- 积分
- 4672
- 明经币
- 个
- 注册时间
- 2015-1-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - <div class="blockcode"><blockquote>;|Copyright(C) 1994-2005 by KozMos Inc.
- Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby
- granted, provided that the above copyright notice appears in all copies and that both that copyright notice
- and the limited warranty and restricted rights notice below appear in all supporting documentation.
- KozMos PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS. KozMos SPECIFICALLY DISCLAIMS ANY IMPLIED
- WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. KozMos, INC. DOES NOT WARRANT THAT THE OPERATION
- OF THE PROGRAM WILL BE UNINTERRUPTED OR ERROR FREE.
- Public Function
- Name
- (vlxls-variant->list VariantValue)
- Usage
- Convert a variant into normal Visual LISP LIST data, nested Variant and safearray will also be converted.
- Input
- VARIANT
- Input Variant
- RetVal
- True
- LIST
- Valid Visual LISP variable value
- Fail
- STR
- (Defun vlxls-variant->list (VarX / Run Item Rtn)
- (setq Run T)
- (while
- Run
- (cond ((= (type VarX) 'SAFEARRAY)
- (setq VarX (vlax-safearray->list VarX))
- ((= (type VarX) 'VARIANT)
- (if (member (vlax-variant-type VarX) (list 5 4 3 2))
- (setq VarX (vlax-variant-change-type Varx vlax-vbString))
- (setq VarX (vlax-variant-value VarX))
- (t (setq Run nil))
- (cond ((= (type VarX) 'LIST)
- (foreach Item VarX
- (setq Item (vlxls-variant->list Item)
- Rtn (append Rtn (list Item))
- ((= VarX nil) (setq Rtn ""))
- (t (setq Rtn VarX))
- Rtn
- ;|Examples:
- NONE
- Color Transfer Function
- Name
- (vlxls-color-eci->truecolor ExcelColorIndexNumber)
- Usage
- Convert Excel ColorIndex number into most matched AutoCAD2004+ truecolor number (stored by DXF420).
- Input
- INT
- Excel ColorIndex integer (0 to 56)
- RetVal
- True
- INT
- Valid AutoCAD 2004+ truecolor number
- Fail
- INT
- 16711935 for None|;
- (Defun vlxls-color-ECI->truecolor (Color / Rtn)
- (if (setq Rtn (cdr (assoc Color *xls-color*)))
- (setq Rtn (nth 1 Rtn))
- (if (null Rtn)
- (setq Rtn 16711935)
- Rtn
- ;|Examples:
- (vlxls-color-eci->truecolor 0) è16711935
- (vlxls-color-eci->truecolor 1)è 0
- (vlxls-color-eci->truecolor 12)è 8355584
- (vlxls-color-eci->truecolor 120) è16711935
- Name
- (vlxls-color-eci->aci ExcelColorIndexNumber)
- Usage
- Convert Excel ColorIndex number into most matched AutoCAD ACI Integer number.
- Input
- INT
- RetVal
- True
- INT
- Valid AutoCAD ACI Integer number (0 to 256)
- Fail
- INT
- 256 for BYLAYER
- (Defun vlxls-color-eci->aci (Color / Rtn)
- (if (null (setq Rtn (cdr (assoc Color *xls-color*))))
- (setq Rtn 256)
- (setq Rtn (nth 0 Rtn))
- Rtn
- Examples:
- (vlxls-color-eci->aci 0) è256
- (vlxls-color-eci->aci 1)è 18
- (vlxls-color-eci->aci 12)è 56
- (vlxls-color-eci->aci 120) è256
- Name
- (vlxls-color-aci->eci AutoCADColorIndexNumber)
- Usage
- Convert AutoCAD ColorIndex number into Excel ColorIndex .
- Input
- INT
- AutoCAD ColorIndex integer (0 to 256)
- RetVal
- True
- INT
- Valid Excel ColorIndex number (from 1 to 56)
- Fail
- INT
- 0 for NONE
- (Defun vlxls-color-aci->eci (Color / Item Rtn)
- (foreach Item *xls-color*
- (if (= (nth 1 Item) Color)
- (setq Rtn (car Item))
- (if (null Rtn)
- (setq Rtn 0)
- Rtn
- Examples:
- (vlxls-color-aci->eci 0) è0
- (vlxls-color-aci->eci 1)è 3
- (vlxls-color-aci->eci 12)è 0
- (vlxls-color-aci->eci 120) è0
- Name
- (vlxls-color-aci->truecolor AutoCADColorIndexNumber)
- Usage
- Convert AutoCAD ColorIndex number into most matched AutoCAD2004+ true color number (using Excel ColorIndex as
- intermediary, provided for use in AutoCAD2002. In AutoCAD2004+, this can be done directly by AutoCAD.
- Input
- INT
- RetVal
- True
- INT
- Valid AutoCAD2004+ truecolor number
- Fail
- INT
- 16711935 for None
- (Defun vlxls-color-aci->truecolor (aci)
- (vlxls-color-eci->truecolor (vlxls-color-aci->eci aci))
- Examples:
- (vlxls-color-aci-> truecolor 0) è 16711935
- (vlxls-color-aci->truecolor 1)è 16711680
- (vlxls-color-aci-> truecolor 12)è 16711935
- (vlxls-color-aci-> truecolor 120) è 16711935
- Excel Application Session Progress Function
- Name
- (vlxls-app-init)
- Usage
- Import Microsoft Excel Type Library, set prefix of "msxl-" for all of the :methods-prefix; :properties-prefix
- & :constants-prefix. This function can detect Excel’s installation path automatically from Windows registry so
- that it can run smoothly on any language platform of Windows and Office.
- Input
- NONE
- No Arguments
- RetVal
- True
- BOOLEAN
- msxl-xl24HourClock
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-Init
- (/ OSVar GGG Olb8 Olb9 Olb10 TLB Out msg msg1 msg2)
- (if *Chinese*
- (setq msg "n 初始化微软Excel "
- msg1 "42初始化Excel错误42"
- msg2 (strcat
- "42 警告"
- "n ===="
- "n 无法在您的计算机上检测到微软Excel软件"
- "n 如果您确认已经安装Excel, 请发送电子邮"
- "n 件到GuXiaolin@hxch.com.cn获取更多的解决方案42"
- (setq msg "n Initializing Microsoft Excel "
- msg1 "42Initialization Error42"
- msg2 (strcat
- "42 WARNING"
- "n ======="
- "n Can NOT detect Excel97/200X/XP in your computer"
- "n If you already have Excel installed, please email"
- "n us to get more solution via GuXiaolin@hxch.com.cn42")
- (if (null msxl-xl24HourClock)
- (progn
- (if (and (setq GGG
- (vl-registry-read
- "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Excel.EXE"
- "Path"
- (setq GGG (strcase (strcat GGG "Excel.EXE")))
- (progn
- (foreach OSVar (list "SYSTEMROOT" "WINDIR"
- "WINBOOTDIR" "SYSTEMDRIVE"
- "USERNAME" "COMPUTERNAME"
- "HOMEDRIVE" "HOMEPATH"
- "PROGRAMFILES"
- (if (vl-string-search (strcat "%" OSVar "%") GGG)
- (setq GGG (vl-string-subst
- (strcase (getenv OSVar))
- (strcat "%" OSVar "%")
- GGG
- (setq Olb8 (findfile (vl-string-subst "EXCEL8.OLB" "EXCEL.EXE" GGG))
- Olb9 (findfile (vl-string-subst "EXCEL9.OLB" "EXCEL.EXE" GGG))
- Olb10 (findfile (vl-string-subst "EXCEL10.OLB" "EXCEL.EXE" GGG))
- (cond ((= (vl-filename-base (vl-filename-directory GGG))
- "OFFICE11"
- (setq TLB GGG
- Out "2003"
- ((= (vl-filename-base (vl-filename-directory GGG))
- "OFFICE10"
- (setq TLB GGG
- Out "XP"
- (Olb9
- (setq TLB Olb9
- Out "2000"
- (Olb8
- (setq TLB Olb8
- Out "97"
- (t (setq Out "Version Unknown"))
- (if TLB
- (progn
- (princ (strcat MSG Out "..."))
- (vlax-import-type-library
- :tlb-filename TLB :methods-prefix
- "msxl-" :properties-prefix
- "msxl-" :constants-prefix "msxl-"
- (progn
- (if vldcl-msgbox
- (vldcl-msgbox "x" msg1 msg2)
- (alert (read msg2))
- (exit)
- Examples:
- (vlxls-app-init)è 33
- Name
- (vlxls-app-new ShowExcelFlag)
- Usage
- Open a new Excel session and start a new workbook.
- Input
- BOOLEAN
- T for display, nil for hide
- RetVal
- True
- VLOBJ
- Excel Session vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-New (UnHide / Rtn)
- (if (vlxls-app-init)
- (progn
- (if *Chinese*
- (princ "n 新建微软Excel工作表...")
- (princ "n Creating new Excel Spreadsheet file...")
- (if (setq Rtn (vlax-get-or-create-object "Excel.Application"))
- (progn
- (vlax-invoke-method
- (vlax-get-property Rtn 'WorkBooks)
- 'Add
- (if UnHide
- (vla-put-visible Rtn 1)
- (vla-put-visible Rtn 0)
- Rtn
- Examples:
- (setq *xlapp* (vlxls-app-new T)) è #<VLA-OBJECT _Application 001db27c>
- Name
- (vlxls-app-open XLSfilename ShowExcelFlag)
- Usage
- Open a new Excel session to start existing XLS file.
- Input
- STR
- XLS file name with full path, ".XLS" not needed.
- BOOLEAN
- RetVal
- True
- VLOBJ
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-open
- (XLSFile UnHide / ExcelApp WorkSheet Sheets ActiveSheet Rtn)
- (setq XLSFile (strcase XLSFile))
- (if (null (wcmatch XLSFile "*.XLS"))
- (setq XLSFile (strcat XLSFile ".XLS"))
- (if (and (findfile XLSFile)
- (setq Rtn (vlax-get-or-create-object "Excel.Application"))
- (progn
- 'Open
- XLSFile
- (if UnHide
- Rtn
- Examples:
- (setq *xlapp* (vlxls-app-open “C:/test.XLS” T)) è #<VLA-OBJECT _Application 001efd2c>
- Name
- (vlxls-app-save ExcelSessionVLA-OBJECT)
- Usage
- Perform save operation in Excel.
- Input
- VLOBJ
- Excel session vla-object
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-save (xlapp)
- (equal (vlax-invoke-method
- (vlax-get-property Xlapp "ActiveWorkbook")
- "Save"
- :vlax-true
- Examples:
- (vlxls-app-save *xlapp*) è T
- Name
- (vlxls-app-saveas ExcelSessionVLA-OBJECT SavedFileName)
- Usage
- Perform saveas operation in Excel.
- Input
- VLOBJ
- STR
- Saved XLS file name with full path
- NIL for a temporary “XLS.XLS” file in current drawing path.
- RetVal
- True
- STRING
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-saveas (xlapp Filename / Rtn)
- (if (null filename)
- (setq filename (strcat (getvar "dwgprefix") "XLS.XLS"))
- (if (null (wcmatch (setq filename (strcase Filename)) "*`.XLS"))
- (setq filename (strcat filename ".XLS"))
- (if (findfile Filename)
- (vl-file-delete (findfile Filename))
- "SaveAs"
- Filename
- msxl-xlNormal
- :vlax-False
- :vlax-False
- nil
- (findfile Filename)
- Examples:
- (vlxls-app-saveas *xlapp* nil) è “C:/Temp-Folder/XLS.XLS”
- (vlxls-app-saveas *xlapp* “C:/Temp-Folder/XLS.XLS”) è “C:/Temp-Folder/XLS.XLS”
- (vlxls-app-saveas *xlapp* nil) è NIL
- Name
- (vlxls-app-quit ExcelSessionVLA-OBJECT SavedFlag)
- Usage
- Quit active workbook of Excel session and release Excel application.
- Input
- VLOBJ
- BOOLEAN
- Save Excel active workwook flag, T for save, NIL for unsave
- RetVal
- True
- BOOLEAN
- NIL
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-quit (ExlObj SaveYN)
- (if SaveYN
- (vlax-get-property ExlObj "ActiveWorkbook")
- 'Close
- 'Close
- :vlax-False
- (vlax-invoke-method ExlObj 'QUIT)
- (vlax-release-object ExlObj)
- (setq ExlObj nil)
- (gc)
- Examples:
- (vlxls-app-quit *xlapp* nil) è nil
- Name
- (vlxls-app-kill)
- Usage
- Close all active Excel workbooks.
- Input
- NONE
- No Arguments
- RetVal
- True
- BOOLEAN
- NIL
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-kill (SaveYN / ExlObj)
- (while (setq ExlObj (vlax-get-object "Excel.Application"))
- (vlxls-app-quit ExlObj SaveYN)
- Examples:
- (vlxls-app-kill T) è nil
- Name
- (vlxls-app-autofit ExcelSessionVLA-OBJECT)
- Usage
- Autofit the column width of all Excel session used ranges.
- Input
- VLOBJ
- RetVal
- True
- Variant
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-app-autofit (xlapp / sh act Rtn)
- (setq act (vlxls-Sheet-Get-Active xlapp))
- (foreach sh (append (vl-remove act (vlxls-sheet-get-all Xlapp))
- (list act)
- (setq Rtn (variant-value
- (msxl-autofit
- (msxl-get-columns
- (msxl-get-Cells
- (vlxls-sheet-get-usedrange xlapp sh)
- (equal Rtn :vlax-true)
- Examples:
- (vlxls-app-autofit *xlapp*) è T
- (vlxls-app-autofit *xlapp*) è NIL
- Excel Sheet Progress Function
- Name
- (vlxls-sheet-get-all ExcelSessionVLA-OBJECT)
- Usage
- Get name list of all sheets.
- Input
- VLOBJ
- RetVal
- True
- LIST
- List contain all sheets’ name
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-get-all (xlapp / SH Rtn)
- (vlax-for SH (vlax-get-property Xlapp "sheets")
- (setq Rtn (cons (vlax-get-property sh "Name") Rtn))
- (reverse Rtn)
- Examples:
- (vlxls-sheet-get-all *xlapp*) è ("Sheet1" "Sheet2" "Sheet3")
- Name
- (vlxls-sheet-get-active ExcelSessionVLA-OBJECT)
- Usage
- Get active sheet name.
- Input
- VLOBJ
- RetVal
- True
- STRING
- Active sheet's name string
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-Sheet-Get-Active (xlapp)
- (vlax-get-property (msxl-get-ActiveSheet Xlapp) 'name)
- Examples:
- (vlxls-sheet-get-active *xlapp*) è "Sheet2"
- Name
- (vlxls-sheet-delete ExcelSessionVLA-OBJECT DeleteSheetName)
- Usage
- Delete certain sheet by name.
- Input
- VLOBJ
- STRING
- Sheet name to delete
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-delete (xlapp Name / sh Rtn)
- (setq Rtn (vlxls-sheet-get-all Xlapp))
- (vlax-for sh (vlax-get-property Xlapp "sheets")
- (if (= (vlax-get-property sh "Name") Name)
- (vlax-invoke-method sh "Delete")
- (not (equal Rtn (vlxls-sheet-get-all Xlapp)))
- Examples:
- (vlxls-sheet-delete *xlapp* “Sheet1”) è T
- (vlxls-sheet-delete *xlapp* “UnExistingSheet”) è NIL
- Name
- (vlxls-sheet-rename NewSheetName OldSheetName ExcelSessionVLA-OBJECT)
- Usage
- Rename certain sheet by name.
- Input
- STRING
- New sheet name string
- STRING
- Old sheet name string
- VLOBJ
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-rename (New Old Xlapp / sh Rtn)
- (if (null old)
- (setq old (msxl-get-name (msxl-get-activesheet Xlapp)))
- (if (member New (vlxls-sheet-get-all Xlapp))
- (setq Rtn nil)
- (progn
- (if (= (msxl-get-name sh) Old)
- (msxl-put-name sh New)
- (setq Rtn
- (equal New
- Rtn
- ;|Examples:
- (vlxls-sheet-rename “New” “Sheet1” *xlapp*) è T
- (vlxls-sheet-rename “New” NIL *xlapp*) è T
- (vlxls-sheet-rename “Sheet3” NIL *xlapp*) è NIL
- (vlxls-sheet-rename “Sheet2” “Sheet1” *xlapp*) è NIL
- (vlxls-sheet-rename “Sheet2” “UnExistSheet” *xlapp*) è NIL
- Name
- (vlxls-sheet-add ExcelSessionVLA-OBJECT NewSheetName)
- Usage
- New sheet name. If sheet name exist, return NIL
- Input
- VLOBJ
- STRING
- New added sheet name string
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-add (xlapp Name / Rtn)
- (if (member name (vlxls-sheet-get-all xlapp))
- (setq Rtn nil)
- (progn
- (vlax-put-property
- (vlax-get-property Xlapp "sheets")
- "Add"
- "name"
- Name
- (setq Rtn (equal (vlxls-sheet-get-active xlapp) name))
- Rtn
- Examples:
- (vlxls-sheet-add *xlapp* “Sheet1”) èT
- (vlxls-sheet-add *xlapp* NIL) èT
- (vlxls-sheet-add *xlapp* “NewSheet”) è NIL
- Name
- (vlxls-sheet-put-active ExcelSessionVLA-OBJECT ActiveSheetName)
- Usage
- Put certain sheet as active sheet. If sheet name not exist, create automatically.
- Input
- VLOBJ
- STRING
- New active sheet name string
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-put-active (xlapp Name / sh)
- (if (null (vlxls-sheet-add xlapp name))
- (vlax-invoke-method sh "Activate")
- (equal (vlxls-sheet-get-active xlapp) name)
- Examples:
- (vlxls-sheet-put-active *xlapp* “Sheet1”) è T
- (vlxls-sheet-put-active *xlapp* “NewSheet”) è T
- Name
- (vlxls-sheet-get-usedrange ExcelSessionVLA-OBJECT SheetName)
- Usage
- Get all used range of certain Excel sheet. If sheet name not exist, return NIL.
- Input
- VLOBJ
- STRING
- Excel sheet name string, NIL for current active sheet.
- RetVal
- True
- VLOBJ
- Excel Range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-sheet-get-UsedRange (xlapp Name / sh Rtn)
- (if (null Name)
- (setq Name (vlax-get-property (msxl-get-ActiveSheet Xlapp) 'Name))
- (setq Rtn (vlax-get-property sh "UsedRange"))
- Rtn
- Examples:
- (vlxls-sheet-get-usedrange *xlapp* “Sheet1”) è T
- (vlxls-sheet- get-usedrange *xlapp* “NewSheet”) è T
- Excel Cell and Range Progress Function
- Name
- (vlxls-cellid CellIDStringOrList)
- Usage
- Divide complex Excel Cell ID into a two-string-item list, contain the Left-Upper and Right-Lower Cell ID.
- If only one Cell ID is provided, set the Right-Lower Cell ID to “”.
- Input
- STR/LIST
- Complex Excel Cell ID string or simple Cell ID string/list.
- RetVal
- True
- LIST
- List of Left-Upper and Right-Lower Cell ID
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cellid (id / xx id1 id2 Rtn)
- (if (= (type id) 'list)
- (setq id (vlxls-rangeid id))
- (setq id (strcase id))
- (if (null (setq xx (vl-string-search ":" id)))
- (setq Rtn (list id ""))
- (setq id1 (substr id 1 xx)
- id2 (substr id (+ xx 2))
- id1 (vlxls-rangeid id1)
- id2 (vlxls-rangeid id2)
- Rtn (list (vlxls-rangeid
- (list (min (car id1) (car id2))
- (min (cadr id1) (cadr id2))
- (vlxls-rangeid
- (list (max (car id1) (car id2))
- (max (cadr id1) (cadr id2))
- Rtn
- Examples:
- (vlxls-cellid ‘(3 14)) è ("C14" "")
- (vlxls-cellid “D23”) è ("D23" "")
- (vlxls-cellid “C12:F3”) è ("C3" "F12")
- (vlxls-cellid “F15:G22”) è ("F15" "G22")
- Name
- (vlxls-rangeid CellIDStringOrList)
- Usage
- VLXLS treats Excel Cell ID in two types: AutoCAD LIST and Excel simple Cell ID String. This function is used to convert Cell ID between the two types.
- Input
- STR/LIST
- The Cell ID list or string
- RetVal
- True
- STR/LIST
- Cell ID value in another VLXLS ID type
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-rangeid (id / str->list list->str xid->str Rtn)
- (Defun str->list (str / ii xk xv rr pos x y)
- (setq rr (strlen str))
- (foreach ii '("0" "1" "2" "3" "4" "5" "6" "7" "8" "9")
- (if (setq pos (vl-string-search ii str))
- (setq rr (min pos rr))
- (setq x (substr str 1 rr)
- y (substr str (1+ rr))
- (if (= (strlen x) 2)
- (setq xk (- (ascii (substr x 1 1)) 64)
- xv (- (ascii (substr x 2)) 64)
- (setq xk 0
- xv (- (ascii x) 64)
- (list (+ (* xk 26) xv) (read y))
- (Defun xid->str (IntNum / PosNum Nm-One)
- (setq Nm-One (1- IntNum)
- PosNum (/ Nm-One 26)
- (if (= PosNum 0)
- (chr (+ 65 (rem Nm-One 26)))
- (strcat (chr (+ 64 PosNum)) (chr (+ 65 (rem Nm-One 26))))
- (Defun list->str (idr / x y)
- (setq x (car idr)
- y (cadr idr)
- x (xid->str x)
- y (itoa y)
- (strcat x y)
- (cond ((= (type id) 'str) (setq Rtn (str->list id)))
- ((= (type id) 'list) (setq Rtn (list->str id)))
- Rtn
- Examples:
- (vlxls-rangeid ‘(3 14)) è "C14"
- (vlxls-rangeid “D23”) è (4 23)
- (vlxls-rangeid “DD23”) è (108 23)
- Name
- (vlxls-range-autofit RangeVLA_OBJECT)
- Usage
- Autofit the column width of a certain range object.
- Input
- VLOBJ
- The Excel Range vla-object
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-range-autofit (range)
- (equal (vlax-variant-value
- (msxl-autofit
- (msxl-get-columns (msxl-get-Cells range))
- :vlax-true
- Examples:
- (vlxls-range-autofit (msxl-get-range *xlapp* “C12:F15”)) è T
- (vlxls-range-autofit RangeObject) è NIL
- Name
- (vlxls-cell-put-active ExcelSessionVLA-OBJECT CellIDStringOrList)
- Usage
- Select to certain Cell ID and activate it.
- Input
- VLOBJ
- The Excel Session vla-object
- STR/LIST
- RetVal
- True
- VLOBJ
- Active Range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-put-active (xl id / Rtn)
- (msxl-activate (setq Rtn (msxl-get-range xl id)))
- Rtn
- Examples:
- (vlxls-cell-put-active *xlapp* “C12:F15”) è #<VLA-OBJECT Range 09d1998c>
- (vlxls-cell-put-active *xlapp* “F12”) è #<VLA-OBJECT Range 06c389a2>
- Name
- (vlxls-cell-get-value ExcelSessionVLA-OBJECT CellIDStringOrList)
- Usage
- Get value of certain Cell ID.
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- STR/LIST
- String for one cell, a 2 dimension list for multiple cells or merged cell
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-get-value (xl id)
- (msxl-get-value2 (msxl-get-range xl id))
- Examples:
- (vlxls-cell-get-value *xlapp* “C12”) è “g”
- (vlxls-cell-get-value *xlapp* “C12:C12”) è “g”
- (vlxls-cell-get-value *xlapp* “C12:C15”) è (("g") ("") ("") (""))
- (vlxls-cell-get-value *xlapp* “C12:F12”) è (("g" "ds" "" ""))
- (vlxls-cell-get-value *xlapp* “C12:F15”) è (("g" "ds" "" "") ("" "" "g" "") ("" "" "" "") ("" "" "" ""))
- Name
- (vlxls-cell-put-value ExcelSessionVLA-OBJECT CellIDStringOrList DataList)
- Usage
- Pass a 1 dimension or a 2 dimension string list into Excel, started at certain Cell ID.
- Input
- VLOBJ
- STR/LIST
- The start Cell ID [Left-Upper] list or string
- STR/LIST
- If this argument is a string, VLXLS will fill same string to all cells.
- Or the argument should be a 1 dimension list or a 2 dimension list to fill in Excel. If the data list can NOT match the
- given cell ID, VLXLS will only fill first cell, fill to other cells will be ignored.
- RetVal
- True
- VLOBJ
- All Excel Range vla-object that just be filled in by given data list
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-put-value
- (xl id Data / vllist-explode idx xx yy ary Rtn)
- (Defun vllist-explode (lst)
- (cond
- ((not lst) nil)
- ((atom lst) (list lst))
- ((append (vllist-explode (car lst))
- (vllist-explode (cdr lst))
- (if (null id)
- (setq id "A1")
- (if (= (type (car Data)) 'LIST)
- (setq ARY (vlax-make-safearray
- vlax-vbstring
- (cons 0 (1- (length Data)))
- (cons 1 (length (car Data)))
- XX (1- (length (car Data)))
- YY (1- (length Data))
- (setq
- ARY (vlax-make-safearray
- vlax-vbstring
- (cons 0 1)
- (cons 1 (length Data))
- XX (1- (length Data))
- YY 0
- (if (= xx yy 0)
- (MSXL-PUT-VALUE2
- (setq Rtn (msxl-get-range xl id))
- (car (vllist-explode data))
- (progn
- (setq id (vlxls-cellid-calc id xx yy))
- (MSXL-PUT-VALUE2
- (vlax-safearray-fill ary data)
- Rtn
- Examples:
- (vlxls-cell-put-value *xlapp* “C12” “xx”) è #<VLA-OBJECT Range 093a7764>
- (vlxls-cell-put-value *xlapp* “C12:F3” “xx”) è #<VLA-OBJECT Range 43c5ac64>
- (vlxls-cell-put-value *xlapp* “C12:D13” ‘((“zz” “xx”)(“xx” “zz”))) è #<VLA-OBJECT Range 1b8f2a64>
- Name
- (vlxls-cellid-calc BaseCellId XOffset YOffset)
- Usage
- Calculate a new Cell ID for given delta X and Y from base Cell ID.
- Input
- STR/LIST
- Base Cell ID string or list
- INT
- X offset integer of Cell ID
- INT
- Y offset integer of Cell ID
- RetVal
- True
- STRING
- An Excel Complex Cell ID format contain the base Cell ID and target Cell ID.
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cellid-calc (id x y / idx)
- (setq id (car (vlxls-cellid id))
- idx (vlxls-rangeid id)
- x (+ x (car idx))
- x (if (< x 1)
- 1
- x
- y (+ y (cadr idx))
- y (if (< y 1)
- 1
- y
- idx (vlxls-rangeid (list x y))
- id (vlxls-cellid (strcat id ":" idx))
- id (strcat (car id) ":" (cadr id))
- id
- Examples:
- (vlxls-cellid-calc “C12” 2 20) è "C12:E32"
- (vlxls-cellid-calc ‘(2 23) 2 -120) è "B1:D23"
- Name
- (vlxls-get-row-value ExcelSessionVLA-OBJECT StartCellIDStringOrList RowCellNumber)
- Usage
- Get values of certain row.
- Input
- VLOBJ
- STR/LIST
- The Start Cell ID list or string
- INT
- Number of cells in row to read.
- RetVal
- True
- LIST
- A list contain cells' value in row
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-get-row-value (xl id len / vllist-explode Rtn)
- (cond
- ((not lst) nil)
- (if (> len 0)
- (setq id (vlxls-cellid-calc id (1- len) 0))
- (setq id (vlxls-cellid-calc id (1+ len) 0))
- (setq Rtn (vllist-explode (vlxls-cell-get-value xl id)))
- Rtn
- Examples:
- (vlxls-get-row-value *xlapp* “C12” 2) è ("zz" "xxx")
- (vlxls-get-row-value *xlapp* “C12” -20) è ("" "" "zz")
- Name
- (vlxls-put-row-value ExcelSessionVLA-OBJECT StartCellIDStringOrList StringList)
- Usage
- Put a string list into Excel row started by certain cell.
- Input
- VLOBJ
- STR/LIST
- STR/LIST
- A string to fill in one cell or a 1 dimension string list to fill in row cells.
- RetVal
- True
- VLOBJ
- Filled Excel Range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-put-row-value (xl id data / Rtn)
- (if (= (type data) 'str)
- (setq data (list data))
- id (vlxls-cellid-calc id (1- (length data)) 0)
- ;;;不允许自动调整大小
- ;(vlxls-range-autofit
- (setq Rtn (vlxls-cell-put-value xl id (list data)))
- Rtn
- Examples:
- (vlxls-put-row-value *xlapp* “C12” “abc”) è#<VLA-OBJECT Range 2a621cac>
- (vlxls-put-row-value *xlapp* ‘(12 3) “abc”) è#<VLA-OBJECT Range 7a36c491>
- (vlxls-put-row-value *xlapp* “C12” ‘("zz" "xxx")) è#<VLA-OBJECT Range 09d1da1c>
- (vlxls-put-row-value *xlapp* ‘(12 3) ‘("zz" "xxx")) è#<VLA-OBJECT Range 0a26c4f3>
- Name
- (vlxls-get-column-value ExcelSessionVLA-OBJECT StartCellIDStringOrList ColumnCellNumber)
- Usage
- Get values of certain column.
- Input
- VLOBJ
- STR/LIST
- INT
- Number of cells in column to read.
- RetVal
- True
- LIST
- A list contain cells' value in column
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-get-column-value (xl id len / vllist-explode Rtn)
- (cond
- ((not lst) nil)
- (setq id (car (vlxls-cellid id)))
- (if (> len 0)
- (setq id (vlxls-cellid-calc id 0 (1- len)))
- (setq id (vlxls-cellid-calc id 0 (1+ len)))
- Rtn
- Examples:
- (vlxls-get-column-value *xlapp* “C12” 2) è ("zz" "sdfsdf")
- (vlxls-get-column-value *xlapp* “C12” -20) è ("" "" "xxx" "xxx" "xxx" "xxx" "xxx" "xxx" "xxx" "xxx" "xxx" "zz")
- Name
- (vlxls-put-column-value ExcelSessionVLA-OBJECT StartCellIDStringOrList StringList)
- Usage
- Put a string list into Excel column started by certain cell.
- Input
- VLOBJ
- STR/LIST
- STR/LIST
- A string to fill in one cell or a 1 dimension string list to fill in column cells.
- RetVal
- True
- VLOBJ
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-put-column-value (xl id data / item Rtn)
- id (vlxls-cellid-calc id 0 (1- (length data)))
- (foreach item data
- (setq Rtn (cons (list item) Rtn))
- ;;;不允许自动调整表格大小
- (setq Rtn (vlxls-cell-put-value xl id (reverse Rtn)))
- Rtn
- Examples:
- (vlxls-put-column-value *xlapp* “C12” “abc”) è#<VLA-OBJECT Range 049c521b>
- (vlxls-put-column-value *xlapp* ‘(12 3) “abc”) è#<VLA-OBJECT Range 0235cba1>
- (vlxls-put-column-value *xlapp* “C12” ‘("zz" "xxx")) è#<VLA-OBJECT Range 09d1da1c>
- (vlxls-put-column-value *xlapp* ‘(12 3) ‘("zz" "xxx")) è#<VLA-OBJECT Range 0a26c4f3>
- Name
- (vlxls-cell-get-aci ExcelSessionVLA-OBJECT CellIDStringOrList)
- Usage
- Get the background color (In AutoCAD ColorIndex mode) of certain Excel cell, Multiple color will return 256.
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- INT
- Valid ACI Integer number (0 to 256)
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-get-aci (xl id)
- (vlax-variant-value
- (msxl-get-colorindex
- (msxl-get-interior (msxl-get-range xl id))
- Examples:
- (vlxls-cell-get-aci *xlapp* “C12”) è256
- (vlxls-cell-get-aci *xlapp* ‘(12 3)) è15
- Name
- (vlxls-cell-put-aci ExcelSessionVLA-OBJECT CellIDStringOrList ACINumber)
- Usage
- Put or clear the background color (In AutoCAD ColorIndex mode) of certain Excel cells.
- Input
- VLOBJ
- STR/LIST
- INT
- ACI Integer number, NIL for remove background color
- RetVal
- True
- VLOBJ
- Modified Excel Range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-put-aci (xl id aci / Rtn)
- (if (null aci)
- (msxl-put-colorindex
- (msxl-get-interior (setq Rtn (msxl-get-range xl id)))
- (vlax-make-variant -4142)
- (vlxls-color-aci->eci aci)
- Rtn
- Examples:
- (vlxls-cell-put-aci *xlapp* “C12” 6) è#<VLA-OBJECT Range 09d1369c>
- (vlxls-cell-put-aci *xlapp* “C12” nil) è#<VLA-OBJECT Range 09d1369c>
- Name
- (vlxls-text-get-aci ExcelSessionVLA-OBJECT CellIDStringOrList)
- Usage
- Get the text color (In AutoCAD ColorIndex mode) of certain Excel cells.
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- INT
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-text-get-aci (xl id)
- (msxl-get-font (msxl-get-range xl id))
- Rtn
- Examples:
- (vlxls-text-get-aci *xlapp* “C12”) è256
- (vlxls-text-get-aci *xlapp* ‘(12 3)) è15
- Name
- (vlxls-text-put-aci ExcelSessionVLA-OBJECT CellIDStringOrList ACINumber)
- Usage
- Put or clear the content color (In AutoCAD ColorIndex mode) of certain Excel cells.
- Input
- VLOBJ
- STR/LIST
- INT
- RetVal
- True
- VLOBJ
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-text-put-aci (xl id aci / Rtn)
- (if (null aci)
- (msxl-get-font (setq Rtn (msxl-get-range xl id)))
- (vlax-make-variant -4105)
- Rtn
- Examples:
- (vlxls-text-put-aci *xlapp* “C12” 6) è#<VLA-OBJECT Range 09d1369c>
- (vlxls-text-put-aci *xlapp* “C12” nil) è#<VLA-OBJECT Range 09d1369c>
- Name
- (vlxls-text-get-prop ExcelSessionVLA-OBJECT CellIDStringOrList)
- Usage
- Get the properties of content of certain Excel cells. Multiple cells will only record the Left-Upper cell.
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- LIST
- A dot-paired list contain text properties. Syntax is as following:
- ((0 . LeftUpperCellID)(7 . FontStyle) (62 . TextACIColor) (72 . TextAlignment) (420 . TextTrueColor))
- FontStyle will be recorded as Windows TTF font name displayed in Excel
- VLXLS only support horizontal for TextAlignment: 9=Left, 10=Center, 11=Right
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-text-get-prop
- (xl id / Cell Font DXF1 DXF7 DXF40 DXF72 DXF62 DXF420 Rtn)
- cell (msxl-get-range xl id)
- font (msxl-get-font cell)
- DXF7 (vlax-variant-value (msxl-get-name Font))
- DXF40 (vlax-variant-value (msxl-get-size Font))
- DXF72 (vlax-variant-value
- (msxl-get-HorizontalAlignment Cell)
- DXF72 (cond ((= DXF72 -4152) 11)
- ((= DXF72 -4108) 10)
- (t 9)
- DXF62 (vlxls-color-eci->aci
- (vlax-variant-value (msxl-get-colorIndex Font))
- DXF420 (vlxls-color-eci->truecolor
- Rtn (list (cons 0 (strcase id))
- (cons 7 DXF7)
- (cons 40 DXF40)
- (cons 62 DXF62)
- (cons 72 DXF72)
- (cons 420 DXF420)
- Rtn
- Examples:
- (vlxls-text-get-prop *xlapp* “C12”) è((0 . "C12") (7 . "Arial") (40 . 12.0) (62 . 256) (72 . 9) (420 . 16711935))
- (vlxls-text-get-prop *xlapp* ‘(2 10)) è((0 . "B10") (7 . "Arial") (40 . 12.0) (62 . 256) (72 . 11) (420 . 16711935))
- Name
- (vlxls-cell-get-prop ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Get the properties of certain Excel cells.
- Input
- VLOBJ
- STR
- The Cell ID string
- RetVal
- True
- LIST
- A dot-paired list contain cell properties. Syntax is as following:
- ((0 . CellIDString)(1 . CellValueList) (10 . LeftUpperLocation_of_LeftUpperCell) (41 . TotalColumnWidth)
- (42 . TotalRowHeight) (-1 . ReturnValue_of_vlxls-text-get-prop))
- If only one cell, CellValueList can be a string, or it will be a 2 dimension list.
- LeftUpperLocation_of_LeftUpperCell is in Excel units and Cell “A1” will be original.
- TotalRowHeight and TotalColumnWidth are both in Excel units
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-get-prop
- (xl id / range left top width height dxf10 Rtn)
- (if (vlxls-cell-merge-p xl id)
- (setq id (vlxls-cell-get-mergeid xl id))
- (setq range (msxl-get-range xl id)
- left (vlax-variant-value (msxl-get-left Range))
- top (vlax-variant-value (msxl-get-top Range))
- width (vlax-variant-value (msxl-get-width Range))
- height (vlax-variant-value (msxl-get-height Range))
- dxf10 (list left top)
- (cons 1 (vlxls-cell-get-value xl id))
- (cons 10 dxf10)
- (cons 41 width)
- (cons 42 height)
- (cons -1 (vlxls-text-get-prop xl id))
- Rtn
- Examples:
- (vlxls-cell-get-prop *xlapp* “C12:F14”) è((0 . "C12:F14") (1 ("zz" "xxx" "xxx" "xxx") ("sdfsdf" "sdfsdf" "sdfsdf" "sdfsdf") ("sdfsdf" "sdfsdf" "sdfsdf" "sdfsdf")) (10 108.0 156.75) (41 . 156.0) (42 . 42.75) (-1 (0 . "C12") (7 . "Arial") (40 . 12.0) (62 . 256) (72 . 9) (420 . 16711935)))
- (vlxls-cell-get-prop *xlapp* “B8”) è((0 . "B8") (1 . "sdg") (10 54.0 99.75) (41 . 54.0) (42 . 14.25) (-1 (0 . "B8") (7 . "Arial") (40 . 12.0) (62 . 256) (72 . 10) (420 . 16711935)))
- Name
- (vlxls-cell-border ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Force to draw or hide 4 slim border to certain Excel cells.
- Input
- VLOBJ
- STR/LIST
- BOOLEAN
- Flag to draw border line or NOT, T for draw, NIL for disable
- RetVal
- True
- BOOLEAN
- NIL
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-border (xl id flg / bdr)
- (if flg
- (msxl-put-value
- (msxl-get-borders
- (msxl-get-range xl id)
- 1
- (msxl-put-value
- (msxl-get-borders
- 'linestyle
- msxl-xlnone
- Examples:
- (vlxls-cell-border *xlapp* “C12:F14” T) èNIL
- (vlxls-cell-border *xlapp* “B8” NIL) èNIL
- Name
- (vlxls-cell-merge ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Run cell merge in Excel. Only 1st un-empty value will be left in merged cell.
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- VLOBJ
- New merged cell range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-merge (xl id / vllist-explode Val Rtn)
- (cond
- ((not lst) nil)
- (setq val (vllist-explode (vlxls-cell-get-value xl id)))
- (while (vl-position "" val)
- (setq val (vl-remove "" val))
- (setq val (car val)
- Rtn (msxl-get-range xl id)
- (msxl-clear Rtn)
- (msxl-merge Rtn nil)
- (msxl-put-value2 Rtn Val)
- (msxl-put-HorizontalAlignment Rtn -4108)
- Rtn
- Examples:
- (vlxls-cell-merge *xlapp* “C12:F14”) è#<VLA-OBJECT Range 0023ab7c>
- Name
- (vlxls-cell-unmerge ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Run cell unmerge in Excel. merged value will be placed into the left upper cell, others will be empty.
- If given Cell ID is not a valid merged cell, return NIL
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- VLOBJ
- All unmerged cells range vla-object
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-unmerge (xl id / Rtn)
- (progn
- (vlax-invoke-method (msxl-get-range xl id) 'unmerge)
- Rtn
- Examples:
- (vlxls-cell-unmerge *xlapp* “C12:F14”) è#<VLA-OBJECT Range 0023ab7c>
- (vlxls-cell-unmerge *xlapp* “E14”) è#<VLA-OBJECT Range 09ce72e4>
- Name
- (vlxls-cell-merge-p ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Check if the certain Excel cell is merged
- Input
- VLOBJ
- STR/LIST
- RetVal
- True
- BOOLEAN
- T
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-merge-p (xl id)
- (msxl-get-mergecells (msxl-get-range xl id))
- :vlax-true
- Examples:
- (vlxls-cell-merge-p *xlapp* “C12:F14”) èT
- (vlxls-cell-merge-p *xlapp* “E14”) èNIL
- Name
- (vlxls-cell-get-mergeid ExcelSessionVLA-OBJECT CellIDString)
- Usage
- Get the Left-Upper and Right-Lower Cell ID of a merged cell.
- Input
- VLOBJ
- STR/LIST
- Any Cell ID list or string of a merged cell
- RetVal
- True
- STRING
- A string contain Left-Upper and Right-Lower cells’ ID
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-cell-get-mergeid (XL ID / Rtn)
- (progn
- (msxl-select (msxl-get-range xl id))
- (setq Rtn (vlxls-range-getid (msxl-get-selection xl)))
- Rtn
- Examples:
- (vlxls-cell-get-mergeid *xlapp* “C12:F14”) è”B9:G19”
- (vlxls-cell-get-mergeid *xlapp* “E14”) è”A11:G19”
- Name
- (vlxls-range-getid RangeObject)
- Usage
- Get the Left-Upper and Right-Lower Cell ID of a range object.
- Input
- VLOBJ
- RetVal
- True
- STRING
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-range-getID (range / col row dx dy)
- (setq dx (vlxls-get-property range "MergeArea.Rows.Count")
- dy (vlxls-get-property range "MergeArea.Columns.Count")
- row (vlxls-get-property range "MergeArea.Row")
- col (vlxls-get-property range "MergeArea.Column")
- (strcat (vlxls-rangeid (list col row))
- (vlxls-rangeid (list (1- (+ col dy)) (1- (+ row dx))))
- Examples:
- (vlxls-range-getid RangeObject) è”C12:G19”
- (vlxls-range-getid RangeObject) è”B16:B16”
- Name
- (vlxls-range-size RangeObject)
- Usage
- Get the column width and row height list of a range object.
- Input
- VLOBJ
- RetVal
- True
- STRING
- A list contain two sub-list, each sub-list contain real number of columns' width and rows' height. Syuntax:
- ((Column1Width Column2Width…)(Row1Height Row2Height…))
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-range-size (range / xl row col rrr ccc xxx yyy)
- (setq xl (msxl-get-parent range)
- Row (msxl-get-count (msxl-get-rows Range))
- Col (msxl-get-count (msxl-get-columns Range))
- RRR (1- (msxl-get-row Range))
- CCC (msxl-get-column Range)
- (repeat Row
- (setq
- yyy (cons (vlax-variant-value
- (msxl-get-height
- (msxl-get-range
- xl
- (vlxls-rangeid (list CCC (setq RRR (1+ RRR))))
- yyy
- (setq RRR (msxl-get-row Range)
- CCC (1- (msxl-get-column Range))
- (repeat Col
- (setq
- xxx (cons (vlax-variant-value
- (msxl-get-width
- (msxl-get-range
- xl
- (vlxls-rangeid (list (setq CCC (1+ CCC)) RRR))
- xxx
- (list (reverse xxx) (reverse yyy))
- Examples:
- (vlxls-range-size RangeObject) è ((27.0 27.0 110.25 51.0 69.75) (14.25 14.25 14.25 14.25 14.25 57.0 14.25))
- Name
- (vlxls-rangevalue->safearray RangeValueList)
- Usage
- Convert a Range-Value-List into safearray list so that they can be passed into Excel directly.
- VLXLS defined a Range-Value-List as a dot-paired list contain two elements: 1st for Cell ID, 2nd for the cell content. Example for Range-Value-List may be ‘(("A1" . "aaa")("A2" . "SDA")...("C12" . "ccc"))
- Because Range-Value-List may NOT cover all Cell IDs, this function will automatically fill the undefined cells with "" so that the return variant can be send to Excel directly.
- Input
- VLOBJ
- RetVal
- True
- STRING
- A safearray variant contain all given Range-Value-List
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-Rangevalue->SafeArray (Data / XSub_GetXY
- XSub_GetMinMaxID
- xsub-MergeID->List MinID
- MaxID ID ID1
- ID2 IDN X
- minid xy Y
- Rtn Item
- (Defun xsub-MergeID->List (ID / KK ID1 ID2 IDX IDY Rtn)
- (Setq ID (strcase ID))
- (if (setq KK (vl-string-search ":" ID))
- (setq ID1 (substr ID 1 KK)
- ID2 (substr ID (+ 2 KK))
- (setq ID1 ID
- ID2 ID
- (setq ID1 (vlxls-rangeid ID1)
- ID2 (vlxls-rangeid ID2)
- IDX (vlxls-rangeid
- (list (min (nth 0 ID1) (nth 0 ID2))
- (min (nth 1 ID1) (nth 1 ID2))
- IDY
- (vlxls-rangeid
- (list (max (nth 0 ID1) (nth 0 ID2))
- (max (nth 1 ID1) (nth 1 ID2))
- Rtn (list IDX IDY)
- Rtn
- (Defun XSub_GetXY (ID SID / S10 S11 DX DY Rtn)
- (setq S10 (nth 0 MinID)
- S11 (nth 1 MinID)
- ID (vlxls-rangeid ID)
- DX (- (nth 0 ID) S10)
- DY (- (nth 1 ID) S11)
- Rtn (list DX DY)
- Rtn
- (Defun XSub_GetMinMaxID (ID1 ID MinorMax / X Y X1 Y1 Rtn)
- (if (null ID)
- (setq Rtn ID1)
- (progn
- X1 (nth 0 ID1)
- Y1 (nth 1 ID1)
- X (nth 0 ID)
- Y (nth 1 ID)
- (if (null MinorMax)
- (setq Rtn (vlxls-rangeid (list (min X X1) (min Y Y1))))
- (setq Rtn (vlxls-rangeid (list (max X X1) (max Y Y1))))
- Rtn
- (foreach Item Data
- (setq ID (strcase (car Item)))
- (if (vl-string-search ":" ID)
- (setq IDN (xsub-MergeID->List ID))
- (setq IDN (list ID))
- (foreach ID IDN
- (setq MinID (XSub_GetMinMaxID ID MinID nil)
- MaxID (XSub_GetMinMaxID ID MaxID T)
- (setq MinID (vlxls-rangeid MinID)
- MaxID (vlxls-rangeid MaxID)
- X (- (nth 0 MaxID) (nth 0 MinID))
- Y (- (nth 1 MaxID) (nth 1 MinID))
- Rtn (vlax-make-safearray
- vlax-vbstring
- (cons 0 Y)
- (cons 1 (1+ X))
- (foreach ID IDN
- (setq XY (XSub_GetXY ID MinID))
- (vlax-safearray-put-element
- Rtn
- (nth 1 XY)
- (1+ (nth 0 XY))
- (cdr Item)
- Rtn
- Examples:
- (vlxls-rangevalue->safearray ‘((“A1” . “aaa”)(“B4” . “ccc”))) è#<safearray...>
- (vlxls-variant->list (vlxls-rangevalue->safearray '(("A1" . "aaa")("B4" . "ccc"))))è(("aaa" "") ("" "") ("" "") ("" "ccc"))
- Public Function
- Name
- (vlxls-get-property TopVLAObject NestPropertyString)
- Usage
- Get the property of a nested VLA-Object from the main top vla-object. Use same property indicator as VBA.
- Input
- VLOBJ
- The Top vla-object
- STRING
- The Property combination string, divided with “.”, ordered from top to inner.
- RetVal
- True
- ANY
- The value of the most nested property.
- Fail
- BOOLEAN
- NIL
- (Defun vlxls-get-property (top prop / vlstring->list item Rtn)
- (Defun vlstring->list (str st / lst e)
- (setq str (strcat str st))
- (while (vl-string-search st str)
- (setq
- lst
- (append lst (list (substr str 1 (vl-string-search st str))))
- (setq
- str
- (substr str (+ (1+ (strlen st)) (vl-string-search st str)))
- (if lst
- (mapcar '(lambda (e) (vl-string-trim " " e)) lst)
- (cond ((= (type prop) 'sym)
- (setq Rtn (vlax-get-property top prop))
- ((= (type prop) 'str)
- (if (null (vl-string-search "." prop))
- (foreach item (vlstring->list prop ".")
- (if (null Rtn)
- (setq Rtn (vlax-get-property top item))
- (setq Rtn (vlax-get-property Rtn item))
- (cond ((= (type Rtn) 'variant)
- (setq Rtn (vlax-variant-value Rtn))
- ((= (type Rtn) 'safearray)
- (setq Rtn (vlxls-variant->list Rtn))
- Rtn
- Examples:
- (vlxls-get-property RangeObject “Application.ActiveSheet.Name”) è”Sheet1”
- (vlxls-get-property RangeObject “MergeArea.Columns.Count”) è3
- Following is the pre-define part of VLXLS project, VLXLS need a global variable named as *xls-color* to contain all color matching list. Syntax as (ECI ACI TrueColor), sorted as ECI number.
- As VLXLS support two languages: English as international and Simplified Chinese as local. In Default, VLXLS will go to seek if global variable *Chinese* is true, if so, VLXLS will prompt Chinese, or VLXLS will display English as default.
- (setq *xls-color*
- (list (list 1 18 0)
- (list 2 7 1677215)
- (list 3 1 16711680)
- (list 4 3 65280)
- (list 5 5 255)
- (list 6 2 16776960)
- (list 7 6 16711935)
- (list 8 4 65535)
- (list 9 16 8323072)
- (list 10 96 32512)
- (list 11 176 127)
- (list 12 56 8355584)
- (list 13 216 8323199)
- (list 14 136 32639)
- (list 15 9 12566463)
- (list 16 8 8355711)
- (list 17 161 9476095)
- (list 18 237 9449568)
- (list 19 7 1677167)
- (list 20 254 12648447)
- (list 21 218 6291552)
- (list 22 11 16744319)
- (list 23 152 24768)
- (list 24 254 13617407)
- (list 25 176 127)
- (list 26 6 16711935)
- (list 27 2 16776960)
- (list 28 4 65535)
- (list 29 216 8323199)
- (list 30 16 8323072)
- (list 31 136 32639)
- (list 32 5 255)
- (list 33 140 51455)
- (list 34 254 12648447)
- (list 35 254 13631439)
- (list 36 51 16777104)
- (list 37 151 9488639)
- (list 38 221 16750799)
- (list 39 191 13605119)
- (list 40 31 16763024)
- (list 41 150 3105023)
- (list 42 132 3131584)
- (list 43 62 9488384)
- (list 44 40 16762880)
- (list 45 30 16750336)
- (list 46 30 16738048)
- (list 47 165 6317968)
- (list 48 252 9475984)
- (list 49 148 12384)
- (list 50 105 3184736)
- (list 51 98 12032)
- (list 52 48 3158016)
- (list 53 24 9449472)
- (list 54 237 9449311)
- (list 55 177 3158160)
- (list 56 250 3092527)
- *Chinese* t
- (if vl-load-com
- (vl-load-com)
- (if vl-arx-import
- (foreach item '(ACAD_COLORDLG ACAD_truecolordlg
- ACAD_STRLSORT INITDIA
- ACAD-POP-DBMOD ACAD-PUSH-DBMOD
- STARTAPP layoutlist
- (vl-arx-import item)
- (setq item nil
- *xls-ver* "1.2.50331"
- ;|(princ
- (strcat "n VLAE:VLXLS Freebie API Version " *xls-ver*)
- (princ
- "n Copyright(C) 1994-2005 KozMos Inc. All rights reserved"
- ;(princ)
- (defun vlxls-ScreenUpdating-Off (*xlapp*)
- (vlax-put-property *xlapp* 'ScreenUpdating 0))
- (defun vlxls-ScreenUpdating-On (*xlapp*)
- (vlax-put-property *xlapp* 'ScreenUpdating -1))
- ;;; 模塊: vlxls-Excel-ColumnWidth
- ;;; 描述: 調整寬度col為width
- ;;; 參數: sheet (object)
- ;;; 示例: (vlxls-Excel-ColumnWidth xlapp 2 12);;調整B欄寬為12
- (defun vlxls-ColumnWidth(xlapp col width / sheet cell)
- (setq sheet (vlax-get-property xlapp "ActiveSheet"))
- (vlax-put-property (setq cell (vlxls-get-cell sheet 1 col)) "ColumnWidth"
- width)
- ;;; 模塊: mSX-Excel-RowHeight
- ;;; 描述: 調整列高row為height
- ;;; 示例: (mSX-Excel-ColumnWidth xlapp 3 15);;調整3列高為15
- (defun vlxls-RowHeight(xlapp row height / sheet cell)
- (vlax-put-property (setq cell (vlxls-get-cell sheet row 1)) "RowHeight"
- height)
- (defun vlxls-get-cell (obj row col / item cells)
- (setq item (vlax-get-property
- (setq cells (vlax-get-property obj "Cells"))
- "Item"
- (vlax-make-variant row)
- (vlax-make-variant col)))
- (vlax-release-object cells)
- (vlax-variant-value item))
- (defun vlxls-put-pagesetup(xlapp top bot lef rig hea fot flh flv);;設置版面
- (setq page (vlax-get-property sheet "pagesetup"))
- (vlax-put-property page "footermargin" (* fot 28.3465))
- (vlax-put-property page "headermargin" (* hea 28.3465))
- (vlax-put-property page "leftmargin" (* lef 28.3465))
- (vlax-put-property page "rightmargin" (* 28.3465 rig))
- (vlax-put-property page "topmargin" (* top 28.3465))
- (vlax-put-property page "bottommargin" (* bot 28.3465))
- (vlax-put-property page "CenterHorizontally" (* 28.3465 flh))
- (vlax-put-property page "CenterVertically" (* flv 28.3465))
- ;;; 模塊: vlxls-Excel-cellfontname
- ;;; 描述: 更改單元格字體
- ;;; 參數: row col name
- ;;; 示例: (vlxls-Excel-cellfontname 2 3 "新細明體");;更改單元格C2字體為"新細明體"
- (defun vlxls-Excel-cellfontname(xlapp row col name / sheet cell)
- (vlax-put-property(vlax-get-property (setq cell (msx-get-cell sheet row col)) "font"
- ) "name" name
- ;;; 模塊: vlxls-Excel-cellcolor
- ;;; 描述: 更改單元格顏色
- ;;; 參數: row col color
- ;;; 示例: (vlxls-Excel-cellcolor2 3 14);;更改單元格C2為14號色
- (defun vlxls-Excel-cellcolor(xlapp row col color / sheet cell)
- (setq cell (vlxls-get-cell sheet row col))
- (msxl-put-ColorIndex (msxl-get-Interior cell) color))
- ;;; 模塊: vlxls-Excel-textcolor
- ;;; 描述: 更改單元格文字顏色
- ;;; 示例: (vlxls-Excel-textcolor 2 3 14);;更改單元格C2文字為14號色
- (defun vlxls-Excel-textcolor(xlapp row col color / sheet cell)
- (vlax-put-property (vlax-get-property cell "font") "ColorIndex" color))
- ;;; 模塊: vlxls-Excel-textsize
- ;;; 描述: 更改單元格文字大小
- ;;; 參數: row col size
- ;;; 示例: (vlxls-Excel-textsize 2 3 18);;更改單元格C2文字為18號字大小
- (defun vlxls-Excel-textsize(xlapp row col size / sheet cell)
- (vlax-put-property (vlax-get-property cell "font") "Size" size))
- ;;; 模塊: vlxls-Excel-textunderline
- ;;; 描述: 更改單元格文字下畫線
- ;;; 示例: (vlxls-Excel-textunderline 2 3 1);;更改單元格C2文字無下划線
- (defun vlxls-Excel-textunderline(xlapp row col underline / sheet cell)
- (vlax-put-property (vlax-get-property cell "font") "Underline" underline))
- ;;;;;注: underline 1---------無下划線
- ;;;;; 2---------單線
- ;;;;; 3---------雙線
- ;;;;; 4---------會計用單線
- ;;;;; 5---------會計用雙線
- ;;; 模塊: vlxls-Excel-fontstyle
- ;;; 描述: 更改單元格文字形式
- ;;; 示例: (vlxls-Excel-fontstyle 2 3 "粗體");;更改單元格C2文字為14粗體
- (defun vlxls-Excel-fontstyle(xlapp row col style / sheet cell)
- (vlax-put-property (vlax-get-property cell "font") "FontStyle" style))
- ;;; 模塊: vlxls-Excel-fontspecial
- ;;; 描述: 更改單元格文字特殊效果
- ;;; 示例: (vlxls-Excel-fontspecial 2 3 "Strikethrough" item);;更改單元格C2文字特殊效果為刪線
- ;;; "Superscript"為上標 "Subscript" 為下標 (item設置為0則停用,-1為啟用)
- (defun vlxls-Excel-fontspecial(xlapp row col special item / sheet cell)
- (vlax-put-property (vlax-get-property cell "font") special item))
- ;;; 模塊: vlxls-Excel-textAlignment
- ;;; 描述: 更改單元格文字對齊方式
- ;;; 參數: row col color hal val
- ;;; 示例: (vlxls-Excel-textAlignment 2 3 1 -4108);;更改單元格C2文字對齊方式水平方向一般﹐垂直置中
- (defun vlxls-Excel-textAlignment (xlapp row col hal val / sheet cell)
- (vlax-put-property cell "HorizontalAlignment" hal)
- (vlax-put-property cell "VerticalAlignment" val))
- ;;;注:水平方式 1 ----------一般
- ;;;;;;;;; -4131----------左縮排 ;;;;或2
- ;;;;;;;;; -4108----------置中對齊 ;;或3
- ;;;;;;;;; -4152----------靠右對齊 ;;或4
- ;;;;;;;;; 5 ----------填滿 ;;或5
- ;;;;;;;;; -4130----------水平對齊 ;;或6
- ;;;;;;;;; 7----------跨欄置中
- ;;;;;;;;; -4117----------分散對齊 ;;或8
- ;;;注:垂直方式 -4160 ----------靠上 或1
- ;;;;;;;;; -4108----------置中對齊 或2
- ;;;;;;;;; -4107----------靠下 或3
- ;;;;;;;;; -4130----------垂直對齊 或4
- ;;;;;;;;; -4117 ----------分散對齊 或5
- ;;;页面设置
- ;;;(vlxls-Excel-Pagesetup *xlApp* ".LeftFooter" "&P")
- ;;;具体设置参考如下
- ActiveWindow.SelectedSheets.HPageBreaks.Add Before:=ActiveCell 插入分页符
- With ActiveSheet.PageSetup
- .PrintTitleRows = "$1:$3" 工作表顶端标题行
- .PrintTitleColumns = "" 工作表左端标题列
- End With
- ActiveSheet.PageSetup.PrintArea = "$C$1:$H$255" 工作表打印区域
- .LeftHeader = "" 左页眉
- .CenterHeader = "" 中页眉
- .RightHeader = "" 右页眉
- .LeftFooter = "&P" 左页脚
- .CenterFooter = "&N" 中页脚
- .RightFooter = "aaaaaaaaa" 右页脚
- .LeftMargin = Application.InchesToPoints(0.62) 左边距
- .RightMargin = Application.InchesToPoints(0.748031496062992) 右边距
- .TopMargin = Application.InchesToPoints(0.984251968503937)
- .BottomMargin = Application.InchesToPoints(0.393700787401575)
- .HeaderMargin = Application.InchesToPoints(0.511811023622047)
- .FooterMargin = Application.InchesToPoints(0.511811023622047)
- .PrintHeadings = False
- .PrintGridlines = False
- .PrintComments = xlPrintNoComments
- .CenterHorizontally = False
- .CenterVertically = False
- .Orientation = xlPortrait
- .Draft = False
- .PaperSize = xlPaperA4
- .FirstPageNumber = xlAutomatic 打印起始页
- .Order = xlDownThenOver
- .BlackAndWhite = False
- .Zoom = 100
- .PrintErrors = xlPrintErrorsDisplayed
- End With
- End Sub
- (defun vlxls-Excel-Pagesetup (xlapp Key var / sheet PageSetup)
- (setq PageSetup (vlax-get-property sheet "PageSetup"))
- (vlax-put-property PageSetup Key var)
- ;;; ActiveWindow.SelectedSheets.HPageBreaks.Add Before:=ActiveCell
- ;;;在单元格ID 之前插入分页符
- (defun vlxls-Excel-InsertHPageBreaks (xlapp id / sheet HPageBreaks HPageBreaks)
- (setq HPageBreaks (vlax-get-property sheet "HPageBreaks"))
- (vlxls-cell-put-active xlapp id)
- (vlax-invoke-method HPageBreaks 'Add (vlax-get-property xlapp "Activecell"))
