查看: 36297|回复: 119
[2023] Autodesk 2023 全系列产品持续更新中
发表于 2022-3-29 22:59:13 | 显示全部楼层 |阅读模式
x64 | Language:English | File Size: 3.60 GB
Description
Autodesk AutoCAD 2023 design and documentation software, of the world’s leading 2D and 3D CAD tools. It will allow you to design and shape the world around you using its powerful and flexible features. Speed documentation, share ideas seamlessly, and explore ideas more intuitively in 3D. With thousands of available add-ons, AutoCAD software provides the ultimate in flexibility, customized for your specific needs. It’s time to take design further.
AutoCAD 2023 enables you to create and explore ideas like never before. It is all you need to create, visualize, document, and share your ideas. From conceptual design through drafting and detailing.
Import a wide variety of other formats including SolidWorks, Pro/ENGINEER, CATIA, Rhino, and NX. Drawing views, edge display, and location are instantly updated when an engineering change is made.
System requirements
OS:Microsoft Windows 10 (64-bit only) (version 1803 or higher)
CPU:Basic:2.5–2.9 GHz processor / Recommended:3+ GHz processor
Multiple processors:Supported by the application
RAM:8 GB / Recommended: 16 GB
Display Resolution
Conventional Displays:1920 x 1080 with True Color
High Resolution & 4K Displays:Resolutions up to 3840 x 2160 supported on Windows 10, 64-bit systems (with capable display card)
Disk space:6.0 GB
百度网盘下载地址:
链接:https://pan.baidu.com/s/1ea877LEEZ6_bG1cUsjAlCA
提取码:mjtd
PJ文件网盘下载地址:链接:https://pan.baidu.com/s/1BFKqEf0GE3tuAp3FrgidsQ
提取码:mjtd
Autodesk 2023 系列产品正式版下载链接(持续更新,欢迎分享增加……)
AutoCAD_2023_Simplified_Chinese_Win_64bit
https://efulfillment.autodesk.co ... dlm_001_002.sfx.exe
https://efulfillment.autodesk.co ... dlm_002_002.sfx.exe
Autodesk AutoCAD 2023 官方繁體中文版完整离线安装包
http://dds.autodesk.com/NetSWDLD ... dlm_001_002.sfx.exe
http://dds.autodesk.com/NetSWDLD ... dlm_002_002.sfx.exe
Autodesk AutoCAD LT 2023 官方繁體中文版完整离线安装包
http://dds.autodesk.com/NetSWDLD ... n_64bit_dlm.sfx.exe
AutoCAD_2023_English_Win_64bit
https://dds.autodesk.com/NetSWDL ... dlm_001_002.sfx.exe
https://dds.autodesk.com/NetSWDL ... dlm_002_002.sfx.exe
AutoCAD for Mac 2023
https://dds.autodesk.com/NetSWDL ... oCAD_2023_macOS.dmg
AutoCAD LT 2023
https://dds.autodesk.com/NetSWDL ... n_64bit_dlm.sfx.exe
AutoCAD LT for Mac 2023
https://dds.autodesk.com/NetSWDL ... D_LT_2023_macOS.dmg
AutoCAD Mechanical 2023 Simplified Chinese & English:
https://trial2.autodesk.com/NetS ... dlm_001_002.sfx.exe
https://trial2.autodesk.com/NetS ... dlm_002_002.sfx.exe
Autocad Electrical 2023 Simplified Chinese:
Autocad Electrical 2023 English:
https://efulfillment.autodesk.com/NetSWDLD/2023/ACAD_E/DE663064-1A7C-3129-832C-6D36950C3559/SFX/AutoCAD_Electrical_2023_English_Win_64bit_dlm_001_002.sfx.exe
https://efulfillment.autodesk.com/NetSWDLD/2023/ACAD_E/DE663064-1A7C-3129-832C-6D36950C3559/SFX/AutoCAD_Electrical_2023_English_Win_64bit_dlm_002_002.sfx.exe
Autocad Architecture 2023 English:
Autocad MEP 2023 Simplified Chinese & English:
https://efulfillment.autodesk.co ... dlm_001_003.sfx.exe
https://efulfillment.autodesk.co ... dlm_002_003.sfx.exe
https://efulfillment.autodesk.co ... dlm_003_003.sfx.exe
AutoCAD Plant 3D 2023 Simplified Chinese & English:
Autodesk Inventor Professional 2023 Simplified Chinese
https://dds.autodesk.com/NetSWDL ... Dlm_001_003.sfx.exe
https://dds.autodesk.com/NetSWDL ... Dlm_002_003.sfx.exe
https://dds.autodesk.com/NetSWDL ... Dlm_003_003.sfx.exe
Autodesk 3ds Max 2023 Simplified Chinese
https://dds.autodesk.com/NetSWDL ... bit_001_004.sfx.exe
https://dds.autodesk.com/NetSWDL ... bit_002_004.sfx.exe
https://dds.autodesk.com/NetSWDL ... bit_003_004.sfx.exe
https://dds.autodesk.com/NetSWDL ... bit_004_004.sfx.exe
Autodesk Maya 2023
Autodesk Navisworks 2023 Simplified Chinese
https://trial2.autodesk.com/NetSWDLD/2023/NAVMAN/54026284-5924-352E-895D-2DAE5162F3DE/SFX/Autodesk_Navisworks_Manage_2023_Win_64bit_dlm_001_002.sfx.exe
https://trial2.autodesk.com/NetSWDLD/2023/NAVMAN/54026284-5924-352E-895D-2DAE5162F3DE/SFX/Autodesk_Navisworks_Manage_2023_Win_64bit_dlm_002_002.sfx.exe
Autodesk Revit 2023 多国语言完整离线安装包
https://trial2.autodesk.com/NetS ... dlm_001_005.sfx.exe
https://trial2.autodesk.com/NetS ... dlm_002_005.sfx.exe
https://trial2.autodesk.com/NetS ... dlm_003_005.sfx.exe
https://trial2.autodesk.com/NetS ... dlm_004_005.sfx.exe
https://trial2.autodesk.com/NetS ... dlm_005_005.sfx.exe
Autodesk Civil 3D 2023 Simplified Chinese & Traditional Chinese & English
参与人数 2明经币 +2 收起 理由
asen + 1 神马都是浮云
hkzhq + 1 神马都是浮云
发表于 2022-4-13 13:57:44 | 显示全部楼层
wgldragon 发表于 2022-4-12 15:58
多谢反馈,已更新!
自动桌子2023下载地址大全
回复 支持 2 反对 0
 楼主| 发表于 2022-4-6 19:29:38 | 显示全部楼层
Mazco123 发表于 2022-4-4 13:48
AutoCAD Mechanical 2023这个有中文版吗
AutoCAD Mechanical 2023中文版已增加!
发表于 2022-3-30 22:29:32 | 显示全部楼层
hszt 发表于 2022-3-30 21:47
安装2023之后可以单独卸载许可证管理器不?然后重新安装2022。2023硬解,2022批量授权。
可否?
可以,只要2023不装别的产品就行了
发表于 2022-3-30 00:07:35 | 显示全部楼层
帮助文件(简体中文):
https://help.autodesk.com/view/ACD/2023/CHS/
AutoCAD 2023 中的新增功能(简体中文):
https://help.autodesk.com/view/A ... 2-99EB-A97EFDCEE8C6
AutoCAD2023 的系统要求,包括专用工具集
System requirements for AutoCAD |AutoCAD | Autodesk Knowledge Network 【英文】
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-AutoCAD.html
AutoCAD 系统要求 |AutoCAD | Autodesk Knowledge Network  【简体中文】
https://knowledge.autodesk.com/zh-hans/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/CHS/System-requirements-for-AutoCAD.html
AutoCAD 系统要求 | AutoCAD | Autodesk Knowledge Network  https://knowledge.autodesk.com/z ... ts-for-AutoCAD.html
AutoCAD 2023 including Specialized Toolsets(专业化工具组合)系统要求
Support
2022 年 3 月 31 日
准备好开始了吗?
下载免费试用版
立即购买
AutoCAD 2023(包括专用工具集)系统要求 (Windows)
操作系统64 位 Microsoft Windows 11Windows 10 版本 1809 或更高版本。有关支持信息,请参见 Autodesk 的产品支持生命周期
处理器基本要求:2.5–2.9 GHz 处理器(基础版),ARM 处理器不受支持。
建议:3+ GHz 处理器(基础版),4+ GHz(Turbo 版)
内存基本要求:8 GB
建议:16 GB
显示器分辨率传统显示器:
1920 x 1080 真彩色显示器
高分辨率和 4K 显示器:
支持高达 3840 x 2160 的分辨率(使用支持的显卡)
显卡基本要求:1 GB GPU,具有 29 GB/s 带宽,与 DirectX 11 兼容
建议:4 GB GPU,具有 106 GB/s 带宽,与 DirectX 12 兼容
磁盘空间10.0 GB(建议使用 SSD)
网络请参见Autodesk Network License Manager for Windows
指针设备Microsoft 鼠标兼容的指针设备
.NET Framework.NET Framework 版本 4.8 或更高版本
AutoCAD 2023 for Mac 系统要求
操作系统Apple macOS Monterey v12
Apple macOS Big Sur v11
Apple macOS Catalina v10.15
模型基本要求:Apple Mac Pro 4.1、MacBook Pro 5.1、iMac 8.1、Mac mini 3.1、MacBook Air、MacBook 5.1
建议:支持 Metal Graphics Engine 的 Apple Mac 型号
在 Rosetta 2 模式下支持带有 M 系列芯片的 Apple Mac 型号。
CPU 类型64 位 Intel CPU
Apple M 系列 CPU
内存基本要求:4 GB
建议:8 GB 或更大
显示器分辨率基本要求:1280 x 800 显示器
高分辨率:2880 x 1800 Retina 显示器
磁盘空间5 GB 可用磁盘空间(用于下载和安装)
指针设备Apple 兼容的鼠标、Apple 兼容的触控板、Microsoft 兼容的鼠标
显卡建议:Mac 本地安装的显卡
磁盘格式APFS、APFS(加密)、Mac OS Extended(日志)、Mac OS Extended(日志,加密)
[td]
大型数据集、点云和三维建模的其他要求
内存16 GB 或更大 RAM1
磁盘空间6 GB 可用硬盘空间(不包括安装所需的空间)
显卡3840 x 2160 (4K) 或更高的真彩色视频显示适配器;8 GB VRAM 或更多;Pixel Shader 3.0 或更高版本;支持 DirectX 的工作站级显卡。
专业化工具组合(仅限 Windows)
工具组合其他要求
AutoCAD Map 3D磁盘空间:20 GB
内存:16 GB
数据库和 FDO 要求(请参见下文)
AutoCAD Electrical磁盘空间:20 GB
Microsoft Access Database Engine 2016 Redistributable (x64) (16.0.5044.1000) 或更高版本
AutoCAD Architecture磁盘空间:20 GB
内存:16 GB
AutoCAD MEP磁盘空间:21 GB
内存:16 GB
AutoCAD Plant 3D磁盘空间:12 GB
AutoCAD Mechanical磁盘空间:12 GB
AutoCAD Raster Design磁盘空间:1 GB
AutoCAD Map 3D 附加要求(仅限 Windows)
FDO Provider 要求
FDO Provider已认证的版本注释
Microsoft SQL ServerMicrosoft SQL Server 2017 标准版和企业版
Microsoft SQL Server 2019 标准版和企业版
行业模型也支持左侧列出的 Microsoft SQL Server 版本。
Oracle 12c Release 2Oracle 12.2.0.1.0
Standard Edition 和 Enterprise Edition
行业模型支持与左侧所列相同的 Oracle 版本。
Oracle 18cOracle 18.3
Enterprise Edition 和 Standard Edition 2
Oracle 19cOracle 19.3
Oracle 21cOracle 21.3
企业版和标准版 2
光栅DEM、JPG2K、DTED、MrSID、ECW、PNG、ESRI Grid、TIFF、JPEG、ESRIASCII
SDF3.0
ESRI ArcGISArcGIS 10.8.1
ArcGIS 10.7.1
ArcGIS 10.6.1
此提供程序要求在装有 Map 3D 的系统上安装 ESRI 许可的组件 (ArcGIS Engine/ArcGIS Desktop)。
MySQL8.0
ODBCFDO ODBC 提供程序已经过测试,带有相应版本的 ODBC 驱动程序(随相关的支持操作系统版本提供)。
OGC WMSWMS 1.3.0
OGC WMTSWMS 1.0.0
OGC WFSWFS 2.0.0
SQLiteSQLite 3.27.2
PostgresSQLPostgreSQL 13.5 + PostGIS 3.0
[td]
ODBC 驱动程序测试的版本
Microsoft Access 驱动程序(*.mdb、*.accdb)Microsoft Access 数据库引擎 2016(英语)16.00.4999.1000
Microsoft Excel 驱动程序(*.xls、*xlsx、*.xlsm、*.xlsb)Microsoft Access 数据库引擎 2016(英语)16.00.4999.1000
MySQL ODBC 8.0 驱动程序8.00.27.00
SQL Server10.00.19041.01
OraClient21Home1 中的 Oracle21.00.00.00
注意:并非所有 Autodesk 产品都可以虚拟化。仅当规定对该产品的访问和使用的适用条款和条件明确允许虚拟化时,才可以虚拟化产品。在得到授权进行虚拟化的情况下,适用条款和条件中指定的所有条件和限制均适用。Autodesk 可能会提供有关在虚拟化环境中使用产品的信息。此类信息的提供仅出于方便您使用的目的,按“原样”提供,可能包含错误、不准确、不完整的信息。Autodesk 不会做出与在任何虚拟化环境中或采用任何虚拟化技术使用任何产品有关的任何陈述、保证或其他承诺。如果您得到授权进行虚拟化并选择这样做,则需承担与此类使用相关的所有风险,包括但不限于产品与第三方虚拟化技术和/或您的虚拟化环境之间的不兼容性。阅读使用条款以了解更多信息。另请参见:AutoCAD 认证硬件 - 使用此工具查找推荐的显卡硬件和驱动程序。Autodesk 为许多 Autodesk 产品测试了显卡硬件和驱动程序。请注意,并非所有 Autodesk 产品都参与显卡硬件认证。AutoCAD 认证硬件常见问题解答
这是机器翻译:
涵盖的产品和版本
经过: file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png
支持
2022 3 31
分享 添加到收藏准备好开始了吗?
下载免费试用版
立即购买
[td]
   AutoCAD 2023 的系统要求,包括专用工具集 (Windows)
  操作系统
  64 位 Microsoft  Windows 11 Windows 10 版本 1809 或更高版本。有关支持信息,请参见 Autodesk 的产品支持生命周期
  处理器
  基本:2.5–2.9 GHz 处理器(基本),不支持 ARM 处理器。
  推荐:3+ GHz 处理器(基本),4+  GHz(睿频)
  内存
  基本:8 GB
  推荐:16 GB
  显示屏分辨率
  传统显示器:
  1920 x 1080 真彩色
  高分辨率和 4K 显示器:
  分辨率高达 3840 x 2160 分辨率(使用功能强大的显卡)
  显示卡
  基本:1 GB GPU,29 GB/s 带宽和 DirectX 11 兼容
  推荐:4 GB GPU,106 GB/s 带宽和 DirectX 12 兼容
  磁盘空间
  10.0 GB(建议使用 SSD)
  网络
  请参见适用于 Windows 的 Autodesk Network License Manager
  指点设备
  兼容 MS 鼠标
  .NET 框架
  .NET Framework 4.8 或更高版本
发表于 2022-3-30 00:16:34 | 显示全部楼层
AutoCAD 2023 帮助 |AutoCAD 2023 中的新增功能 | Autodesk  https://help.autodesk.com/view/ACD/2023/CHS/?guid=GUID-C6EC4B39-2588-43A2-99EB-A97EFDCEE8C6
AutoCAD2023 中的新增功能
了解此版本的AutoCAD 2023 中的新增功能。有关技术详细信息,请参见发行说明
亮点新功能概述(视频)
标记输入和标记辅助
我的见解:宏指导工具
跟踪
计数
浮动图形窗口
三维图形
二维图形显示
Autodesk Docs 的图纸集管理器
“图形”和“布局”选项卡
CUTBASE
多段线延伸
MLEADER 增强功能
其他增强功能
插入块:“块重定义”对话框提供了一个选项,可用于在图形中已存在指定块名称的情况下重命名块。
选项对话框:尝试关闭或取消“选项”对话框时,新任务对话框会提示您保存或放弃所做的更改。
隔离模式:退出隔离模式时,对象选择现在会保持不变。
新建图形:将光标悬停在“开始”选项卡上的“新建”下拉列表上时,系统会显示工具提示(其中包含将使用的图形模板文件的名称)。
客户错误报告(CER):现在,当生成错误报告时,系统会自动填写您的电子邮件地址。
多核后台发布:现在,当使用后台发布功能发布多页 PDF 文件时,支持“包含超链接”发布选项。
相关概念此信息是否有用?
发表于 2022-3-29 23:28:25 | 显示全部楼层
上图了
本体版本号是T.53.0.0。安装包根目录大小是1.5G。
2022的去共享按钮补丁不支持2023,但新补丁已经做出来了。除了本体以外所有组件可以精简。
 楼主| 发表于 2022-3-29 23:31:18 | 显示全部楼层
大佬神速!!!
 楼主| 发表于 2022-3-29 23:34:28 | 显示全部楼层
我下载完就赶紧给大伙分享上来了,还没来得及尝鲜呢!
发表于 2022-3-29 23:36:23 | 显示全部楼层
厉害了我的哥
发表于 2022-3-29 23:37:50 | 显示全部楼层
你这收费挡了一大片,还是等中文版的吧
 楼主| 发表于 2022-3-29 23:39:39 | 显示全部楼层
dalong6371451 发表于 2022-3-29 23:37
你这收费挡了一大片,还是等中文版的吧
哈哈,我花了90个币从SDbeta上搬过来的,先收几个币,请理解~
发表于 2022-3-29 23:44:40 | 显示全部楼层
不知道中文版什么时候出来?
发表于 2022-3-29 23:47:37 | 显示全部楼层
不错,期待珊瑚海大佬出手
 楼主| 发表于 2022-3-29 23:54:30 | 显示全部楼层
mokson 发表于 2022-3-29 23:44
不知道中文版什么时候出来?
中文版估计得晚个三五天,个把星期吧~
GMT+8, 2025-7-15 07:26 , Processed in 0.246361 second(s), 29 queries , Gzip On.
