查看: 3224|回复: 15
[图元] c#如何删除块中块,保留外层块?
发表于 2021-12-18 13:53:12 | 显示全部楼层 |阅读模式
各位大佬,赐教用c#如何删除块中块,保留最外层块。如块A中包含有块B、块C等等,删除块A中的块B。急求,先感谢各位大佬
发表于 2022-4-13 16:43:29 | 显示全部楼层
                psr.Value.GetEntities<Entity>().ForEach(x => x.ForWrite(e =>
                    if (e is BlockReference brf)
                        using var tr = new DBTrans();
                        var btr = tr.BlockTable.GetRecord(brf.BlockTableRecord, OpenMode.ForRead);
                        foreach (ObjectId id in btr)
                            var e1 = tr.GetObject<Entity>(id, OpenMode.ForWrite);
                            if (e1 is BlockReference brf1)
                                var btr1 = tr.BlockTable.GetRecord(brf1.BlockTableRecord, OpenMode.ForRead);
                                foreach (ObjectId id1 in btr1)
                                    var ent1 = tr.GetObject<Entity>(id1, OpenMode.ForWrite);
                                    ent1.ColorIndex = colorI;
                            else
                                e1.ColorIndex = colorI;
                    if (e is Entity ent)
                        ent.ColorIndex = colorI;
发表于 2021-12-20 12:49:24 | 显示全部楼层
if (ent is BlockReference)
                                using (Transaction trans1 = db.TransactionManager.StartTransaction())
                                    BlockTable bt1 = (BlockTable)trans1.GetObject(db.BlockTableId, OpenMode.ForRead);
                                    BlockReference br1 = (BlockReference)ent;
                                    string blkname1 = br1.Name;
                                    ObjectId brId1 = bt1[blkname1];
                                    BlockTableRecord btr1 = (BlockTableRecord)brId1.GetObject(OpenMode.ForRead);
                                    foreach (ObjectId entId1 in btr1)
                                        Entity ent1 = trans1.GetObject(entId1, OpenMode.ForWrite) as Entity;
                                        ent1.ChangeEntityColor(1);
                                }                             trans1.Commit();
发表于 2021-12-30 13:47:05 | 显示全部楼层
666SHUN 发表于 2021-12-24 17:51
ChangeEntityColor()那这个就是自定义方法了,官方文件没有。这个方法代码可以贴来不?
        /// <summary>
        /// 改变图形颜色
        /// </summary>
        /// <param name="c1Id">图形的ObjectId</param>
        /// <param name="colorIndex">颜色索引</param>
        public static void ChangeEntityColor(this ObjectId c1Id, short colorIndex)
            //图形数据库
            Database db = HostApplicationServices.WorkingDatabase;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                //打开块表
                BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                //打开块表记录
                BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                //获取图形对象
                Entity ent1 = (Entity)c1Id.GetObject(OpenMode.ForWrite);
                ent1.ColorIndex = colorIndex;
                trans.Commit();
发表于 2021-12-18 20:57:22 来自手机 | 显示全部楼层
遍历图块,就是一个blocktable 跟模型空间一样,你怎么遍历模型空间实体,你就怎样操作块
发表于 2021-12-18 20:58:05 来自手机 | 显示全部楼层
图块本身和模型空间一样,都是blocktable
 楼主| 发表于 2021-12-19 11:51:01 | 显示全部楼层
OK,感谢
 楼主| 发表于 2021-12-19 11:53:47 | 显示全部楼层
有时又不会,这是怎么回事呢
 楼主| 发表于 2021-12-19 11:57:44 | 显示全部楼层
另想问问大佬,C#批量绑定图纸时,图纸的图层怎么控制和原来一样呢?遇到的情况是:有时绑定后,会把绑定前处理的图层全部打开了,有时又不会,这是怎么回事呢
 楼主| 发表于 2021-12-22 19:59:59 | 显示全部楼层
                                using (Tr ...
Entity没有ChangeEntityColor()方法?这是你的自定义方法吗,大佬
发表于 2021-12-24 00:29:58 来自手机 | 显示全部楼层
我这月12接触这语言,这个改颜色的方法是抄袭书上的案例,主要是表达两重块的两次遍历,三重或更多估计得递归写法
 楼主| 发表于 2021-12-24 17:51:09 | 显示全部楼层
wang2006zhi 发表于 2021-12-24 00:29
我这月12接触这语言,这个改颜色的方法是抄袭书上的案例,主要是表达两重块的两次遍历,三重或更多估计得递 ...
GMT+8, 2025-5-1 07:58 , Processed in 0.172576 second(s), 25 queries , Gzip On.
