查看: 2036|回复: 9
沙漠骆驼工具箱源码-3快速选择
发表于 2022-2-9 15:31:16 | 显示全部楼层 |阅读模式
文本操作1,界面和代码如下:
1 界面:
2代码如下:
Dim layerobj As AcadLayer
Dim filtertype() As Integer '定义选择过滤器类型的dsf组码, 动态数组
Dim filterdata() As Variant '定义过滤器的值,为动态数组
Dim selectobjname As String '确定选择对象名称
Dim selectlayername As String '确定选择图层名称
Dim selectcolor As Integer    '确定选择颜色0-256
Dim selectblockname As String '确定选择块名称
Dim selectwidth As Double   '确定选择宽度
Dim syscolor As String    '系统变量 当前颜色值 0~256
Private Sub CheckBox1_Click()  '列出当前所有图层
    ComboBox1.Enabled = CheckBox1.value
    ComboBox1.Clear
    For Each layerobj In ThisDrawing.Layers
        ComboBox1.AddItem Trim(layerobj.name)
    Next
    ComboBox1.Text = ComboBox1.List(0)
    If CheckBox1.value = True Then selectlayername = "0"
End Sub
Private Sub CheckBox2_Click() '获取当前模型空间颜色 0-256 颜色索引值
    If CheckBox2.value = True Then
        syscolor = ThisDrawing.GetVariable("cecolor")
        ThisDrawing.SendCommand "color "
        Label1.Caption = ThisDrawing.GetVariable("cecolor")
        selectcolor = ThisDrawing.GetVariable("cecolor")
        If LCase(selectcolor) = "bylayer" Then selectcolor = 256
        If LCase(selectcolor) = "byblock" Then selectcolor = 0
    End If
End Sub
Private Sub CheckBox3_Click()   '列出当前所有图块名称 ,默认情况下0-2 是一个模型加两个布局
    ComboBox3.Enabled = CheckBox3.value
    ComboBox3.Clear
    Dim str As String
    Dim i As Integer, j As Integer
    For i = 0 To ThisDrawing.Blocks.count - 1
        str = Left(ThisDrawing.Blocks.Item(i).name, 1)
        If str = "*" Then j = j + 1
    Next
    For i = j To ThisDrawing.Blocks.count - 1
        ComboBox3.AddItem ThisDrawing.Blocks.Item(i).name
    Next
    If ComboBox3.ListCount > 0 Then
        ComboBox3.Text = ComboBox3.List(0)
        selectblockname = ComboBox3.List(0)
    Else
        selectblockname = ""
        CheckBox3.value = False
        ComboBox3.Enabled = False
    End If
End Sub
Private Sub CheckBox4_Click()
    ComboBox4.Enabled = CheckBox4.value
    If CheckBox4.value = True Then selectwidth = ComboBox4.Text
End Sub
Private Sub ComboBox1_Click()
    selectlayername = ComboBox1.Text
End Sub
Private Sub ComboBox3_Click()
    selectblockname = ComboBox3.Text
End Sub
Private Sub ComboBox4_Click()
End Sub
Private Sub CommandButton1_Click()
    Me.Hide
    If selectobjname = "block" Then '选择块,排除多线,
        If CheckBox1.value = False And CheckBox2.value = False And CheckBox3.value = False Then
'            ReDim filtertype(4) '全关闭 选择所有块
'            ReDim filterdata(4)
'            filtertype(0) = 2
'            filterdata(0) = "*"
'            filtertype(1) = -4
'            filterdata(1) = "<not"
'            filtertype(2) = 0
'            filterdata(2) = "hatch"
'            filtertype(3) = 0
'            filterdata(3) = "mline"
'            filtertype(4) = -4
'            filterdata(4) = "not>"
            Call createssetfilter(filtertype, filterdata, 0, "insert")
        ElseIf CheckBox1.value = True And CheckBox2.value = True And CheckBox3.value = True Then
            ReDim filtertype(2)  '图层,颜色,块名 全打开
            ReDim filterdata(2)
            filtertype(0) = 2
            filterdata(0) = selectblockname
            filtertype(1) = 8
            filterdata(1) = selectlayername
            filtertype(2) = 62
            filterdata(2) = selectcolor
        ElseIf CheckBox1.value = True And CheckBox2.value = False And CheckBox3.value = False Then
'            ReDim filtertype(4)   '图层打开
'            filtertype(0) = 2
'            filtertype(1) = 8
'            filterdata(1) = selectlayername
'            filtertype(2) = -4
'            filterdata(2) = "<not"
'            filtertype(3) = 0
'            filterdata(3) = "hatch"
            Call createssetfilter(filtertype, filterdata, 0, "insert", 8, selectlayername)
        ElseIf CheckBox1.value = False And CheckBox2.value = True And CheckBox3.value = False Then
'            ReDim filtertype(4)      '颜色打开
'            filtertype(0) = 2
'            filtertype(1) = 62
'            filterdata(1) = selectcolor
'            filtertype(3) = 0
            Call createssetfilter(filtertype, filterdata, 0, "insert", 62, selectcolor)
        ElseIf CheckBox1.value = False And CheckBox2.value = False And CheckBox3.value = True Then
            ReDim filtertype(0)     '块名打开
            ReDim filterdata(0)
            filtertype(0) = 2
        ElseIf CheckBox1.value = True And CheckBox2.value = True And CheckBox3.value = False Then
'            ReDim filtertype(5)     '图层打开,颜色打开
'            ReDim filterdata(5)
'            filtertype(0) = 2
'            filtertype(1) = 8
'            filtertype(2) = 62
'            filterdata(2) = selectcolor
'            filtertype(3) = -4
'            filterdata(3) = "<not"
'            filtertype(4) = 0
'            filterdata(4) = "hatch"
'            filtertype(5) = -4
'            filterdata(5) = "not>"
            Call createssetfilter(filtertype, filterdata, 0, "insert", 8, selectlayername, 62, selectcolor)
        ElseIf CheckBox1.value = True And CheckBox2.value = False And CheckBox3.value = True Then
            ReDim filtertype(1)    '图层打开,块名打开
            ReDim filterdata(1)
            filtertype(0) = 2
            filtertype(1) = 8
        ElseIf CheckBox1.value = False And CheckBox2.value = True And CheckBox3.value = True Then
            ReDim filtertype(1)    '颜色打开,块名打开
            ReDim filterdata(1)
            filtertype(0) = 2
            filtertype(1) = 62
        End If
    ElseIf selectobjname = "lwpolyline" Then   '选择多段线
        If CheckBox1.value = False And CheckBox2.value = False And CheckBox4.value = False Then
            ReDim filtertype(3) '全关闭 选择所有多段线ok
            ReDim filterdata(3)
            filtertype(0) = -4
            filterdata(0) = "<or"
            filtertype(1) = 0
            filterdata(1) = "lwpolyline"
            filtertype(2) = 0
            filterdata(2) = "POLYLINE"
            filtertype(3) = -4
            filterdata(3) = "or>"
        ElseIf CheckBox1.value = True And CheckBox2.value = True And CheckBox4.value = True Then
            ReDim filtertype(3)   '图层,颜色,宽度 全打开 ok
            ReDim filterdata(3)
            filtertype(0) = 0
            filterdata(0) = selectobjname
            filtertype(1) = 8
            filtertype(2) = 62
            filtertype(3) = 43
            filterdata(3) = selectwidth
        ElseIf CheckBox1.value = True And CheckBox2.value = False And CheckBox4.value = False Then
            ReDim filtertype(4)     '图层打开 ok
            ReDim filterdata(4)
            filtertype(0) = -4
            filtertype(1) = 0
            filtertype(2) = 0
            filtertype(3) = -4
            filtertype(4) = 8
            filterdata(4) = selectlayername
        ElseIf CheckBox1.value = False And CheckBox2.value = True And CheckBox4.value = False Then
            ReDim filtertype(4)      '颜色打开 ok
            ReDim filterdata(4)
            filtertype(0) = -4
            filtertype(1) = 0
            filtertype(2) = 0
            filtertype(3) = -4
            filtertype(4) = 62
            filterdata(4) = selectcolor
        ElseIf CheckBox1.value = False And CheckBox2.value = False And CheckBox4.value = True Then
            ReDim filtertype(1)       '宽度打开 ok
            ReDim filterdata(1)
            filtertype(0) = 0
            filtertype(1) = 43
            filterdata(1) = selectwidth
        ElseIf CheckBox1.value = True And CheckBox2.value = True And CheckBox4.value = False Then
            ReDim filtertype(5)     '图层打开,颜色打开 ok
            ReDim filterdata(5)
            filtertype(0) = -4
            filtertype(1) = 0
            filtertype(2) = 0
            filtertype(3) = -4
            filtertype(4) = 8
            filtertype(5) = 62
            filterdata(5) = selectcolor
        ElseIf CheckBox1.value = True And CheckBox2.value = False And CheckBox4.value = True Then
            ReDim filtertype(2)    '图层打开,宽度打开ok
            ReDim filterdata(2)
            filtertype(0) = 0
            filtertype(1) = 8
            filtertype(2) = 43
            filterdata(2) = selectwidth
        ElseIf CheckBox1.value = False And CheckBox2.value = True And CheckBox4.value = True Then
            ReDim filtertype(2)    '颜色打开,宽度打开ok
            ReDim filterdata(2)
            filtertype(0) = 0
            filtertype(1) = 62
            filtertype(2) = 43
        End If
    Else       '选择text,mtext ,point ,circle,dimension,hatch
        If CheckBox1.value = False And CheckBox2.value = False Then
            ReDim filtertype(0) '图层,颜色全关闭 选择所有
            ReDim filterdata(0)
            filtertype(0) = 0
        ElseIf CheckBox1.value = True And CheckBox2.value = True Then
            ReDim filtertype(2)   '图层,颜色 全打开
            ReDim filterdata(2)
            filtertype(0) = 0
            filtertype(1) = 8
            filtertype(2) = 62
        ElseIf CheckBox1.value = True And CheckBox2.value = False Then
            ReDim filtertype(1)   '图层 打开
            ReDim filterdata(1)
            filtertype(0) = 0
            filtertype(1) = 8
        ElseIf CheckBox1.value = False And CheckBox2.value = True Then
            ReDim filtertype(1)   '颜色 打开
            ReDim filterdata(1)
            filtertype(0) = 0
            filtertype(1) = 62
        End If
    End If
    Call selectobjprograme(filtertype, filterdata)
    Erase filtertype
    Erase filterdata
    ThisDrawing.SetVariable "cecolor", syscolor
    Me.show
End Sub
Private Sub CommandButton2_Click()
    Me.Hide
End Sub
Private Sub Image1_Click()
    Image1.BackColor = cirobj.color
End Sub
Private Sub CommandButton3_Click()
    MsgBox "时间:2011年11月19日    " & vbCr & _
           "名称:快速选择 V1.0    " & vbCr & _
           "by  :沙漠骆驼    " & vbCr & _
           "qq  :549738552    " & vbCr & vbCr & _
           "当前时间:" & Now, vbInformation, "快速选择--by沙漠骆驼"
End Sub
Private Sub Label1_Click()
        If LCase(selectcolor) = "bylayer" Then selectcolor = "256"
        If LCase(selectcolor) = "byblock" Then selectcolor = "0"
    End If
End Sub
Private Sub OptionButton1_Click()
    CheckBox3.Enabled = False
    CheckBox4.Enabled = False
    selectobjname = "text"
End Sub
Private Sub OptionButton2_Click()
    selectobjname = "mtext"
End Sub
Private Sub OptionButton3_Click()
    selectobjname = "circle"
End Sub
Private Sub OptionButton4_Click()
    selectobjname = "point"
End Sub
Private Sub OptionButton5_Click()
    CheckBox4.Enabled = True
End Sub
Private Sub OptionButton6_Click()
    selectobjname = "dimension"
End Sub
Private Sub OptionButton7_Click()
    CheckBox3.Enabled = True
End Sub
Private Sub OptionButton8_Click()
    selectobjname = "hatch"
End Sub
Private Sub UserForm_Initialize()
    '初始化 当前图层 当前颜色 多段线宽度
    'On Error Resume Next
    ComboBox1.Text = ThisDrawing.Layers.Item(0).name
    Dim i As Integer
    For i = 0 To 39
        ComboBox4.AddItem Format((i + 1) * 0.05, "0.00"), i
    Next
    ComboBox4.AddItem Format(2.5, "0.00")
    ComboBox4.AddItem Format(3, "0.00")
    ComboBox4.Text = ComboBox4.List(2)
    syscolor = "256"
End Sub
'条件选择过滤器函数,以夹点方式显示选择集
Private Sub selectobjprograme(filtertype() As Integer, filterdata() As Variant)
    Dim sset1 As AcadSelectionSet
    Dim element As AcadEntity
    Set sset1 = ThisDrawing.SelectionSets.Add("ss1")
    If Err.Number <> 0 Then
        Err.Clear
        Set sset1 = ThisDrawing.SelectionSets.Item("ss1")
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请选择对象:")
    sset1.SelectOnScreen filtertype, filterdata
    If sset1.count = 0 Then
        ThisDrawing.Utility.prompt "-------选择失败-------by沙漠骆驼-------" & vbCrLf
        ThisDrawing.Utility.prompt "-------请重新选择过滤条件进行选择-------" & vbCrLf
        Exit Sub
    End If
    ThisDrawing.SetVariable "nomutt", 1
    With ThisDrawing
        .SendCommand "(setq ss1 (ssget ""p""))" '命令行(setq ss1 (ssget "p"))
        .SendCommand "(sssetfirst nil ss1)" & vbCr
        .Utility.prompt "正在选择......" & vbCrLf
    End With
    ThisDrawing.SetVariable "NOMUTT", 0
    ThisDrawing.Utility.prompt "-------选择成功-------by沙漠骆驼-------" & vbCrLf
    ThisDrawing.Utility.prompt "一共选择了  " & sset1.count & "  个对象。" & vbCrLf
    sset1.Clear
    sset1.Delete
End Sub
发表于 2023-2-13 14:29:38 | 显示全部楼层
如果能有lisp代码那就好了。谢谢楼主分享啊。
发表于 2022-2-11 20:04:44 来自手机 | 显示全部楼层
怎么没人支持这么好的源码
发表于 2022-4-24 11:36:29 | 显示全部楼层
可以同时选择多个图层吗?
发表于 2022-4-24 18:58:37 | 显示全部楼层
看不懂,先留个脚印
发表于 2022-5-2 18:21:31 | 显示全部楼层
支持一下VBA
发表于 2022-5-2 19:12:35 | 显示全部楼层
感谢分享代码,学习了,一直用lisp,对这个不是太了解
发表于 3 天前 | 显示全部楼层
要是lsp就好了
可以用贱人工具箱  发表于 3 天前
发表于 前天 08:06 | 显示全部楼层
没有源码啊
GMT+8, 2025-4-30 21:01 , Processed in 0.384251 second(s), 26 queries , Gzip On.
