查看: 951|回复: 1
[基础] 插入的文件是块,怎么调整为文件
发表于 2021-12-1 09:54:27 | 显示全部楼层 |阅读模式
以下代码是插入一个外部cad文件,但是插入进去的是一个块,怎么调整为插入文件
[code=.net]public void insertBlockFunc(string blockName, string layerName, bool isShow, bool isCover)
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    // 指定块的插入位置
    PromptPointResult pPtRes;
    PromptPointOptions pPtOpts = new PromptPointOptions("");
    //提示起点
    pPtOpts.Message = "\n请选择插入点: ";
    pPtRes = doc.Editor.GetPoint(pPtOpts);
    Point3d point = pPtRes.Value;
    // 新建块文件数据库对象 读取块
    using (Database blockDb = new Database(false, true))
        // 读取外部块 dwg
        blockDb.ReadDwgFile(blockName, System.IO.FileShare.Read, true, null);
        // 关闭文件
        blockDb.CloseInput(true);
        // 先锁定文档 多文档的情况需要先锁定
        using (DocumentLock lockDoc = doc.LockDocument())
            // 新建图层id
            ObjectId layId = ObjectId.Null;
            // 开启事务处理
            using (Transaction trans = db.TransactionManager.StartTransaction())
                // 指定插入块后的新名称
                string newName = System.IO.Path.GetFileNameWithoutExtension(blockName);
                BlockTable bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                if ((bt.Has(newName)) && isCover)
                    // 插入块 insert it as a new block
                    ObjectId idBtr = doc.Database.Insert(newName, blockDb, false);
                    if (isShow)
                        BlockTableRecord curBtr = trans.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                        LayerTable lt = trans.GetObject(db.LayerTableId, OpenMode.ForWrite) as LayerTable;
                        if (!lt.Has("layerName"))
                            LayerTableRecord ltr = new LayerTableRecord();
                            ltr.Name = "layerName";
                            layId = lt.Add(ltr);
                            trans.AddNewlyCreatedDBObject(ltr, true);
                        curBtr.LayoutId = layId;
                        using (BlockReference blockRef = new BlockReference(point, idBtr))
                            curBtr.AppendEntity(blockRef);
                            trans.AddNewlyCreatedDBObject(blockRef, true);
                else if (!(bt.Has(newName)))
                    if (isShow)
                trans.Commit();
}[/code]
发表于 2021-12-11 15:59:35 | 显示全部楼层
主要步骤
  1. Dim ID As ObjectId = Doc.Database.AttachXref("x:\xxxxx.dwg", "新的名称")
  2. Dim Ref As New BlockReference(Point3d.Origin, ID)
  3. ModelSpace.AppendEntity(Ref)
  4. Trans.AddNewlyCreatedDBObject(Ref, True)
GMT+8, 2025-5-1 05:32 , Processed in 0.159022 second(s), 24 queries , Gzip On.
