帖子
查看: 2719|回复: 2
求个小程序
发表于 2022-4-7 15:24:41 | 显示全部楼层 |阅读模式
      求个铝材挤压比的程序,请大师留步帮个忙,具体在附件里!先谢!先谢!
发表于 2022-12-30 17:02:35 | 显示全部楼层
什么挤压比,看看
发表于 2023-3-24 14:11:30 | 显示全部楼层
路过,随手写的lsp,保存为*.lsp文件加载到CAD试试看
  1. (defun c:tt(/ bjing en mj mzhong zc zjing zl)(vl-load-com)
  2.   (setq  zjing(getint "-->输入铝棒直径:")bjing(* zjing 0.5) mzhong(rtos(* pi bjing bjing 0.0027)2 3))
  3.   (setq en(Vlax-Ename->Vla-Object(car(entsel "-->点选封闭图形:"))))
  4.   (setq mj(vlax-get en 'area) zc(rtos(vlax-get en 'length)2 3))
  5.   (setq zl(rtos(* mj 0.0027)2 3))
  6.   (princ"\n所选型材参数信息如下:")
  7.   (princ(strcat "\n型材周长:" zc "mm"))
  8.   (princ(strcat "\n截面积:"  (rtos mj 2 3) "mm2"))
  9.   (princ(strcat "\n型材米重:" zl "kg/m"))
  10.   (princ(strcat "\n铝棒米重"(rtos bjing 2 2)"*"(rtos bjing 2 2)"*"(rtos pi 2 2)"*0.0027=" mzhong "kg/m"))
  11.   (princ(strcat "\n挤压比为=" mzhong "/" zl "="(rtos(/(atof mzhong)(atof zl))2 2)))
  12.   (princ)
  13. )
GMT+8, 2025-6-6 16:46 , Processed in 0.169008 second(s), 25 queries , Gzip On.
