楼主: pym
[2023] 真的跟不上AutoDesk的步伐——AutoCAD 2023本月初就开始Alpha版的测试了
发表于 2021-6-24 00:22:37 | 显示全部楼层
2018   R24,2    安装路径不一样。天正建筑挂上也用不了
发表于 2021-6-24 11:15:18 | 显示全部楼层
luqzcm 发表于 2021-6-22 12:48
10年画图狗表示08版很香,还可以再战5年
我也喜欢用08 ,但是工作软件不支持,烦躁
发表于 2021-6-24 12:07:28 | 显示全部楼层
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: TANGENT
Customization file loaded successfully. Customization Group: 天正快捷菜单
Regenerating model.
c:\tangent\tarcht20v7\sys24x64\tch_blklib.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'tch_blklib.arx'
tch_blklib.arx
c:\tangent\tarcht20v7\sys24x64\tch_interior.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'tch_interior.arx'
tch_interior.arx
c:\tangent\tarcht20v7\sys24x64\tch_uiframe.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_uiframe.arx'
c:\tangent\tarcht20v7\sys24x64\tch_kerncmd.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_kerncmd.arx'
c:\tangent\tarcht20v7\sys24x64\tch_annotate.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_annotate.arx'
c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arx'
c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arxRuntime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_elevation.arx' is already loaded.
c:\tangent\tarcht20v7\sys24x64\tch_siteplan.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_siteplan.arx'
c:\tangent\tarcht20v7\sys24x64\tch_public.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_public.arx'
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_blklib.arx'
c:\tangent\tarcht20v7\sys24x64\tch_blklib.arxRuntime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_elevation.arx' is already loaded.Runtime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_3dsolids.arx' is already loaded.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_interior.arx'
AutoCAD menu utilities loaded.*Cancel*
Command: *Cancel*
_RIBBON
*Cancel*
COMMANDLINE
Command:
Command:
Command:
加载天正菜单文件: C:\Tangent\TArchT20V7\sys24x64\tch.tmn
LOGINITIALWORKSPACEESW
Command: tshowbar
Customization file unloaded successfully. Customization Group: 天正快捷菜单
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: *Cancel*
Command: tgwall
Unknown command "TGWALL".  Press F1 for help.
Command: *Cancel*
发表于 2021-6-24 13:57:09 | 显示全部楼层
一直不明白,好好的十字光标,为什么高版本来个,中空形状的。这改来改去,这点小玩意,就能提高效率?明摆着就是坑钱的
注:十字光标的大小要设置为100%才行。  发表于 2021-9-8 18:56
因为很多用户提出十字叉丝穿过去的老的设计,让他们看不清点击框中的对象,所以 Autodesk 就按他们的意见改成了默认为中空的形式(你也可以在option三种改回来)  发表于 2021-6-24 16:56
发表于 2021-6-24 14:09:56 | 显示全部楼层
一直用2004的留个爪印
发表于 2021-6-24 18:10:46 | 显示全部楼层
andyhua 发表于 2021-6-24 13:57
一直不明白,好好的十字光标,为什么高版本来个,中空形状的。这改来改去,这点小玩意,就能提高效率?明摆 ...
你可以这样调出来:
在选项OP对话框的在“三维建模”选项卡里,取消勾选“在十字光标中显示Z轴”后,十字光标就不空心了(注:十字光标的大小要设置为100%才行。),如下图所示。
2015及以上版本不建议改这个选项,改了之后在三维空间中不显示Z轴的光标线了,显得很难看(如下图)。 另外,是空心的与不空心的,又有啥区别,习惯了也没什么。
发表于 2021-6-24 19:56:14 | 显示全部楼层
aichong 发表于 2021-6-24 18:10
你可以这样调出来:
在选项OP对话框的在“三维建模”选项卡里,取消勾选“在十字光标中显示Z轴”后,十 ...
兄弟,挂上天正建筑后,命令都不用哎,你有试试?
发表于 2021-6-25 16:24:02 | 显示全部楼层
更新一代用一代,强迫症表示就喜欢用最新版本的
发表于 2021-6-26 09:21:48 | 显示全部楼层
年年更新不如好好修复下bug,比如文字bug,放大缩小宋体真的那种顿挫感很强。。。
发表于 2021-6-28 00:22:35 | 显示全部楼层
2022一些新功能或者说修复BUG是真好——我毫不犹豫的就把2020抛弃了
GMT+8, 2025-8-23 09:53 , Processed in 0.189045 second(s), 18 queries , Gzip On.
