查看: 1269|回复: 5
[提问] 路径字符串转换
发表于 2021-11-3 11:52:24 | 显示全部楼层 |阅读模式
请教一下各位大神、如何用lisp将  D:\飞诗编辑器\Drawing1.dwg  这个字符串路径转换为   D:\\飞诗编辑器\\Drawing1.dwg
发表于 2021-11-3 14:44:14 | 显示全部楼层
        (Defun vldos-formatpath (string)
                (while (vl-string-search "/" string)
                        (setq string (vl-string-subst "\\" "/" string)))
                (while (vl-string-search "\\\\" string)
                        (setq string (vl-string-subst "\\" "\\\\" string)))
                (strcase string)
发表于 2021-11-3 15:14:19 | 显示全部楼层
这应该是一个转义符的问题吧,这道题应该无解
发表于 2021-11-4 14:48:52 | 显示全部楼层
(setq ot "\\"  nt"=="  mt "=")
(setq str (vl-string-subst nt ot str ))
(setq str (vl-string-subst ot mt str ))
循环一下就好
 楼主| 发表于 2021-11-6 09:20:30 | 显示全部楼层
                        (setq string (vl-strin ...
谢谢、我试试
 楼主| 发表于 2021-11-6 09:20:50 | 显示全部楼层
(setq str (vl-string-sub ...
谢谢
GMT+8, 2025-7-10 10:07 , Processed in 0.177622 second(s), 25 queries , Gzip On.
