查看: 1584|回复: 0
[【PyCAD】] PYCAD复制excel内容进行查找文本
发表于 2022-4-12 09:26:33 | 显示全部楼层 |阅读模式
# -*- coding: utf-8 -*
import re
import clr
from pycad.runtime import *
from pycad.system import *
clr.AddReference('System.Windows.Forms')
from System.Windows.Forms import Clipboard
fd_str = ""
@command()
def fd(doc):
    with dbtrans(doc) as tr:
        global fd_str
        res =edx.getstr("请输入查找文字 ")
        if not res.ok: return
        str0=res.value
        if str0 == "":
            str0=fd_str
        pa= "^\s*|\s*$"
        str0=re.sub(pa, "", str0, count=0, flags=0)
        print(str0)
        fd_str = str0
        ss_list=[]
        ss = edx.ssget_x((0, '*text'))
        if ss.ok():
            for ssi in ss:
                txt=tr.getobject(ssi.ObjectId)
                with upopen(txt):
                    if isinstance(txt, acdb.DBText):
                        str1 = txt.TextString
                    elif isinstance(txt, acdb.MText):
                        str1 = txt.Text
                if not re.match(str0 , str1, re.I) is None:
                   ss_list.append(ssi.ObjectId)
        edx.sssetfirst(tuple(ss_list))
@command()
def ff(doc):
        str0 = Clipboard.GetText()
        if not str0:
            print("剪贴板为空")
        else:
            Clipboard.Clear()
            pa= "^\s*|\s*$"
            print(str0)
            Clipboard.SetText(str0)
            ss_list=[]
            if ss.ok():
                for ssi in ss:
                    with upopen(txt):
                            str1 = txt.Text
                    if not re.match(str0 , str1,re.IGNORECASE) is None:
GMT+8, 2025-5-1 07:55 , Processed in 0.154396 second(s), 22 queries , Gzip On.
