查看: 1362|回复: 0
[资源] 【转载】Xrecord之DBDictionary信息的添加与获取
发表于 2021-10-25 22:00:21 | 显示全部楼层 |阅读模式
  1.   [CommantMethod("ADDINI")]
  2.         public static void AddIni()
  3.         {
  4.             try
  5.             {
  6.                 Document doc = Application.DocumentManager.MdiActiveDocument;
  7.                 Database db = doc.Database;
  8.                 using (Transaction tr = db.TransactionManager.StartTransaction())
  9.                 {
  10.                     DBDictionary NOD =(DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
  11.                     DBDictionary dict;//作为主字典中INI键的值
  12.                     if (NOD.Contains("INI"))
  13.                     {
  14.                         dict = (DBDictionary)tr.GetObject(NOD.GetAt("BLSZ"), OpenMode.ForWrite);
  15.                     }
  16.                     else
  17.                     {
  18.                         dict = new DBDictionary();
  19.                         NOD.UpgradeOpen();
  20.                         NOD.SetAt("INI", dict);
  21.                         tr.AddNewlyCreatedDBObject(dict, true);
  22.                     }
  23.                     ResultBuffer resBuf = new ResultBuffer();
  24.                     resBuf.Add(new TypedValue((int)DxfCode.Text, "A"));
  25.                     resBuf.Add(new TypedValue((int)DxfCode.Text, "B"));
  26.                     Xrecord xRec = new Xrecord();
  27.                     xRec.Data = resBuf;
  28.                     dict.SetAt("INIS", xRec);
  29.                     tr.AddNewlyCreatedDBObject(xRec, true);
  30.                     tr.Commit();
  31.                 }
  32.             }
  33.             catch {
  34.             }
  35.         }
  36.         [CommandMethod("GETINI")]
  37.         public static void  GetINI()
  38.         {
  39.             try
  40.             {
  41.                 Document doc = Application.DocumentManager.MdiActiveDocument;
  42.                 Database db = doc.Database;
  43.                 Edotor ed=doc.Editor;
  44.                 using (Transaction tr = db.TransactionManager.StartTransaction())
  45.                 {
  46.                     DBDictionary NOD = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
  47.                     if (NOD.Contains("INI"))
  48.                     {
  49.                         DBDictionary dict = tr.GetObject(NOD.GetAt("INI"), OpenMode.ForRead) as DBDictionary;
  50.                         Xrecord xRec = tr.GetObject(dict.GetAt("INIS"), OpenMode.ForRead) as Xrecord;//获取值
  51.                         foreach (var xdata in xRec.Data)
  52.                         {
  53.                             ed.WriteMessage(xdata.Value.ToString()+"\n");
  54.                         }
  55.                     }
  56.                 }
  57.             }
  58.             catch{
  59.             }
  60.         }
  61. ————————————————
  62. 版权声明:本文为CSDN博主「淡定vs冷漠」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
  63. 原文链接:https://blog.csdn.net/qq_21489689/article/details/79061759
GMT+8, 2025-5-1 07:30 , Processed in 0.141891 second(s), 23 queries , Gzip On.
