查看: 1584|回复: 1
[【PyCAD】] pycad 读写EXCEL
发表于 2022-4-21 21:20:27 | 显示全部楼层 |阅读模式
具体参考Microsoft.Office.Interop.Excel用法,与查到的资料不一致的地方,读单元格数据用的是Value2.ToString()在这边卡了很久。网上查到的都是Value.ToString(),返回是<bound dispmethod Value>
from pycad.system import *
from pycad.runtime import *
efilename = None
@command()
def excel1(doc):
    import clr
    clr.AddReference('Microsoft.Office.Interop.Excel')
    from Microsoft.Office.Interop import Excel
    from System.Runtime.InteropServices import Marshal
    pfo = aced.PromptOpenFileOptions("选择excel文件")
    pfo.Filter = "Excel文件(*.xlsx)|*.xlsx"
    pfo.PreferCommandLine = acapp.GetSystemVariable("FILEDIA") == 0
    pfo.InitialDirectory = pye.extensionspath + "\\.scripts\\"
    global efilename
    pfo.InitialFileName = efilename
    pr = doc.Editor.GetFileNameForOpen(pfo)
    if pr.Status == aced.PromptStatus.OK:
        file= pr.StringResult
        print(file)
        ex=Excel.ApplicationClass()
        ex.Visible = True
        ex.DisplayAlerts = False
        wb=ex.Workbooks.Open(file)
        wsh=wb.Worksheets['Sheet3']
        wsh.Cells[1,4].Value="asdsada"
        str = wsh.Cells[1,4].Value2.ToString()
        print(str)
参与人数 1金钱 +15 收起 理由
e2002 + 15 赞一个!
发表于 2022-4-22 06:52:20 | 显示全部楼层
不错,很有参考价值
GMT+8, 2025-5-1 07:24 , Processed in 0.156416 second(s), 24 queries , Gzip On.
