查看: 1363|回复: 2
椭圆(弧)转多段线(非模拟)---
发表于 2021-12-23 14:23:52 | 显示全部楼层 |阅读模式
椭圆(弧)转换为多段线弧(非模拟
;; Arguments
;; lst : a list
;; start : start index (first item = 0)
;; leng : the sub list length (number of items) or nil
(defun sublist (lst start leng / n r)
  (if (or (not leng) (< (- (length lst) start) leng))
    (setq leng (- (length lst) start))
  (setq n (+ start leng))
  (while (< start n)
    (setq r (cons (nth (setq n (1- n)) lst) r))
;; EllipseToPolyline
;; Returns a polyline (vla-object) which is an approximation of the ellipse (or elliptical arc)
;; Argument : an ellipse (vla-object)
(defun EllipseToPolyline (el        /     cl    norm  cen        elv   pt0
                          pt1        pt2   pt3   pt4          ac0        ac4   a04
                          a02        a24   bsc0  bsc2  bsc3        bsc4  plst
                          blst        spt   spa   fspa  srat        ept   epa
                          fepa        erat  n
  (vl-load-com)
  (setq        cl   (=        (ang<2pi (vla-get-StartAngle el))
                (ang<2pi (vla-get-EndAngle el))
        norm (vlax-get el 'Normal)
        cen  (trans (vlax-get el 'Center) 0 norm)
        elv  (caddr cen)
        cen  (3dTo2dPt cen)
        pt0  (mapcar '+ (trans (vlax-get el 'MajorAxis) 0 norm) cen)
        ac0  (angle cen pt0)
        pt4  (mapcar '+ cen (trans (vlax-get el 'MinorAxis) 0 norm))
        pt2  (3dTo2dPt
               (trans (vlax-curve-getPointAtparam el (/ pi 4.)) 0 norm)
        ac4  (angle cen pt4)
        a04  (angle pt0 pt4)
        a02  (angle pt0 pt2)
        a24  (angle pt2 pt4)
        bsc0 (/ (ang<2pi (- a02 ac4)) 2.)
        bsc2 (/ (ang<2pi (- a04 a02)) 2.)
        bsc3 (/ (ang<2pi (- a24 a04)) 2.)
        bsc4 (/ (ang<2pi (- (+ ac0 pi) a24)) 2.)
        pt1  (inters pt0
                     (polar pt0 (+ ac0 (/ pi 2.) bsc0) 1.)
                     pt2
                     (polar pt2 (+ a02 bsc2) 1.)
                     nil
        pt3  (inters pt2
                     (polar pt2 (+ a04 bsc3) 1.)
                     pt4
                     (polar pt4 (+ a24 bsc4) 1.)
                     nil
        plst (list pt4 pt3 pt2 pt1 pt0)
        blst (mapcar '(lambda (b) (tan (/ b 2.)))
                     (list bsc4 bsc3 bsc2 bsc0)
  (foreach b blst (setq blst (cons b blst)))
  (foreach p (cdr plst)
    (setq ang  (angle cen p)
          plst (cons (polar cen (+ ang (* 2 (- ac4 ang))) (distance cen p))
                     plst
          plst (cons (polar cen (+ ang (* 2 (- ac0 ang))) (distance cen p))
                     plst
  (setq        pl (vlax-invoke
             (vla-get-ModelSpace
               (vla-get-ActiveDocument (vlax-get-acad-object))
             'AddLightWeightPolyline
             (apply 'append
                    (setq plst (reverse        (if cl
                                          (cdr plst)
                                          plst
  (vlax-put pl 'Normal norm)
  (vla-put-Elevation pl elv)
  (mapcar '(lambda (i v) (vla-SetBulge pl i v))
          '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16)
          blst
  (if cl
    (vla-put-Closed pl :vlax-true)
    (progn (setq spt  (vlax-curve-getClosestPointTo pl (vlax-get el 'Startpoint))
                 spa  (vlax-curve-getParamAtPoint pl spt)
                 fspa (fix spa)
                 ept  (vlax-curve-getClosestPointTo pl (vlax-get el 'Endpoint))
                 epa  (vlax-curve-getParamAtPoint pl ept)
                 fepa (fix epa)
                 n    0
           (cond ((equal spt (trans pt0 norm 0) 1e-9)
                  (if (= epa fepa)
                    (setq plst (sublist plst 0 (1+ fepa))
                          blst (sublist blst 0 (1+ fepa))
                    (setq erat (/ (- (vlax-curve-getDistAtParam pl epa)
                                     (vlax-curve-getDistAtParam pl fepa)
                                  (- (vlax-curve-getDistAtParam pl (rem (1+ fepa) 17))
                          plst (append (sublist plst 0 (1+ fepa))
                                       (list (3dTo2dPt (trans ept 0 norm)))
                          blst (append (sublist blst 0 (1+ fepa))
                                       (list (k*bulge (nth fepa blst) erat))
                 ((equal ept (trans pt0 norm 0) 1e-9)
                  (if (= spa fspa)
                    (setq plst (sublist plst fspa nil)
                          blst (sublist blst fspa nil)
                    (setq srat (/ (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17))
                                     (vlax-curve-getDistAtParam pl spa)
                                     (vlax-curve-getDistAtParam pl fspa)
                          plst (cons (3dTo2dPt (trans spt 0 norm))
                                     (sublist plst (1+ fspa) nil)
                          blst (cons (k*bulge (nth fspa blst) srat)
                                     (sublist blst (1+ fspa) nil)
                 (T
                  (if (< epa spa)
                    (setq plst (append (if (= spa fspa)
                                       (cdr (sublist plst 0 (1+ fepa)))
                                       (if (/= epa fepa)
                          blst (append (if (= spa fspa)
                                       (sublist blst 0 fepa)
                                       (if (= epa fepa)
                                         (list (nth fepa blst))
                                         (sublist plst fspa (1+ (- fepa fspa)))
                                               (sublist plst (1+ fspa) (- fepa fspa))
                                         (sublist blst fspa (- fepa fspa))
                                               (sublist blst (1+ fspa) (- fepa fspa))
                                       (if (= epa fepa)
           (vlax-put pl 'Coordinates (apply 'append plst))
           (foreach b blst (vla-SetBulge pl n b) (setq n (1+ n)))
  pl
;; Ang<2pi
;; Returns the angle expression betweem 0 and 2*pi
(defun ang<2pi (ang)
  (if (and (<= 0 ang) (< ang (* 2 pi)))
    ang
    (ang<2pi (rem (+ ang (* 2 pi)) (* 2 pi)))
;; 3dTo2dPt
;; Returns the 2d point (x y) of a 3d point (x y z)
(defun 3dTo2dPt (pt) (list (car pt) (cadr pt)))
;; Tan
;; Returns the angle tangent
(defun tan (a) (/ (sin a) (cos a)))
;; K*BULGE
;; Returns the proportinal bulge to the référence bulge
;; Arguments :
;; b : the bulge
;; k : the proportion ratio (between angles or arcs length)
(defun k*bulge (b k / a)
  (setq a (atan b))
  (/ (sin (* k a)) (cos (* k a)))
;; EL2PL
;; Converts ellipses and elliptcal arcs into polylines
(defun c:el2pl (/ *error* fra acdoc ss)
  (vl-load-com)
  (defun *error* (msg)
    (if        (and (/= msg "Fonction annulée")
             (/= msg "Function cancelled")
      (princ (strcat (if (= "FRA" (getvar 'locale))
                       "\nErreur: "
                       "\Error: "
                     msg
    (vla-endUndoMark acdoc)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (ssget '((0 . "ELLIPSE")))
    (progn (vla-StartUndoMark acdoc)
           (vlax-for e (setq ss (vla-get-ActiveSelectionSet acdoc))
             (EllipseToPolyline e)
             (vla-delete e)
           (vla-delete ss)
           (vla-EndUndoMark acdoc)
;; PELL
;; Draws an ellipse or an elliptical arc approximation (polyline) on the fly
(defun c:pell (/ *error* ec pe old ent)
  (vl-load-com)
    (if        (and msg
                       "\nErreur: "
                       "\Error: "
                     msg
    (setvar 'cmdecho ec)
    (setvar 'pellipse pe)
  (setq        ec  (getvar 'cmdecho)
        pe  (getvar 'pellipse)
        old (entlast)
  (setvar 'cmdecho 1)
  (setvar 'pellipse 0)
  (command "_.ellipse")
  (while (/= 0 (getvar 'cmdactive)) (command pause))
  (if (not (eq old (setq ent (entlast))))
    (progn (EllipseToPolyline (vlax-ename->vla-object ent))
           (entdel ent)
  (*error* nil)
tigcat + 1 很给力!
发表于 2021-12-23 19:37:33 | 显示全部楼层
经过实测,还是有点差别的
 楼主| 发表于 2021-12-23 19:40:33 | 显示全部楼层
tigcat 发表于 2021-12-23 19:37
经过实测,还是有点差别的
这是我在网上看到的源程序,这个程序,可以解决问题,本坛缺少这个。这个支持椭圆、椭圆弧。改写后我暂时采用。
  • ;; 椭圆(弧)转多段线(非直线模拟)----(一级)---------------
  • (defun arc->pline (enam / cl norm cen elv pt0 pt1 pt2 pt3 pt4 ac0 ac4 a04 a02 a24 bsc0 bsc2 bsc3 bsc4 plst
  •                     blst spt spa fspa srat ept epa fepa erat n obj
  •   ;; 角度正切值-----(一级)-------
  •   (defun tan (a) (/ (sin a) (cos a)))
  •   ;; b : the bulge
  •   ;; k : the proportion ratio (between angles or arcs length)
  •   (defun k*bulge (b k / a)
  •     (setq a (atan b))
  •     (/ (sin (* k a)) (cos (* k a)))
  •   ;; lst : a list
  •   ;; start : start index (first item = 0)
  •   ;; leng : the sub list length (number of items) or nil
  •   (defun sublist (lst start leng / n r)
  •     (if (or (not leng) (< (- (length lst) start) leng))
  •       (setq leng (- (length lst) start))
  •     (setq n (+ start leng))
  •     (while (< start n)
  •       (setq r (cons (nth (setq n (1- n)) lst) r))
  •   (if (= (type enam) 'ENAME) (setq obj (en2obj enam)))
  •   (setq cl (= (Angle-Mod (vla-get-StartAngle obj)) (Angle-Mod (vla-get-EndAngle obj)))
  •     norm (vlax-get obj 'Normal)
  •     cen  (trans (vlax-get obj 'Center) 0 norm)
  •     elv  (caddr cen)
  •     cen  (3dTo2dPt cen)
  •     pt0  (mapcar '+ (trans (vlax-get obj 'MajorAxis) 0 norm) cen)
  •     ac0  (angle cen pt0)
  •     pt4  (mapcar '+ cen (trans (vlax-get obj 'MinorAxis) 0 norm))
  •     pt2  (3dTo2dPt (trans (vlax-curve-getPointAtparam obj pi4) 0 norm))
  •     ac4  (angle cen pt4)
  •     a04  (angle pt0 pt4)
  •     a02  (angle pt0 pt2)
  •     a24  (angle pt2 pt4)
  •     bsc0 (* (Angle-Mod (- a02 ac4)) 0.5)
  •     bsc2 (* (Angle-Mod (- a04 a02)) 0.5)
  •     bsc3 (* (Angle-Mod (- a24 a04)) 0.5)
  •     bsc4 (* (Angle-Mod (- (+ ac0 pi) a24)) 0.5)
  •     pt1  (inters pt0
  •            (polar pt0 (+ ac0 pi2 bsc0) 1.)
  •            pt2
  •            (polar pt2 (+ a02 bsc2) 1.)
  •            nil
  •     pt3  (inters pt2
  •            (polar pt2 (+ a04 bsc3) 1.)
  •            pt4
  •            (polar pt4 (+ a24 bsc4) 1.)
  •            nil
  •     plst (list pt4 pt3 pt2 pt1 pt0)
  •     blst (mapcar '(lambda (b) (tan (* b 0.5))) (list bsc4 bsc3 bsc2 bsc0))
  •   (foreach b blst (setq blst (cons b blst)))
  •   (foreach p (cdr plst)
  •     (setq ang (angle cen p)
  •       plst (cons (polar cen (+ ang (* 2 (- ac4 ang))) (distance cen p)) plst)
  •       plst (cons (polar cen (+ ang (* 2 (- ac0 ang))) (distance cen p)) plst)
  •   (setq pl (vlax-invoke
  •              (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
  •              'AddLightWeightPolyline
  •              (apply 'append (setq plst (reverse (if cl (cdr plst) plst))))
  •   (vlax-put pl 'Normal norm)
  •   (vla-put-Elevation pl elv)
  •   (mapcar '(lambda (i v) (vla-SetBulge pl i v)) '(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16) blst)
  •   (if cl
  •     (vla-put-Closed pl :vlax-true)
  •     (progn
  •       (setq spt (vlax-curve-getClosestPointTo pl (vlax-get obj 'Startpoint))
  •         spa  (vlax-curve-getParamAtPoint pl spt)
  •         fspa (fix spa)
  •         ept  (vlax-curve-getClosestPointTo pl (vlax-get obj 'Endpoint))
  •         epa  (vlax-curve-getParamAtPoint pl ept)
  •         fepa (fix epa)
  •         n    0
  •       (cond
  •         ((equal spt (trans pt0 norm 0) 1e-9)
  •           (if (= epa fepa)
  •             (setq plst (sublist plst 0 (1+ fepa)) blst (sublist blst 0 (1+ fepa)))
  •             (setq erat (/ (- (vlax-curve-getDistAtParam pl epa) (vlax-curve-getDistAtParam pl fepa))
  •                          (- (vlax-curve-getDistAtParam pl (rem (1+ fepa) 17)) (vlax-curve-getDistAtParam pl fepa))
  •               plst (append (sublist plst 0 (1+ fepa)) (list (3dTo2dPt (trans ept 0 norm))))
  •               blst (append (sublist blst 0 (1+ fepa)) (list (k*bulge (nth fepa blst) erat)))
  •         ((equal ept (trans pt0 norm 0) 1e-9)
  •           (if (= spa fspa)
  •             (setq plst (sublist plst fspa nil)
  •               blst (sublist blst fspa nil)
  •             (setq srat (/ (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17))
  •                             (vlax-curve-getDistAtParam pl spa)
  •                          (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17))
  •                            (vlax-curve-getDistAtParam pl fspa)
  •               plst (cons (3dTo2dPt (trans spt 0 norm)) (sublist plst (1+ fspa) nil))
  •               blst (cons (k*bulge (nth fspa blst) srat) (sublist blst (1+ fspa) nil))
  •         (T
  •           (setq srat (/ (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17)) (vlax-curve-getDistAtParam pl spa))
  •                        (- (vlax-curve-getDistAtParam pl (rem (1+ fspa) 17)) (vlax-curve-getDistAtParam pl fspa))
  •             erat (/ (- (vlax-curve-getDistAtParam pl epa) (vlax-curve-getDistAtParam pl fepa))
  •           (if (< epa spa)
  •             (setq plst (append (if (= spa fspa)
  •                                  (sublist plst fspa nil)
  •                                  (cons (3dTo2dPt (trans spt 0 norm)) (sublist plst (1+ fspa) nil))
  •                          (cdr (sublist plst 0 (1+ fepa)))
  •                          (if (/= epa fepa)
  •                            (list (3dTo2dPt (trans ept 0 norm)))
  •               blst (append (if (= spa fspa)
  •                              (sublist blst fspa nil)
  •                              (cons (k*bulge (nth fspa blst) srat) (sublist blst (1+ fspa) nil))
  •                      (sublist blst 0 fepa)
  •                      (if (= epa fepa)
  •                        (list (nth fepa blst))
  •                        (list (k*bulge (nth fepa blst) erat))
  •                                  (sublist plst fspa (1+ (- fepa fspa)))
  •                                  (cons (3dTo2dPt (trans spt 0 norm)) (sublist plst (1+ fspa) (- fepa fspa)))
  •                              (sublist blst fspa (- fepa fspa))
  •                              (cons (k*bulge (nth fspa blst) srat) (sublist blst (1+ fspa) (- fepa fspa)))
  •                      (if (= epa fepa)
  •       (vlax-put pl 'Coordinates (apply 'append plst))
  •       (foreach b blst (vla-SetBulge pl n b) (setq n (1+ n)))
  •   (sl:-erase obj)
  •   pl
GMT+8, 2025-5-24 14:55 , Processed in 0.175028 second(s), 24 queries , Gzip On.
