查看: 3367|回复: 20
请求帮助,把画柜子的等分加强下
发表于 2021-8-15 15:41:03 | 显示全部楼层 |阅读模式
(defun C:df( / )
            (setq cm (getvar "cmdecho")
                  os (getvar "osmode"))
(setvar "CMDECHO" 0)
   (command "color" "bylayer")
         (command "_undo" "be")
                (if (setq pta (getpoint "\n层板位置<空格>两点定位"))
        (COMMAND "-BOUNDARY" pta "")
        (setq ent (entlast))
        (setq ss (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget ent))))
        (if (= (length ss) 4)
                        (vl-load-com)
                        (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
                        (setq p1 (vlax-safearray->list maxpoint)
                                p3 (vlax-safearray->list minpoint))
                        (setq p2 (list (car p3) (cadr p1)))
                        (setq p4 (list (car p1) (cadr p3)))
      (COMMAND "_.erase"  ENT "")
                (setq p1 (getpoint"\n洞口不是矩形,手动选择矩形的第一点"))
    (setq p3 (getcorner p1 "\n第二点"))
        (setvar "osmode" 0)
    (command "rectang" p1 p3)
     (vl-load-com)
         (setq p4 (list (car p1) (cadr p3)));外框线点定位
         (COMMAND "_.erase"  ENT ""))
    (setq p1 (getpoint"\n第一点"))
        (setvar "osmode" 0)
     (vl-load-com)
        (setq nl (getdist"\n层板厚度"))
        (setq n (getint"\n层板数量"))
        (setq gl (distance p1 p4))
        (setq kl (distance p1 p2))
        (setq l (/ (- gl (* nl n)) (1+ n)))
        (repeat n
        (setq ptn (polar p1 (angle p2 p3) l))
        (setq ptny (polar ptn (angle p4 p3) kl))
(entmake (list '(0 . "LINE") (cons 10 ptn) (cons 11 ptny)))
        (setq ptn1 (polar ptn (angle p2 p3) nl))
        (setq ptn1y (polar ptn1 (angle p4 p3) kl))
(entmake (list '(0 . "LINE") (cons 10 ptn1) (cons 11 ptn1y)))
        (setq p1 ptn1)
        (setvar "CMDECHO" cm)
        (setvar "osmode" os)
有大师能把这个改改吗,想要竖的效果也有  他只有横的
发表于 2021-8-19 10:09:41 | 显示全部楼层
竖向等分板,按上楼的方向,加了默认值,方便一点,不用每处都要自已输入
(defun C:ddf( / )
                        (vl-load-com)
        (setvar "osmode" 0)
     (vl-load-com)
        (setvar "osmode" 0)
     (vl-load-com)
        (setq nl (getdist"\n层板厚度<20>"))
                (if (= nl nil) (setq nl 20))
        (setq n (getint"\n层板数量<5>"))
                (if (= n nil) (setq n 5))
        (repeat n
          (setq l (/ (- kl (* nl n)) (1+ n)))
       (setq ptn (polar p1 (angle p4 p3) l))
        (setq ptny (polar ptn (angle p2 p3) gl))
        (setq ptn1 (polar ptn (angle p4 p3) nl))
        (setq ptn1y (polar ptn1 (angle p2 p3) gl))
        (setq p1 ptn1)
发表于 2021-8-19 10:11:11 | 显示全部楼层
水平方向的等分板有一个更简单的,基本上差不多,别的网友写的,
;;;;;;等分板
(defun c:DFF()
(setq os (getvar "OSMODE"))
(setq p1 (getpoint "\n左上角点:")
       p3 (getcorner p1 "\n右下角点:"))
(setq p1x (car p1)
       p1y (cadr p1)
       p3x (car p3)
       p3y (cadr p3)
       p2  (list p3x p1y)
       p4  (list p1x p3y))
(setq ch (getdist "\n请输入中间层板厚度<20>: "))
(if (= ch nil) (setq ch 20))
(setq df (getdist "\n请输入风格数<5>: "))
(setq df (if (= df nil) 5 (fix df)))
(setq A (distance p1 p4))
(setq x (/ (- A (* (1- df) ch)) df))
(command "line" (polar p4 (* pi 0.5) x) (polar p3 (* pi 0.5) x) "")
(setq s01 (entlast))
(command "_offset" ch (list s01 (polar p4 (* pi 0.5) x)) (polar (polar p4 (* pi 0.5) x) (* pi 0.5) 500) "" )
(setq ss (ssget "w" (polar p1 (* pi 1.5) 10) (polar p3 (* pi 0.5) 10) ))
(command "_array" ss "" "R" (1- df) "1" (+ x ch) "")
(setvar "CMDECHO" 1)
发表于 2021-8-17 19:54:27 | 显示全部楼层
把这部份改成下面的,就变成竖向的了
(repeat n
        (setq p1 ptn1)
发表于 2021-8-16 10:09:58 | 显示全部楼层
直接做个动态块多省事啊,还方便修改
 楼主| 发表于 2021-8-16 11:15:24 | 显示全部楼层
k1nger 发表于 2021-8-16 10:09
直接做个动态块多省事啊,还方便修改
动态块有  但是感觉还是这个方法好用点
发表于 2021-8-17 08:51:36 | 显示全部楼层
这个我都弄出来用了好几年了!
发表于 2021-8-17 08:52:23 | 显示全部楼层
写复杂了,用command调用阵列
 楼主| 发表于 2021-8-17 09:34:03 | 显示全部楼层
写不完的日记 发表于 2021-8-17 08:52
写复杂了,用command调用阵列
别人那里拿的,不知道你是作者  呵呵
 楼主| 发表于 2021-8-19 20:26:33 | 显示全部楼层
谢谢大家,我这边自己也弄好了。
GMT+8, 2025-5-24 15:45 , Processed in 0.164420 second(s), 25 queries , Gzip On.
