查看: 923|回复: 4
[提问] G版的这个检测Excel函数如何修改可以支持ecxel2016版本?
发表于 2021-11-23 05:33:40 | 显示全部楼层 |阅读模式
现在最高只支持到excel2013版本,无法识别excel2016版本。
(Defun vlxls-app-Init
       (/ OSVar GGG Olb8 Olb9 Olb10 TLB Out msg msg1 msg2)
  (if *Chinese*
    (setq msg  "\n 初始化微软Excel "
          msg1 "\042初始化Excel错误\042"
          msg2 (strcat
                 "\042 警告"
                 "\n ===="
                 "\n 无法在您的计算机上检测到微软Excel软件"
                 "\n 如果您确认已经安装Excel, 请发送电子邮"
                 "\n 件到kozmosovia@hotmail.com获取更多的解决方案\042")
    (setq msg  "\n Initializing Microsoft Excel "
          msg1 "\042Initialization Error\042"
          msg2 (strcat
                 "\042 WARNING"        "\n ======="
                 "\n Can NOT detect Excel97/200X/XP in your computer"
                 "\n If you already have Excel installed, please email"
                 "\n us to get more solution via GuXiaolin@hxch.com.cn\042")
  (if (null msxlc-xl24HourClock)
      (if (and (setq GGG
                      (vl-registry-read
                        "HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\Excel.EXE"
                        "Path"
               (setq GGG (strcase (strcat GGG "Excel.EXE")))
          (foreach OSVar  (list        "SYSTEMROOT"          "WINDIR"
                                "WINBOOTDIR"          "SYSTEMDRIVE"
                                "USERNAME"          "COMPUTERNAME"
                                "HOMEDRIVE"          "HOMEPATH"
                                "PROGRAMFILES")
            (if        (vl-string-search (strcat "%" OSVar "%") GGG)
              (setq GGG        (vl-string-subst
                          (strcase (getenv OSVar))
                          GGG
          (setq        Olb8  (findfile
                        (vl-string-subst "EXCEL8.OLB" "EXCEL.EXE" GGG))
                Olb9  (findfile
                        (vl-string-subst "EXCEL9.OLB" "EXCEL.EXE" GGG))
                Olb10 (findfile        (vl-string-subst
                                  "EXCEL10.OLB"
                                  "EXCEL.EXE"
                                  GGG))
          (cond
            ((= (vl-filename-base (vl-filename-directory GGG))
                    "OFFICE15"
                 (setq TLB GGG
                       Out "2013"
                    "OFFICE14"
                 (setq TLB GGG
                       Out "2010"
                    "OFFICE12"
                 (setq TLB GGG
                       Out "2007"
                "OFFICE11"
             (setq TLB GGG
                   Out "2003"
                "OFFICE10"
             (setq TLB GGG
                   Out "XP"
            (Olb9
             (setq TLB Olb9
                   Out "2000"
            (Olb8
             (setq TLB Olb8
                   Out "97"
            (t (setq TLB GGG Out "Version Unknown"))
          (if TLB
              (princ (strcat MSG Out "..."))
              (vlax-import-type-library
                :tlb-filename           TLB
                :methods-prefix           "msxl-"
                :properties-prefix "msxlp-"
                :constants-prefix  "msxlc-")
          ;|(if vldcl-msgbox
            (vldcl-msgbox "x" msg1 msg2)
            (alert (read msg2))
          (alert msg2)
          (exit)
  msxlc-xl24HourClock
发表于 2021-11-23 08:54:58 | 显示全部楼层
照猫画虎添加进去啊
发表于 2021-11-23 09:38:47 | 显示全部楼层
昨天刚刚遇到这个问题,没想应有帖子反馈了。
 楼主| 发表于 2021-11-23 19:43:33 | 显示全部楼层
安装offcie2016完整版的只需要添加
                    "OFFICE16"
                 (setq TLB GGG
                       Out "2016"
就可以了,绿色版或者精简版的不行。
发表于 2021-11-24 09:38:18 | 显示全部楼层
原来如此,我昨天照着“烟盒迷唇”大佬说的照猫画虎的方法,如法炮制,但是不行。
GMT+8, 2025-7-10 10:00 , Processed in 0.172951 second(s), 26 queries , Gzip On.
