查看: 3064|回复: 13
加载插件提示错误: no function definition: CX-REG-YN
发表于 2021-11-21 22:23:03 | 显示全部楼层 |阅读模式
在论坛上下载表格删除0空格并重新编号这个插件,感觉非常好用,但加载后提示错误: no function definition: CX-REG-YN,换几个版本CAD也如此,查询翻译应该是有自定义函数不能加载。打开插件第一条命令出现了,不知如何解决,请教大佬大神帮助,谢谢!
源程序如下:
(defun c:a5 ( / a a1 aa b1 box ffx h1 i kk l1 l2 la lb lbg lc ld le lk ll lsn lss lx lxx ly odlst pc sn ss sty th tw x xx y y1 y2 dxf ss2lst ssbox ebox cbox mid 3d2d CurveLength lstcj qbw mkline mktext RevmoveMt2Text explodeblk cumid)(cx-reg-yn)
(defun cumid (e) (vlax-curve-getpointatdist e (* 0.5 (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e)))))
(defun explodeblk(ent)
  (mapcar 'vlax-vla-object->ename (vlax-safearray->list
    (vlax-variant-value
                          (vla-explode(vlax-ename->vla-object ent)))))
(defun RevmoveMt2Text (MTextString / regex s)
  (setq regex(vlax-create-object "Vbscript.RegExp")) ;引用正则表达式控件
  (vlax-put-property regex "IgnoreCase" 0) ;不忽略大小写
  (vlax-put-property regex "Global" 1) ;匹配方式,全文字匹配
  (setq s MTextString)
        ;替换\\字符
  (vlax-put-property regex "Pattern" "\\\\\\\\")
  (setq s(vlax-invoke-method  regex "Replace" s (chr 1)))
        ;替换\{字符
  (vlax-put-property regex "Pattern" "\\\\{")
  (setq s(vlax-invoke-method  regex "Replace" s (chr 2)))
        ;替换\}字符
  (vlax-put-property regex "Pattern" "\\\\}")
  (setq s(vlax-invoke-method  regex "Replace" s (chr 3)))
        ;删除段落缩进格式
  (vlax-put-property regex "Pattern" "\\\\pi(.[^;]*);")
  (setq s(vlax-invoke-method  regex "Replace" s ""))
        ;删除制表符格式
  (vlax-put-property regex "Pattern" "\\\\pt(.[^;]*);")
        ;删除堆迭格式
  (vlax-put-property regex "Pattern" "\\\\S(.[^;]*)(\\^|#|\\\\)(.[^;]*);")
        ;删除字体、颜色、字高、字距、倾斜、字宽、对齐格式
  (vlax-put-property regex "Pattern" "(\\\\F|\\\\f|\\\\C|\\\\H|\\\\\T|\\\\Q|\\\\W|\\\\A)(.[^;]*);")
        ;删除下划线、删除线格式
  (vlax-put-property regex "Pattern" "(\\\\L|\\\\O|\\\\l|\\\\o)")
        ;删除不间断空格格式
  (vlax-put-property regex "Pattern" "\\\\~")
        ;删除换行符格式
  (vlax-put-property regex "Pattern" "\\\\P")
        ;删除换行符格式(针对Shift+Enter格式)
  (vlax-put-property regex "Pattern" "\n")
        ;删除{}
  (vlax-put-property regex "Pattern" "({|})")
        ;替换回\\,\{,\}字符
  (vlax-put-property regex "Pattern" "\\x01")
  (setq s(vlax-invoke-method  regex "Replace" s "\\"))
  (vlax-put-property regex "Pattern" "\\x02")
  (setq s(vlax-invoke-method  regex "Replace" s "{"))
  (vlax-put-property regex "Pattern" "\\x03")
  (setq s(vlax-invoke-method  regex "Replace" s "}"))
  (vlax-release-object regex)
  s
(defun dxf (key ename) (cdr (assoc key (entget ename))))
(defun ss2lst ( ss / i l )
    (if ss
        (repeat (setq i (sslength ss))
            (setq l (cons (ssname ss (setq i (1- i))) l))
(defun ssbox ( s / a b i m n o )
    (repeat (setq i (sslength s))
        (if
            (and
                (setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
                (vlax-method-applicable-p o 'getboundingbox)
                (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-getboundingbox (list o 'a 'b))))
            (setq m (cons (vlax-safearray->list a) m)
                  n (cons (vlax-safearray->list b) n)
    (if (and m n)
        (mapcar '(lambda ( a b ) (apply 'mapcar (cons a b))) '(min max) (list m n))
(defun ebox (ent / ll ur)
  (vla-getboundingbox (vlax-ename->vla-object ent) 'll 'ur)
  (mapcar 'safearray-value (list ll ur))
(defun CurveLength (ename)
  (vlax-curve-getDistAtParam
    ename
    (vlax-curve-getEndParam ename)
(defun lstcj ( l1 l2 )
  (vl-remove-if '(lambda ( x ) (member x l2)) l1)
(defun qbw (lst)
   (reverse (cdr (reverse lst)))
(defun cbox (e) (apply 'mid (ebox e)))
(defun mid (p1 p2) (mapcar (function (lambda (e1 e2) (* (+ e1 e2) 0.5))) p1 p2))
(defun 3d2d (p) (mapcar '+ p '(0 0)))
(defun ScreenWinwow(/ h c)
  (setq c(getvar'viewctr)
        h(*(getvar'viewsize)0.5)
        h(list(*(apply'/(getvar'screensize))h)h))
  (mapcar'(lambda(x)(mapcar x c h))'(- +))
(setq *ACAD*  (vlax-get-acad-object)
    *DOC*   (vla-get-ActiveDocument *ACAD*)
(defun *error*(msg)
     (mapcar 'setvar '("cmdecho" "osmode" "dimzin") odlst)
     (vlax-invoke-method *DOC* 'EndUndoMark)
     (princ msg)
(vlax-invoke-method *DOC* 'StartUndoMark)
(setq odlst (mapcar 'getvar '("cmdecho" "osmode" "dimzin")))
(mapcar 'setvar '("cmdecho" "osmode" "dimzin") '(0 0 8))
(setq lst nil
        ts (princ "\n选择全部表格:")
        ss (ssget '((0 . "*text,line") (8 . "表格")))
(if ss
(setq lss (ss2lst ss)
        l1 (vl-remove-if-not '(lambda(x) (wcmatch (dxf 0 x) "*TEXT")) lss)
        l2 (vl-remove-if-not '(lambda(x) (= "LINE" (dxf 0 x))) lss)
        l2 (vl-sort l2 '(lambda (x y) (< (CurveLength x) (CurveLength y)) ) )
        th (apply 'min (mapcar '(lambda(x) (dxf 40 x)) l1))
        h1 (* th 0.5)
        ll (ScreenWinwow)
        sty (dxf 7 (car l1))
    tw (dxf 41 (car l1))
(while l2
        (setq a (car l2)
                box (mapcar '3d2d (ebox a))
                box (list (mapcar '- (car box) (list h1 h1)) (mapcar '+ (cadr box) (list h1 h1)))
                ffx t
        (command "zoom" "w" (car box) (cadr box) "zoom" "0.9xp")
        (while (and ffx (setq sn (ssget "c" (car box) (cadr box) '((0 . "*text,line") (8 . "表格")))))
                (setq b1 (mapcar '3d2d (ssbox sn))
                b1 (list (mapcar '- (car b1) (list h1 h1)) (mapcar '+ (cadr b1) (list h1 h1)))
                (command "zoom" "w" (car b1) (cadr b1) "zoom" "0.9xp")
                (if (equal b1 box th)
                        (setq ffx nil)
                        (setq box b1)
        (setq lsn (ss2lst sn)
                l2 (lstcj l2 lsn)
        (if (> (length lsn) 2)
                        (setq la (vl-remove-if-not '(lambda(x) (wcmatch (dxf 0 x) "*TEXT")) lsn)
                        la (vl-sort la '(lambda (x y) (< (cadr (cbox x)) (cadr (cbox y))) ) )
                        lb nil
                        (while la
                                (setq a1 (car la);
                                lx (vl-remove-if-not '(lambda(x) (equal (cadr (cbox x)) (cadr (cbox a1)) (* th 0.4))) la)
                                lx (vl-sort lx '(lambda (x y) (< (car (cbox x)) (car (cbox y))) ) )
                                lb (cons lx lb);
                                la (lstcj la lx)
                        (setq i 0
                                lb (mapcar '(lambda(x) (cons (setq i (1+ i)) x)) lb)
                                ly (mapcar '(lambda(x) (cons (car x) (cadr (cbox (cadr x))))) lb)
                                lc (mapcar '(lambda(x)
                        (if (equal "0" (RevmoveMt2Text (dxf 1 (last x))))
                                (mapcar 'entdel (cdr x))
                                (list (car x))
                        )) lb)
                        ld (vl-remove-if-not '(lambda(x) (= 1 (length x))) lc)
                        (if ld
                                (setq ld (reverse ld))
                                (while ld
                                        (setq a1 (car ld)
                                                ld (cdr ld)
                                        (setq l1 (member a1 lc)
                                                y1 (cdar (vl-remove-if-not '(lambda(x) (= (car a1) (car x))) ly))
                                                y2 (cdar (vl-remove-if-not '(lambda(x) (= (1- (car a1)) (car x))) ly))
                                        (setq le (apply 'append (mapcar 'cdr (cdr l1))))
                                        (foreach x le
                                                (vla-move (Vlax-Ename->Vla-Object x) (vlax-3d-point (list 0 y1)) (vlax-3d-point (list 0 y2)))
                                (setq ld (vl-remove-if-not '(lambda(x) (and (entget x) (wcmatch (dxf 0 x) "*TEXT"))) lsn)
                                lxx (vl-remove-if-not '(lambda(x) (and (entget x) (wcmatch (dxf 0 x) "LINE"))) lsn)
                                lbg nil
                                (setvar "clayer" "表格")
                                (foreach aa ld
                                        (command "_.boundary" "a" "b" "n" sn "" "" (cbox aa) "")
                                        (setq kk (entlast)
                                                lk (explodeblk kk)
                                        (entdel kk)
                                        (foreach xx lk
                                                (if (not (vl-remove-if-not '(lambda(x) (equal x (setq pc (cumid xx)) (* th 0.1))) lbg))
                                                        (setq lbg (cons pc lbg))
                                                        (entdel xx)
                                (mapcar 'entdel lxx)
                                (setq ld (vl-remove-if-not '(lambda(x) (> (length x) 1)) lc))
                                (setq ld (mapcar 'cadr (cdr ld)))
                                (setq i 0)
                                (foreach aa ld
                                        (Vlax-Put-Property (Vlax-Ename->Vla-Object aa) 'TextString (itoa (setq i (1+ i))))
(command "zoom" "w" (car ll) (cadr ll))
(princ "\n表格图层没对象被选择到:")
发表于 2021-11-29 09:10:19 | 显示全部楼层
jhzxj 发表于 2021-11-26 19:33
大神,怎么删除?可否指点下,我对lisp不懂,请指教下,谢谢!
就是按 “htlaser” 说的,在原程序中把那一句(cx-reg-yn)查找,删掉就可以了,已经试过了,删了就可以了。
 楼主| 发表于 2021-11-26 19:33:10 | 显示全部楼层
panliang9 发表于 2021-11-23 14:31
确实是,删了以后,似乎就行了。可以处理图层名为表格的表格对象。格式须按原贴的表格。
 楼主| 发表于 2021-11-29 22:27:21 | 显示全部楼层
panliang9 发表于 2021-11-29 09:10
就是按 “htlaser” 说的,在原程序中把那一句(cx-reg-yn)查找,删掉就可以了,已经试过了,删了就可以了 ...
谢谢指点,非常感谢,我试试。
发表于 2021-11-22 09:26:54 | 显示全部楼层
把这个删除 (cx-reg-yn) 试试
发表于 2021-11-22 09:31:16 | 显示全部楼层
提示错误: no function definition: CX-REG-YN,提示这个是缺少了 CX-REG-YN这个函数   一般这个是为函数
发表于 2021-11-23 08:56:56 | 显示全部楼层
这个看意思应该是注册类的函数
 楼主| 发表于 2021-11-23 09:23:11 | 显示全部楼层
烟盒迷唇 发表于 2021-11-23 08:56
这个看意思应该是注册类的函数
能否修改下?
发表于 2021-11-23 09:23:59 | 显示全部楼层
论坛原贴发一下链接,大家一起看下。
发表于 2021-11-23 09:35:48 | 显示全部楼层
注释掉就得了,不影响程序使用。
 楼主| 发表于 2021-11-23 11:01:37 | 显示全部楼层
panliang9 发表于 2021-11-23 09:23
论坛原贴发一下链接,大家一起看下。
原帖子http://bbs.mjtd.com/forum.php?mo ... hlight=%D6%D8%D0%C2
发表于 2021-11-23 14:31:29 | 显示全部楼层
发表于 2021-11-25 09:13:25 | 显示全部楼层
看起来是用了他自己的函数库吧
GMT+8, 2025-5-1 17:07 , Processed in 0.204310 second(s), 30 queries , Gzip On.
