查看: 13908|回复: 49
[2023] 真的跟不上AutoDesk的步伐——AutoCAD 2023本月初就开始Alpha版的测试了
发表于 2021-6-21 22:34:30 | 显示全部楼层 |阅读模式
半个月没看邮箱,今天一看,在月初AutoDesk就发了AutoCAD 2023 Alpha版——Turing(图灵)的测试邀请。AutoDesk的步伐真是太快了,2022正式版还在适应中,2023版就开始测试了。
发表于 2021-6-24 12:07:28 | 显示全部楼层
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: CUSTOM
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: TANGENT
Customization file loaded successfully. Customization Group: 天正快捷菜单
Regenerating model.
c:\tangent\tarcht20v7\sys24x64\tch_blklib.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'tch_blklib.arx'
tch_blklib.arx
c:\tangent\tarcht20v7\sys24x64\tch_interior.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'tch_interior.arx'
tch_interior.arx
c:\tangent\tarcht20v7\sys24x64\tch_uiframe.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_uiframe.arx'
c:\tangent\tarcht20v7\sys24x64\tch_kerncmd.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_kerncmd.arx'
c:\tangent\tarcht20v7\sys24x64\tch_annotate.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_annotate.arx'
c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arx'
c:\tangent\tarcht20v7\sys24x64\tch_toolcmd.arxRuntime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_elevation.arx' is already loaded.
c:\tangent\tarcht20v7\sys24x64\tch_siteplan.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_siteplan.arx'
c:\tangent\tarcht20v7\sys24x64\tch_public.arx cannot find a dll or other file that it needs.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_public.arx'
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_blklib.arx'
c:\tangent\tarcht20v7\sys24x64\tch_blklib.arxRuntime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_elevation.arx' is already loaded.Runtime Extension 'c:\tangent\tarcht20v7\sys24x64\tch_3dsolids.arx' is already loaded.
AcRxDynamicLinker failed to load 'c:\tangent\tarcht20v7\sys24x64\tch_interior.arx'
AutoCAD menu utilities loaded.*Cancel*
Command: *Cancel*
_RIBBON
*Cancel*
COMMANDLINE
Command:
Command:
Command:
加载天正菜单文件: C:\Tangent\TArchT20V7\sys24x64\tch.tmn
LOGINITIALWORKSPACEESW
Command: tshowbar
Customization file unloaded successfully. Customization Group: 天正快捷菜单
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: *Cancel*
Command: tgwall
Unknown command "TGWALL".  Press F1 for help.
Command: *Cancel*
发表于 2021-6-24 18:10:46 | 显示全部楼层
andyhua 发表于 2021-6-24 13:57
一直不明白,好好的十字光标,为什么高版本来个,中空形状的。这改来改去,这点小玩意,就能提高效率?明摆 ...
你可以这样调出来:
在选项OP对话框的在“三维建模”选项卡里,取消勾选“在十字光标中显示Z轴”后,十字光标就不空心了(注:十字光标的大小要设置为100%才行。),如下图所示。
2015及以上版本不建议改这个选项,改了之后在三维空间中不显示Z轴的光标线了,显得很难看(如下图)。 另外,是空心的与不空心的,又有啥区别,习惯了也没什么。
 楼主| 发表于 2021-6-23 17:14:09 | 显示全部楼层
waitthelove 发表于 2021-6-22 09:40
问下老大 2023 版本号改变没有还是基于2018 还是全新的版本
不好意思,我也只量看到邮件,也尝试过下载,但因为在外地,可能网络不好。下载一天也没能下栽下来,且貌似只能在浏览器中下载,结果多次下载仅不到50%就中断了。所以这个Alpha版到底啥样,得回去后才能下载了。
只能浏览器下载,建议换不同的时间段下载,我一般早上7:00左右速度飞快。  发表于 2021-6-24 16:53
发表于 2021-6-22 08:38:57 | 显示全部楼层
换汤不换药,没有啥革命性的变革
发表于 2021-6-22 09:19:46 | 显示全部楼层
也和微软光头啊三一样。玩版本号??
发表于 2021-6-22 09:40:26 | 显示全部楼层
发表于 2021-6-22 10:12:46 | 显示全部楼层
可怜我还是抱着CAD 2012不放。总觉得画二维图纸CAD 2012没有什么不方便的。虽然后面的版本,我也一直在关注。但是就我的认识里面,后面的版本对于画二维图的提升,可以说可有可无,反而是注册再复查了。嫌麻烦呢
建议升级到2020,还是有很多新特性的,而且激活方便。再往后,激活太麻烦。  发表于 2021-7-28 21:22
发表于 2021-6-22 12:48:42 | 显示全部楼层
10年画图狗表示08版很香,还可以再战5年
发表于 2021-6-22 16:30:18 | 显示全部楼层
文件越来越大,还不如2010好用
发表于 2021-6-22 16:31:19 | 显示全部楼层
好的功能还不如原来的好用,生成的文件小,运行也快
发表于 2021-6-22 17:16:44 | 显示全部楼层
没有记错的话,08版本的CAD不支持拖动填充夹点,增加,删除修改填充图案的边界形状。这个功能好像是从2010版本才有的。个人觉得08版还是差点火候
发表于 2021-6-22 21:14:46 | 显示全部楼层
2012版这前的版本,没有 viewbase 功能,就像吃饭没有菜。
GMT+8, 2025-5-17 11:08 , Processed in 0.177842 second(s), 29 queries , Gzip On.
