(s), 26 queries , Gzip On.
