查看: 1247|回复: 2
圆弧半径调整为(10的整数倍)
发表于 2022-5-16 20:29:46 | 显示全部楼层 |阅读模式
2明经币
如题,批量将圆弧的半径调整为10的整数倍,弧长可以不变
发表于 2022-5-16 20:29:47 | 显示全部楼层
  1. (defun c:tt ()
  2.   "批量将圆弧的半径调整为10的整数倍,弧长保持不变"
  3.   (setq i -1)
  4.   (if (setq ss (ssget '((0 . "arc"))))
  5.     (while (setq s1 (ssname ss (setq i (1+ i))))
  6.       (setq ob (vlax-ename->vla-object s1)
  7.             l1 (vla-get-ArcLength ob)
  8.             rr (vla-get-radius ob)
  9.             rr (* (fix (/ rr 10)) 10)
  10.             rr (if (= rr 0)10 rr)
  11.       )
  12.       (vla-put-radius ob rr)
  13.       (setq l2 (vla-get-ArcLength ob)
  14.             dl (* (- l1 l2) 0.5)
  15.       )
  16.       (command "LENGTHEN" "de"dl(list s1 (vlax-curve-getStartPoint s1))(list s1 (vlax-curve-getendPoint s1)) "")
  17.     ;(setq l2 (vla-get-ArcLength ob))(princ l1)(princ " ")(princ l2)
  18.     )
  19.   )
  20.   (princ)
  21. )
参与人数 1金钱 +5 收起 理由
start4444 + 5 666
 楼主| 发表于 2022-5-20 22:46:18 | 显示全部楼层
谢谢 ,完美解决
GMT+8, 2025-5-1 07:55 , Processed in 0.161516 second(s), 23 queries , Gzip On.
