查看: 1348|回复: 1
[图元] 【field相关】操作字段对话框,AcFdUiInvokeFieldDialog
发表于 2022-6-9 15:17:49 | 显示全部楼层 |阅读模式
  1. using System;
  2. using System.Runtime.InteropServices;
  3. using Autodesk.AutoCAD.Runtime;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.DatabaseServices;
  6. using Autodesk.AutoCAD.Geometry;
  7. using Autodesk.AutoCAD.EditorInput;
  8. [assembly: CommandClass(typeof(FieldDialog.Utils))]
  9. namespace FieldDialog
  10. {
  11.   public class Utils
  12.   {
  13.     [DllImport("AcFdUi.arx", CallingConvention = CallingConvention.StdCall, EntryPoint = "AcFdUiInvokeFieldDialog")]
  14.     private static extern Int32 InvokeFieldDialog(ref IntPtr fd, Int32 bEdit, IntPtr pDb, IntPtr pParent);
  15.     [CommandMethod("InsField", CommandFlags.Modal)]
  16.     public void InsField()
  17.     {
  18.       Document doc = Application.DocumentManager.MdiActiveDocument;
  19.       if (doc == null) return;
  20.       Database db = doc.Database;
  21.       Editor ed = doc.Editor;
  22.       PromptPointResult ppr =
  23.         ed.GetPoint("\nУкажите точку вставки мультитекста: ");
  24.       if (ppr.Status != PromptStatus.OK) return;
  25.       using (Field fd = new Field())
  26.       {
  27.         IntPtr ptr = fd.UnmanagedObject;
  28.         InvokeFieldDialog(ref ptr, 1, db.UnmanagedObject, IntPtr.Zero);
  29.         using (BlockTableRecord curSpace =
  30.           db.CurrentSpaceId.Open(OpenMode.ForWrite) as BlockTableRecord)
  31.         {
  32.           using (MText mt = new MText())
  33.           {
  34.             mt.Location = ppr.Value;
  35.             curSpace.AppendEntity(mt);
  36.             mt.SetField("TEXT", fd);
  37.             fd.Evaluate((int)FieldEvaluationContext.Demand, db);
  38.           }
  39.         }
  40.       }
  41.     }
  42.   }
  43. }
 楼主| 发表于 2022-6-9 15:22:34 | 显示全部楼层
  1. void addFieldWithDialog()
  2. {
  3.     AcGePoint3d pnt1;
  4.      // pick start point
  5.     if(acedGetPoint(NULL, L"\nPick Insertion point ",
  6.                                         asDblArray(pnt1)) != RTNORM)
  7.     {
  8.         return;
  9.     }
  10.     AcDbDatabase *pDb =
  11.       acdbHostApplicationServices()->workingDatabase();
  12.     AcDbField *pField = NULL;
  13.     Acad::ErrorStatus es;
  14.     //show the dialog box..
  15.     if(AcFdUiInvokeFieldDialog(pField, FALSE, pDb) == IDOK)
  16.     {
  17.         //open the model space for write
  18.         AcDbObjectId modelId;
  19.         modelId = acdbSymUtil()->blockModelSpaceId(pDb);
  20.         AcDbBlockTableRecord *pBlockTableRecord;
  21.         es = acdbOpenAcDbObject((AcDbObject*&)pBlockTableRecord,
  22.                                         modelId, AcDb::kForWrite);
  23.         //add a Mtext;
  24.         AcDbMText *pMText = new AcDbMText();
  25.         pMText->setLocation(pnt1);
  26.         // Add to Db
  27.         AcDbObjectId objectId;
  28.         pBlockTableRecord->appendAcDbEntity(objectId, pMText);
  29.         AcDbObjectId fieldId;
  30.         //add a field
  31.         es = pMText->setField(_T("TEXT"), pField, fieldId);
  32.         es = pField->evaluate(AcDbField::kDemand, pDb);
  33.         pField->close();
  34.         pMText->close();
  35.         pBlockTableRecord->close();
  36.     }
  37. }
复制代码
这个是arx版的
GMT+8, 2025-5-1 08:51 , Processed in 0.164314 second(s), 23 queries , Gzip On.
