查看: 1261|回复: 2
沙漠骆驼工具箱源码-1文本相关-文本操作2
发表于 2022-2-8 15:40:27 | 显示全部楼层 |阅读模式
工具条:文本操作2,界面和代码如下:
1 界面:
2代码如下:
''''每个click事件的后面都注释了当前按钮的名称
Dim filtertype() As Integer '定义选择过滤器类型的dsf组码, 动态数组
Dim filterdata() As Variant '定义过滤器的值,为动态数组
Dim sset1 As AcadSelectionSet
Private Sub CommandButton14_Click() '数字批量增减
    Me.Hide
    On Error Resume Next
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filterdata(0) = "<or"
    filtertype(1) = 0
    filterdata(1) = "text"
    filtertype(2) = 0
    filterdata(2) = "mtext"
    filtertype(3) = -4
    filterdata(3) = "or>"
    Set sset1 = ThisDrawing.SelectionSets.Add("ss1")
    If Err.Number <> 0 Then
        Err.Clear
        Set sset1 = ThisDrawing.SelectionSets.Item("ss1")
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请框选数字文本:")
    sset1.SelectOnScreen filtertype, filterdata
    If sset1.count = 0 Then
        ThisDrawing.Utility.prompt "-------选择失败-------by沙漠骆驼-------" & vbCrLf
        Me.show
        Exit Sub
    End If
    Dim zengliang As Double
    zengliang = ThisDrawing.Utility.GetReal("请输入增量值(可以为负):")
    Dim wenben1 As AcadEntity
    Dim zifu As String
    Dim xiaoshuweishu As Integer '记录小数位数
    Dim changdu As Integer
    Dim geshi As String
    For Each wenben1 In sset1
        xiaoshuweishu = 0
        zifu = wenben1.textstring
        changdu = Len(zifu)
        For i = 1 To changdu
            If Left(Right(zifu, i), 1) = "." Then
                xiaoshuweishu = i
                Exit For
            End If
        Next
        zifu = Trim(str(Val(zifu) + zengliang))
        geshi = "0." & Right("000000000000000", xiaoshuweishu - 1)
        If xiaoshuweishu = 0 Then geshi = "0"
        wenben1.textstring = Format(zifu, geshi)
    Next
    Me.show
End Sub
Private Sub CommandButton15_Click() '数字批量乘除
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
        Me.show
        Exit Sub
    End If
    zengliang = 1
    zengliang = ThisDrawing.Utility.GetReal("请输入要乘的数(可以为负):")
    Dim zifu As String
    Dim geshi As String
        wenben1.textstring = zifu
    Next
    Me.show
End Sub
Private Sub CommandButton21_Click() '数字消零
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请点选或框选数字文本:")
        Me.show
        Exit Sub
    End If
    Dim i As Integer
    Dim zifu As String
        wenben1.textstring = Val(zifu)
    Next
    Me.show
End Sub
'计算角度  格式是弧度
Function angle(ByVal p1 As Variant, ByVal p2 As Variant) As Double
    angle = ThisDrawing.Utility.AngleFromXAxis(p1, p2)
End Function
Private Sub CommandButton22_Click() '求最大值和最小值
    Me.Hide
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filterdata(3) = "dimension"
    filtertype(4) = -4
    filterdata(4) = "or>"
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请框选要求最大最小值的文本:")
        Me.show
        Exit Sub
    End If
    Dim zuida As Double
    Dim zuixiao As Double
    Dim zigao As Double
    zuida = Val(sset1(0).textstring)
    zuixiao = zuida
        If wenben1.ObjectName <> "AcDbText" And wenben1.ObjectName <> "AcDbMText" Then
            'qiuhe = qiuhe + wenben1.Measurement '尺寸标注文本
            If wenben1.Measurement > zuida Then zuida = wenben1.Measurement
            If wenben1.Measurement < zuixiao Then zuixiao = wenben1.Measurement
            zigao = wenben1.TextHeight
        Else
            If Val(wenben1.textstring) > zuida Then zuida = Val(wenben1.textstring)
            If Val(wenben1.textstring) < zuixiao Then zuixiao = Val(wenben1.textstring)
            zigao = wenben1.height
        End If
    Next
    newtextstyle2    '调用新建字体样式程序
    ThisDrawing.SetVariable "textstyle", "wh_lkx"
    Dim ppt1 As Variant
    ppt1 = ThisDrawing.Utility.GetPoint(, "请拾取插入点:")
    'ThisDrawing.ModelSpace.AddText "最大值:" & Format(Trim(str(zuida)), "0.000") & _
      '                        "    最小值:" & Format(Trim(str(zuixiao)), "0.000"), ppt1, zigao
    ThisDrawing.ModelSpace.AddText "最大值:" & Format(zuida, "0.########") & _
                              "  最小值:" & Format(zuixiao, "0.########"), ppt1, zigao
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton23_Click() '文字求差
    Me.Hide
    Dim wenben2 As AcadEntity
    Dim basepnt As Variant
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filtertype(4) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt "请选择数字文本A(可以是标注):" & vbCrLf
        Me.show
        Exit Sub
    Else
        Set wenben1 = sset1.Item(0)
    End If
    sset1.Clear
    ThisDrawing.Utility.prompt "请选择数字文本B(可以是标注):" & vbCrLf
        Me.show
        Exit Sub
    Else
        Set wenben2 = sset1.Item(0)
    End If
    Dim shu1 As Double
    Dim shu2 As Double
    Dim chazhi As Double
    Dim zigao As Double
            shu1 = wenben1.Measurement
    Else
            shu1 = Val(wenben1.textstring)
    End If
    If wenben2.ObjectName <> "AcDbText" And wenben2.ObjectName <> "AcDbMText" Then
            shu2 = wenben2.Measurement
            zigao = wenben2.TextHeight
    Else
            shu2 = Val(wenben2.textstring)
            zigao = wenben2.height
    End If
    chazhi = shu1 - shu2
    Dim ppt1 As Variant
    Set qiuhetext = ThisDrawing.ModelSpace.AddText(Format(Trim(str(chazhi)), "0.000"), ppt1, zigao)
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton24_Click() '文字求商
    Me.Hide
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filtertype(4) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt "请选择数字文本A(可以使标注):" & vbCrLf
        Me.show
        Exit Sub
    Else
    End If
    sset1.Clear
    ThisDrawing.Utility.prompt "请选择数字文本B(可以使标注):" & vbCrLf
        Me.show
        Exit Sub
    Else
    End If
    Dim shu1 As Double
    Dim shu2 As Double
    Dim shangzhi As Double
    Dim zigao As Double
    Else
    End If
    Else
    End If
    If shu2 = 0 Then
        ThisDrawing.Utility.prompt "-------除数不能为 0 -------" & vbCrLf
        MsgBox "除数不能为 0", vbCritical
        Me.show
        Exit Sub
    End If
    shangzhi = shu1 / shu2
    Dim ppt1 As Variant
    Set qiuhetext = ThisDrawing.ModelSpace.AddText(Format(Trim(str(shangzhi)), "0.000"), ppt1, zigao)
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton25_Click() '求平均值
    Me.Hide
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filtertype(4) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请框选要求和的文本:")
        Me.show
        Exit Sub
    End If
    Dim qiuhe As Double
    Dim pingjunzhi As Double
    Dim zigao As Double
        Else
            qiuhe = qiuhe + Val(wenben1.textstring)
        End If
    Next
    pingjunzhi = qiuhe / sset1.count
    Dim qiuhetext As AcadText
    Dim ppt1 As Variant
    Set qiuhetext = ThisDrawing.ModelSpace.AddText(Format(Trim(str(pingjunzhi)), "0.00"), ppt1, zigao)
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton26_Click() '纯数字递增
    Me.Hide
    On Error GoTo eee1
    ThisDrawing.Utility.GetEntity wenben1, basepnt, "请选择纯数字文本(可以是小数):"
        Me.show
        Exit Sub
    End If
    Dim strtext As String
    strtext = wenben1.textstring
    Dim i As Integer
    For i = 1 To Len(strtext)
        If Left(Right(strtext, i), 1) = "." Then Exit For
    Next
    Dim xiaoshuoweishu As Integer
    If i < Len(strtext) Then
        xiaoshuoweishu = i
    Else
        xiaoshuoweishu = 0
    End If
    'MsgBox xiaoshuoweishu
    Dim geshi As String
    geshi = "0" & Left(".00000", xiaoshuoweishu) 'xiaoshuweishu 实际上多1位
    zengliang = ThisDrawing.Utility.GetReal("请输入增量值:")
    Dim shuliang As Integer
    shuliang = ThisDrawing.Utility.GetInteger("请输入复制个数(大于0):")
    Dim ppt1 As Variant
    Dim ppt2 As Variant
    Dim basepnt1 As Variant
    Dim basepnt2(0 To 2) As Double
    Dim ddx As Double, ddy As Double
    basepnt1 = wenben1.InsertionPoint
    Dim copyobj As AcadEntity
    ppt1 = ThisDrawing.Utility.GetPoint(, "请拾取第一点:")
    ppt2 = ThisDrawing.Utility.GetPoint(ppt1, "请拾取第二点:")
    ddx = ppt2(0) - ppt1(0)
    ddy = ppt2(1) - ppt1(1)
    For i = 1 To shuliang
        strtext = strtext + zengliang
        Set copyobj = wenben1.Copy()
        copyobj.textstring = Format(strtext, geshi)
        basepnt2(0) = basepnt1(0) + ddx * i
        basepnt2(1) = basepnt1(1) + ddy * i
        copyobj.Move basepnt1, basepnt2
    Next
    Me.show
eee1:
    Err.Clear
    Me.show
End Sub
Private Sub CommandButton27_Click() '修改小数位数
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
        Me.show
        Exit Sub
    End If
    xiaoshuweishu = 2
    xiaoshuweishu = Abs(ThisDrawing.Utility.GetInteger("请输入小数位数(默认2位):"))
    Dim zifu As Double
    Dim geshi As String
    geshi = "0." & Right("00000000", xiaoshuweishu)
        zifu = Val(wenben1.textstring)
        If wenben1.textstring = zifu Then
            'MsgBox "相同"
        End If
    Next
    Me.show
End Sub
Private Sub CommandButton6_Click() '递增复制
    Me.Hide
    On Error GoTo e1:
    ThisDrawing.Utility.GetEntity wenben1, basepnt, "请选择文本(末尾是数字):"
        Me.show
        Exit Sub
    End If
    'MsgBox wenben1.ObjectName
    strtext = Right(wenben1.textstring, 1)
    If Val(strtext) > 0 And Val(strtext) <= 9 Or strtext = "0" Then
        Dim i As Integer
        Dim j As Integer
        For i = 2 To Len(wenben1.textstring)
            strtext = Left(Right(wenben1.textstring, i), 1)
            If Val(strtext) > 0 And Val(strtext) <= 9 Or strtext = "0" Then j = j + 1
            If i > j + 1 Then Exit For
        Next
        j = j + 1
        Dim zengliang As Integer
        Dim chushizhi As Double
        zengliang = ThisDrawing.Utility.GetInteger("请输入增量值:")
    End If
    If j = 0 Then
        Me.show
        Exit Sub
    End If
r1:
    chushizhi = chushizhi + zengliang
    strtext = Left(wenben1.textstring, Len(wenben1.textstring) - j) & _
            Val(Right(wenben1.textstring, j)) + chushizhi
    basepnt1 = ThisDrawing.Utility.GetPoint(, "指定插入点:")
    copyobj.textstring = strtext
    copyobj.Move wenben1.InsertionPoint, basepnt1
    If copyobj.ObjectName = "AcDbText" Then
        copyobj.Alignment = acAlignmentMiddleCenter
        copyobj.TextAlignmentPoint = basepnt1
    Else
        copyobj.AttachmentPoint = acAttachmentPointMiddleCenter
        copyobj.InsertionPoint = basepnt1
    End If
e1:
        'MsgBox Err.Description
        Err.Clear
        Me.show
        Exit Sub
    Else
        GoTo r1
    End If
End Sub
Private Sub CommandButton7_Click() '超级递增(数在尾)
    Me.Hide
    On Error GoTo eee1
        Me.show
        Exit Sub
    End If
        Dim i As Integer
        Dim j As Integer
        Next
        j = j + 1
        Dim ppt1 As Variant
        Dim ppt2 As Variant
        'Dim juli As Double
        'juli = ((ppt2(0) - ppt1(0)) ^ 2 + (ppt2(1) - ppt1(1)) ^ 2) ^ 0.5 '* (ppt2(0) - ppt1(0)) / Abs(ppt2(0) - ppt1(0))
                    Val(Right(wenben1.textstring, j)) + zengliang * i
        Next
        Me.show
    End If
eee1:
    Err.Clear
    Me.show
End Sub
Private Sub CommandButton19_Click() '超级递增(数在头)
    Me.Hide
    On Error GoTo eee1
    ThisDrawing.Utility.GetEntity wenben1, basepnt, "请选择文本(文字开头是数字):"
        Me.show
        Exit Sub
    End If
    strtext = Left(wenben1.textstring, 1)
        Dim i As Integer
        Dim j As Integer
            strtext = Right(Left(wenben1.textstring, i), 1)
        Next
        j = j + 1
        'Dim juli As Double
        Dim ppt1 As Variant
        Dim ppt2 As Variant
            strtext = Val(Left(wenben1.textstring, j)) + zengliang * i & _
                      Right(wenben1.textstring, Len(wenben1.textstring) - j)
        Next
        Me.show
    End If
eee1:
    Err.Clear
    Me.show
End Sub
Private Sub CommandButton8_Click() '文字求和
    Me.Hide
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filtertype(4) = -4
        Err.Clear
        sset1.Clear
    End If
        Me.show
        Exit Sub
    End If
    Dim qiuhe As Double
    Dim zigao As Double
            qiuhe = qiuhe + wenben1.Measurement     '是标注文本
        Else
            qiuhe = qiuhe + Val(wenben1.textstring)  '单行或是多行文本         sset1.Item(0).textstring
        End If
    Next
    Dim ppt1 As Variant
    Set qiuhetext = ThisDrawing.ModelSpace.AddText(Format(Trim(str(qiuhe)), "0.000"), ppt1, zigao)
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton9_Click() '文字求积
    Me.Hide
    ReDim filtertype(4)
    ReDim filterdata(4)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = 0
    filtertype(4) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请框选要求积的文本:")
        Me.show
        Exit Sub
    End If
    Dim qiuji As Double
    qiuji = 1
    Dim zigao As Double
            qiuji = qiuji * wenben1.Measurement
        Else
            qiuji = qiuji * Val(wenben1.textstring)
        End If
    Next
    Dim qiujitext As AcadText
    Dim ppt1 As Variant
    Set qiujitext = ThisDrawing.ModelSpace.AddText(Format(Trim(str(qiuji)), "0.000"), ppt1, zigao)
    sset1.Clear
    Me.show
End Sub
Private Sub CommandButton10_Click() '数字改桩号
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
        Me.show
        Exit Sub
    End If
    'ThisDrawing.Utility.Prompt ("请输入保留的小数位数:") & vbCrLf
    xiaoshuweishu = ThisDrawing.Utility.GetInteger("请输入保留的小数位数:")
    Dim geshi As String
    geshi = "0+000." & Right("000000000000000", xiaoshuweishu)
    If xiaoshuweishu = 0 Then geshi = "0+000"
        wenben1.textstring = Format(wenben1.textstring, geshi)
    Next
    Me.show
End Sub
Private Sub CommandButton11_Click() '桩号批量增减
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
    ThisDrawing.Utility.prompt ("请点选或框选桩号:")
        Me.show
        Exit Sub
    End If
    zengliang = ThisDrawing.Utility.GetReal("请输入桩号增量值(可以为负):")
    Dim i As Integer
    Dim zifu As String
    Dim geshi As String
        xiaoshuweishu = 0
        changdu = Len(zifu)
            If Left(Right(zifu, i), 1) = "." Then xiaoshuweishu = i
            If Left(Right(zifu, i), 1) = "+" Then Exit For
        Next
        zifu = Left(wenben1.textstring, Len(wenben1.textstring) - i) & Right(wenben1.textstring, i - 1)
        wenben1.textstring = str(Val(zifu) + zengliang)
        geshi = "0+000." & Right("000000000000000", xiaoshuweishu - 1)
    Next
    Me.show
End Sub
Private Sub CommandButton12_Click() '桩号改数字
    Me.Hide
    ReDim filtertype(3)
    ReDim filterdata(3)
    filtertype(0) = -4
    filtertype(1) = 0
    filtertype(2) = 0
    filtertype(3) = -4
        Err.Clear
        sset1.Clear
    End If
        Me.show
        Exit Sub
    End If
    Dim i As Integer
    Dim zifu As String
        xiaoshuweishu = 0
        changdu = Len(zifu)
        Next
        wenben1.textstring = Val(Left(wenben1.textstring, Len(wenben1.textstring) - i) & Right(wenben1.textstring, i - 1))
    Next
    Me.show
End Sub
发表于 2022-10-13 15:22:01 | 显示全部楼层
刚注意,这是VBA的源码,收藏一下。
GMT+8, 2025-5-24 22:17 , Processed in 0.252214 second(s), 23 queries , Gzip On.
