查看: 19749|回复: 96
[源码] 一键合并DCL和LSP文件
发表于 2022-6-6 14:44:36 | 显示全部楼层 |阅读模式
一键合并DCL和LSP文件(已改进,可以支持lsp文件中带注释)
;;先单独写dcl和lsp,调试好后一键合并。
;; by baitang36   (QQ 5520971)    2022-06-06
;;部分代码参考 lee50310  DCL2LSP  在此表示感谢!
;;命令:BDL
;;要求:只能有一个dcl文件,并且主文件名和lsp文件名相同。例如:只能把abcd.dcl与abcd.lsp合并
(defun C:BDL (/ dclFName dcl lspFName lsp str n j k m str1 str2 str5 start1 lstr1 yh)
  ;; 获取 DCL 文件的名称
(setq dclFName (findfile (getfiled "选择 DCL与LSP合并" "" "dcl"  16)))
  (setq        lspFName
         (strcat (substr dclFName 1 (- (strlen dclFName) 4)) ".lsp")
  (setq        newFName (strcat (substr dclFName 1 (- (strlen dclFName) 4))
                         "_new.lsp"
  (setq        dcl (open dclFName "r")                ;打开 DCL 进行读取
        lsp (open newFName "w")                ;打开 LSP 进行写入
  (setq f0 (open lspFName "r"))
  (setq str1 "")
(while (setq nstr5 (read-char f0))
    (setq str5 (chr nstr5))
    (setq str1 (strcat str1 str5))
  (close f0)
  (setq lstr1 (strlen str1))
  (setq start1 1)
  (setq        j 1
        k 0
        m 0
        n 0
  ) ;_ setq
  (setq str2 "")
  (while (< j lstr1)
    (if
      (OR
        (eq (substr str1 j 13) "(load_dialog ")
        (eq (substr str1 j 13) "(LOAD_DIALOG ")
      ) ;_ OR
         (setq m j)
         (setq str2 (strcat str2 (substr str1 start1 (- m start1))))
         (setq j (+ j 1))
         (setq k 1)
         (setq yh 0)
         (while        (/= 0 k)
           (if (eq "\"" (substr str1 j 1))
             (setq yh (boole 6 yh 1))
           (if (eq "(" (substr str1 j 1))
             (if (= yh 0)
               (setq k (1+ k))
           ) ;_ if
           (if (eq ")" (substr str1 j 1))
             (if (= yh 0)
               (setq k (- k 1))
           ) ;_ if
           (setq j (+ j 1))
         ) ;_ while
         (setq n j)
         (setq str3 (substr str1 m (- n m))) ;IF
         (setq str4 "(load_dialog tmp-dcl-file-name)")
         (setq str2 (strcat str2 str4))
         (setq start1 n)
    (setq j (+ j 1))
  (setq str2 (strcat str2 (substr str1 start1 (+ (- lstr1 start1) 1))))
  ;; Start LSP
  (setq        str
         (strcat
           ";<<<<<<合并DCL和lsp文件  baitang36 20220606 >>>>>> \n\n"
           "   (setq dcl_file (open (setq tmp-dcl-file-name (vl-filename-mktemp nil nil  \".DCL\")) \"w\"))\n"
           "              (progn\n" "                 (foreach x \n"
           "                   '(  \n") ;_ end of strcat
  ) ;_ end of setq
  (write-line str lsp)
  ;;读取 DCL 中的每一行并写入 LSP
  (while (setq str (read-line dcl))
    ;; 用反斜杠作为所有反斜杠的前缀
    (setq n 1)
    (while (<= n (strlen str))
      (if (= (substr str n 1) "\\")
          (if (= n 1)
            (setq str (strcat "\\" str))
            (setq
              str (strcat (substr str 1 (- n 1)) "\\" (substr str n))
          ) ;_ end of if
          (setq n (+ n 2))
        ) ;_ end of progn
        (setq n (1+ n))
      ) ;_ end of if
    ) ;_ end of while
    ;;在所有双引号前加上反斜杠
    (setq n 1)
      (if (= (substr str n 1) "\"")
          (if (= n 1)
            (setq
          ) ;_ end of if
          (setq n (+ n 2))
        ) ;_ end of progn
        (setq n (1+ n))
      ) ;_ end of if
    ) ;_ end of while
    ;; 写入文件
    (write-line
      (strcat "                     \"" str "\"  ")
      lsp
  ) ;_ end of while
  (setq        str (strcat "     ) (write-line x dcl_file) )\n"
                    "     (setq dcl_file (close dcl_file)))\n"
  (write-line str2 lsp)
  (close lsp)
  (close dcl)
  (princ "\n")
  (prompt (strcat " << *** DCL和LSP文件合并完成 *** >> 文件名"
                  newFName
  (prin1)
) ;_ end of defun
参与人数 6明经币 +5 金钱 +6 收起 理由
hubeiwdlue + 1 很给力!
趣意人生 + 1 很给力!
liunian0524 + 1 赞一个!
dtucad + 1 赞一个!
muwind + 1 很给力!
xshrimp + 6 赞一个!
 楼主| 发表于 2023-6-19 08:17:34 | 显示全部楼层
迷失1786 发表于 2023-6-18 22:12
好的,大哥,我合成了,但用不了,是什么原因呢?
你的程序有两个问题:
1.程序中有两个load_dialog ,我只考虑了一个的情况。
2.因为你两次load_dialog,不能删除生成的临时文件。如果删除了临时文件,后面的加载一个不存在的文件,肯定会出错。
附件是我试验好了的代码,你看看吧。
学习了,主要是要理好 (vl-file-delete tmp-dcl-file-name) 这行放的位置;  发表于 7 小时前
发表于 2022-6-6 18:57:14 来自手机 | 显示全部楼层
非常感谢楼主分享好码
发表于 2022-11-11 18:52:14 | 显示全部楼层
baitang36 发表于 2022-11-11 08:35
已按你的要求改进,请试用。
感谢。
这个位置不对,和我之前的改动一样。出不来菜单。一共有三个位置要改。图中2个红色箭头部分。
还有起始位置一个定义一个函数名,此函数名最好能采用数字+随机变量的形式。以免多个lsp合并出问题。
至于为什么要把初始化定义为函数,肯定是有原因的。论坛里面好多lsp都有“嵌套命令不能超过4层的”提示,导致CAD出错,而非正常终止的问题。
定义为函数在dcl_bhatch这里调用,就能避免这类问题。当然,dcl_bhatch 估计也得改成随机的函数名了。
如果要完美的话,就是 (dcl_bhatch) (dcl_file_New)均为该次合并时的随机名称,(dcl_file_New)即为dcl初始化参数用。
照图片位置加载、删除就没有多个临时垃圾文件的问题。(dcl_bhatch)随机则可以避免多个合并了dcl的lsp再次合并编译函数重名的问题。
发表于 2022-6-6 16:42:42 | 显示全部楼层
感谢大佬共享代码!
发表于 2022-6-6 17:08:45 | 显示全部楼层
感谢大佬分享代码。原lsp文件注释需要全部删除,否则合并会出错
 楼主| 发表于 2022-6-6 19:53:54 | 显示全部楼层
原因是read-line把回车换行符给丢了。已改进,不用read-line,可以支持注释了。
 楼主| 发表于 2022-6-6 20:45:32 | 显示全部楼层
669423907 发表于 2022-6-6 18:57
非常感谢楼主分享好码
已改进,再试试?
发表于 2022-6-6 21:42:17 | 显示全部楼层
试了下 很不错!  可以合并,也很方便,一键生成。
发表于 2022-6-6 22:30:17 | 显示全部楼层
感谢分享。测试很好用!!!!
发表于 2022-6-7 08:05:48 来自手机 | 显示全部楼层
这个好!这个好
发表于 2022-6-7 08:09:05 | 显示全部楼层
好用,谢谢
GMT+8, 2025-4-30 23:21 , Processed in 0.240869 second(s), 29 queries , Gzip On.
