查看: 3459|回复: 3
数据库操作相关函数
发表于 2021-11-24 21:52:41 | 显示全部楼层 |阅读模式
以下是关于数据库操作方面的相关函数,cad已经封装好了,lisp可以直接使用,只是好多函数的传入参数个数还不是很明确,现贴出来大家一起研究
(arxload "asilisp")
(vlisp-import-exsubrs
  '("ase.arx" "asilisp.arx" "asi_connect" "asi_disconnect")
ASI_CONNECT
  ASI_CMPIDENT           ASI_COLDSC            ASI_DATABASES    ASI_DBMS
  ASI_DEALLOCSTM   ASI_DELETE            ASI_DIAG             ASI_DISCONNECT
  ASI_ERRQTY           ASI_EXECUTE            ASI_FEATURE             ASI_FETCH
  ASI_IEXECUTE           ASI_INFSCHEMA    ASI_LISPVERSION  ASI_MSG
  ASI_NEXECUTE           ASI_OBJLIST            ASI_OBJNAME             ASI_OBJP
  ASI_OPEN           ASI_PARDSC            ASI_PREPARE             ASI_PROVIDERS
  ASI_ROWQTY           ASI_SQL            ASI_STATECSR     ASI_STMTYPE
  ASI_UPDATE           ASI_VERSION
(ASI_VERSION)
陨落 + 1 很给力!
发表于 2021-11-25 13:41:22 | 显示全部楼层
There are two ASILISP functions that help here. Both return cursors to system tables so you can step through the records to find what you need. For example, this code will return all the available providers:返回所有可用的供应商:
(defun c:getprov ( / fasi_kword fasi_curs fasi_row)
  ;;; Note that ASILISP *must* be loaded first.
  (verify_arxapp_loaded "asilisp")
(setq fasi_curs (asi_providers))
(if (asi_open fasi_curs)
   (prompt "\nasi_open successful.")
   (prompt "\nasi_open failed!")
(print fasi_curs)
(while (/= fasi_kword "eXit")
(initget 1 "First Last Next Prior eXit")
(setq fasi_kword (getkword "\nDisplay Row: (First Last Next Prior eXit)"))
(if (/= fasi_kword "eXit")
     (progn (setq fasi_row (asi_fetch fasi_curs fasi_kword))
         (if fasi_row (print fasi_row)
            (prompt "\nNothing to fetch or asi_fetch failed.")
(if (asi_close fasi_curs)
   (prompt "\nasi_close successful.")
   (prompt "\nasi_close failed!")
发表于 2021-11-25 13:11:57 | 显示全部楼层
asi_connect
Connects to the SQL Environment by implementing <connect statement>
asi_disconnect
Disconnects from the SQL Environment by implementing <disconnect statement> and terminates a connection
asi_coldsc
Retrieves the column's description
asi_deallocstm
Deallocates the prepared SQL statement by means of <deallocate prepared statement>
asi_execute
Executes the prepared SQL statement by implementing <execute_statement>
asi_iexecute
Immediately executes the SQL statement by implementing <execute immediate statement>
asi_nexecute
Executes the native DBMS statement
asi_pardsc
Retrieves the description of the SQL input/output parameters
asi_prepare
Prepares the SQL statement by implementing <prepare statement>
asi_alloc
Allocates the SQL cursor by means of <allocate cursor statement>
asi_close
Closes the opened SQL cursor by means of <dynamic close statement>
asi_delete
Deletes the current row in the SQL cursor by means of <dynamic delete statement: positioned>
asi_fetch
Fetches the current position in the SQL cursor by means of <dynamic fetch statement>
asi_open
Opens the SQL cursor by means of <dynamic open statement>
asi_statecsr
Retrieves the status of the allocated SQL cursor
asi_update
Updates the current row in the SQL cursor by implementing <dynamic update statement: positioned>
asi_cmdtype
Retrieves the type of the SQL statement executed as the string
asi_rowqty
Returns the number of rows processed by the SQL data manipulation statement
asi_stmtype
Retrieves the type of the prepared SQL statement as the string
asi_diag
Retrieves the data from the error diagnostics area
asi_errqty
Retrieves the depth of the error diagnostics area
asi_cmpident
Compares two SQL identifiers
asi_dbms
Retrieves the DBMS name
asi_feature
Checks whether or not DBMS supports the SQL features
asi_getcfg
Used to read data from the specified section of the ASI configuration, which is in the Windows System registry.
asi_lispversion
Returns the AutoLISP ASI version string
asi_msg
Retrieves the message from DBMS
asi_objlist
Retrieves the lists of the valid subordinate SQL objects
asi_objname
Retrieves the SQL object name as the string
asi_objp
Checks the SQL descriptor validation
asi_setcfg
Used to assign a value to the specified entry in the specified section in the System registry
asi_sql
Retrieves the SQL realization string
asi_version
Returns the ASI version string
发表于 2023-3-21 13:35:49 | 显示全部楼层
老大,晓东上不了,可否在明经公布一下您的数据库函数库。
可否公布一下数据库如何操作的呢?
这个板块相当封闭。简直没啥用处!
GMT+8, 2025-4-30 20:24 , Processed in 0.185795 second(s), 24 queries , Gzip On.
