查看: 6787|回复: 20
[界面] autohook net版
发表于 2021-7-10 20:45:07 | 显示全部楼层 |阅读模式
cad 热键,支持鼠标键盘组合。
netload 一次加载程序文件即可。
[KEYEDIT]:编辑热键
[keyson]:打开热键
[keysoff]:关闭热键
发表于 2024-2-13 20:48:57 | 显示全部楼层
无法加载啊!提示如下:
命令: NETLOAD
无法加载程序集。错误详细信息: System.IO.FileLoadException: Could not load file or assembly 'file:///C:\Users\Administrator\Desktop\HotKeys net 版\HotKeys_23.1.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
文件名:“file:///C:\Users\Administrator\Desktop\HotKeys net 版\HotKeys_23.1.dll” ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
   在 System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   在 System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   在 System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
   在 System.Reflection.Assembly.LoadFrom(String assemblyFile)
   在 Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   在 loadmgd()
发表于 2024-7-11 16:31:24 | 显示全部楼层
brainstorm 发表于 2021-7-10 20:59
支持cad 2012 14 20,高版本用低版本应该可以
不需要其他复杂的设置,弄一个支持2010的?  把“F8”改为,“左alt”
发表于 2021-12-4 00:02:57 | 显示全部楼层
梦寐以求多少年的东西了 还在犹豫要不要花2个币  完全超值。哈哈实现了我多年的夙愿 谢谢大师
 楼主| 发表于 2021-7-10 20:59:01 来自手机 | 显示全部楼层
发表于 2021-7-11 07:39:14 | 显示全部楼层
18.16用20版本吗?
 楼主| 发表于 2021-7-11 09:43:13 | 显示全部楼层
23.1是cad2020
发表于 2021-7-12 13:39:05 | 显示全部楼层
提示压缩包损坏了
 楼主| 发表于 2021-7-12 18:32:14 来自手机 | 显示全部楼层
论坛有修复工具 是论坛的原因
发表于 2021-8-4 10:54:31 | 显示全部楼层
https://pan.baidu.com/s/1mbmoyT_7xeKDMmMWNjjrEQ
提取码:
mjtd
修复工具
发表于 2021-8-4 11:08:28 | 显示全部楼层
快捷键 无法输入 2014 浪费俩币
 楼主| 发表于 2021-8-4 18:38:40 来自手机 | 显示全部楼层
hvacr 发表于 2021-8-4 11:08
快捷键 无法输入 2014 浪费俩币
具体情况是什么
发表于 2021-8-5 12:09:27 | 显示全部楼层
快捷键那里输不进去,乱按有时会有点内容
GMT+8, 2025-5-1 04:17 , Processed in 0.150331 second(s), 27 queries , Gzip On.
