查看: 1378|回复: 6
workingdatabase 获取指针失败
发表于 2022-2-17 17:38:01 | 显示全部楼层 |阅读模式
通过com 读取Excel 数据,根据数据在cad画图。
1.读取Excel数据,成功。2.添加图块成功 3.添加图层失败,在workingdatabase 获取指针失败。先是锁定文档,添加图层,再解除锁定。没有报错。在第3步,先锁定文档,再获取workingdatabase指针失败。提示access violation reading .请各位大佬不吝赐教
 楼主| 发表于 2022-2-18 15:45:01 | 显示全部楼层
现在把读excle 注释掉,先添加图层,再添加图块,调试进入获取workingdatabase2失败,db=00000000000000000,
static void addlayerblock()   // 添加图层
        ErrorStatus es;
        AcDbDatabase *db = NULL;
        acDocManager->lockDocument(acDocManager->curDocument());
        AcDbLayerTable *playerTable = NULL;
        if (!(db = acdbHostApplicationServices()->workingDatabase()))
                acutPrintf(L"获取workingdata1失败");
delete db;
                return;
        if (Acad::eOk != (es = db->getSymbolTable(playerTable, AcDb::kForWrite)))
                return;
        if (!(playerTable->has(L"轮廓线")))
                AcDbLayerTableRecord *playerTableR = new AcDbLayerTableRecord;
                playerTableR->setName(L"轮廓线");
                AcCmColor col;
                col.setColorIndex(255);
                playerTableR->setColor(col);
                playerTable->add(playerTableR);
                playerTableR->close();
        playerTable->close();
        delete db;
        acDocManager->unlockDocument(acDocManager->curDocument());
static void makeBlock()  // 添加图块
        ErrorStatus es;
        acDocManager->lockDocument(acDocManager->mdiActiveDocument());
        AcGeVector3d nrm(0, 0, 1);
        AcDbBlockTable *blockt = NULL;
                acutPrintf(L"获取workingdata2失败");
                return;
        if (Acad::eOk != (es = db->getBlockTable(playerTable, AcDb::kForWrite)))
                acutPrintf(L"获取getBlockTable失败");
                return;
        if (!(blockt->has(L"mM2")))   //添加M2螺纹孔
                AcDbBlockTableRecord *ptblR = new AcDbBlockTableRecord;
                ptblR->setName(L"mM2");
                AcDbObjectId pid;
                blockt->add(pid, ptblR);
                AcGePoint3d ce(1.25, 0, 0);
                AcGePoint3d p(0, 0, 0);
                AcGePoint3d p0(2.5, 0, 0);
                AcDbLine *pl1 = new AcDbLine(p, p0);
                pl1->setLayer(L"中心线");
                ptblR->appendAcDbEntity(pid, pl1);
                ptblR->setOrigin(ce);
                pl1->close();
                ptblR->close();
        blockt->close();
发表于 2022-2-18 16:16:36 | 显示全部楼层
直接写
AcDbDatabase* db = acdbHostApplicationServices()->workingDatabase();
非要
    return;
自己给自己难受!
 楼主| 发表于 2022-2-18 16:31:25 | 显示全部楼层
gzxl 发表于 2022-2-18 16:16
直接写
非要
改成您这种方法,db依然是0,空指针,我查到非模态对话框,获取空指针,改进后使用了锁定文档,但是好像不管用啊
发表于 2022-2-18 16:38:47 | 显示全部楼层
QQ群:630401507
 楼主| 发表于 2022-2-22 16:57:15 | 显示全部楼层
自己收个尾,在用com 读取Excel时候,选取了多文档模式,导致锁存文档的混乱问题
发表于 2022-3-8 10:04:32 | 显示全部楼层
直接写
非要
您好 可以把里程标注的插件发我试用下吗 我的邮箱:
GMT+8, 2025-5-1 03:12 , Processed in 0.180009 second(s), 24 queries , Gzip On.
