- 积分
- 11923
- 明经币
- 个
- 注册时间
- 2011-9-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2021-6-22 17:16:19
显示全部楼层
地方坐标系或者自定义坐标根据4参数多段线转经纬度文件TXT,经纬度为10进制,可以复制到KML文件用\n" "可以将手薄里面参与求控制点的WGS84经纬度换算成坐标\n" "然后用COORD笑脸软件求地方坐标--》WGS84坐标的4参数抄下来用113.47228431,22.986922997
113.472186361,22.986816298
113.472054915,22.986774606
113.4719921,22.986754673
113.471037673,22.984983334
113.471092087,22.984715313
113.470541912,22.985446895
113.470968935,22.985462633
113.471749262,22.986910865
113.471755997,22.986923274
113.471762811,22.986935665
113.471769664,22.98694801
113.471776604,22.986960328
113.471783612,22.98697261
113.471790689,22.986984865
113.471797844,22.986997093
113.471805047,22.987009266
113.471812319,22.987021422
113.471819678,22.987033532
113.471827087,22.987045624
113.471834553,22.987057671
113.471842108,22.987069681
113.47184972,22.987081638
113.471857401,22.987093585
113.471865131,22.987105478
113.471872949,22.987117353
113.471880815,22.987129182
113.471888769,22.987140957
113.471896772,22.987152715
113.471904843,22.987164427
113.471912982,22.987176102
113.47192117,22.987187742
113.471929445,22.987199327
113.471937769,22.987210886
113.471946172,22.987222408
113.471954613,22.987233894
113.471963142,22.987245325
113.471971719,22.987256721
 - ;;;功能:投影换带
- ;;作者:HUA
- ;;;创建日期:2020-8-18
- ;;;最后编辑日期:2020-8-20
- ;;;秒转度分秒 s->dd.mmss
- (defun Second2Dms(second / sign degree miniute second dms)
- (setq sign (< second 0)
- second (/ (abs second) 3600.0)
- degree (fix second)
- second (* (- second degree) 60.0)
- miniute (fix second)
- second (* (- second miniute) 60.0)
- dms (+ degree (/ miniute 100.0) (/ second 10000.0))
- (if sign (setq dms (- 0 dms)))
- dms
- ;;;角度转弧度 dd.mmss->rad
- (defun Dms2Rad(dms / sign degree miniute second rad)
- (setq sign (< dms 0)
- dms (abs dms)
- degree (fix dms)
- dms (* (- dms degree) 100)
- miniute (fix dms)
- second (* (- dms miniute) 100)
- rad (/ (* (+ degree (/ miniute 60.0) (/ second 3600.0)) PI) 180.0)
- (if sign (setq rad (- 0 rad)))
- rad
- ;;;弧度转角度 rad->dd.mmss
- (defun Rad2Dms(rad / sign degree miniute second dms)
- (setq sign (< rad 0)
- rad (abs rad)
- rad (/ (* rad 180.0) PI)
- degree (fix rad)
- rad (* (- rad degree) 60.0)
- miniute (fix rad)
- second (* (- rad miniute) 60.0)
- dms
- ;;;十进制角度转弧度 dd->rad
- (defun Degree2Rad(degree / sign rad)
- (setq sign (< degree 0)
- degree (abs degree )
- rad (/ (* degree PI) 180.0)
- rad
- ;;;十进制角度转DD.MMSS
- (DEFUN 10-DDMMSS ( A / B C D E )
- (SETQ B (Rad2Dms (Degree2Rad A)) )
- (setq c (fix b)) (setq d (fix(*(- b c) 100)))
- (setq e (- (* 10000 b) (* c 10000) (* d 100) ) )
- (strcat (rtos c 2 0) "度" (rtos d 2 0) "分" (rtos e 2 6) "秒")
- ;;;弧度转十进制角度 rad->dd
- (defun Rad2Degree(rad / sign degree)
- rad (abs rad)
- degree (/ (* rad 180.0) PI)
- (if sign (setq degree (- 0 degree)))
- degree
- ;;;54坐标系参数
- (defun PrjPoint_Krasovsky( / a f e2 e12 A1 A2 A3 A4 A5 A6 A7 tf )
- (setq a 6378245.0
- f 298.3
- tf (/ (- f 1) f)
- e2 (- 1 (* tf tf))
- tf (/ f (- f 1))
- e12 (- (* tf tf) 1)
- A1 6367558.4968749800000000
- A2 -16036.4802694116000000
- A3 16.8280668841393000
- A4 -0.0219753089548841
- A5 0.0000311310026601
- A6 -0.0000000459827472
- A7 0.0000000000679857
- (list a f e2 e12 A1 A2 A3 A4 A5 A6 A7)
- ;;;80坐标系参数
- (defun PrjPoint_IUGG1975(/ a f e2 e12 A1 A2 A3 A4 A5 A6 A7 tf)
- (setq a 6378140.0
- f 298.257
- tf (/ (- f 1) f)
- tf (/ f (- f 1))
- A1 6367452.1327884300000000
- A2 -16038.5282286966000000
- A3 16.8326464353061000
- A4 -0.0219844636486152
- A5 0.0000311484690908
- A6 -0.0000000460151868
- A7 0.0000000000680433
- ;;;2000坐标系参数
- (defun PrjPoint_2000(/ a f e2 e12 A1 A2 A3 A4 A5 A6 A7 tf)
- (setq a 6378137.0
- f 298.257222101
- tf (/ (- f 1) f)
- tf (/ f (- f 1))
- A1 6367449.1457710400000000
- A2 -16038.5087415914000000
- A3 16.8326134276660000
- A4 -0.0219844041401628
- A5 0.0000311483615430
- A6 -0.0000000460149936
- A7 0.0000000000680429
- ;;;BL转cadx,cady
- ;;;输入参数
- ;;;B,L为点位纬度和经度,单位为弧度
- ;;;L0为中央经线,单位为弧度
- ;;;prjType取值为0:北京54坐标系,1:西安80坐标系,2:CGCS2000坐标系
- ;;;输出CAD坐标x,y
- (defun PrjPoint:BL2xy(B L L0 prjType / a f e2 e12 A1 A2 A3 A4 A5 A6 A7 X N tanB tanB2 m m2 ng2 sinB cosB cadx cady)
- (cond
- ((= 0 prjType) (mapcar 'set (list 'a 'f 'e2 'e12 'A1 'A2 'A3 'A4 'A5 'A6 'A7) (PrjPoint_Krasovsky)))
- ((= 1 prjType) (mapcar 'set (list 'a 'f 'e2 'e12 'A1 'A2 'A3 'A4 'A5 'A6 'A7) (PrjPoint_IUGG1975)))
- ((= 2 prjType) (mapcar 'set (list 'a 'f 'e2 'e12 'A1 'A2 'A3 'A4 'A5 'A6 'A7) (PrjPoint_2000)))
- (T (alert "未知prjType参数值")(exit))
- (setq X (+ (* A1 B) (* A2 (sin (* 2 B))) (* A3 (sin (* 4 B))) (* A4 (sin (* 6 B))) (* A5 (sin (* 8 B))) (* A6 (sin (* 10 B))) (* A7 (sin (* 12 B))))
- sinB (sin B) cosB (cos B) tanB (/ (sin B) (cos B)) tanB2 (* tanB tanB)
- N (/ a (sqrt (- 1 (* e2 sinB sinB))))
- m (* cosB (- L L0)) m2 (* m m)
- ng2 (/ (* cosB cosB e2) (- 1 e2))
- cady (+ X (* N tanB (* (+ 0.5 (* (+ (/ (+ (- 5 tanB2) (* 9 ng2) (* 4 ng2 ng2)) 24.0) (/ (* (+ (- 61 (* 58 tanB2)) (* tanB2 tanB2)) m2) 72.0)) m2)) m2)))
- cadx (+ 500000 (* N m (+ 1 (* m2 (+ (/ (+ (- 1 tanB2) ng2) 6.0) (/ (* m2 (- (+ 5 (* tanB2 tanB2) (* 14 ng2)) (* 18 tanB2) (* 58 ng2 tanB2))) 120.0))))))
- (list cadx cady)
- ;;;cadx,cady转BL
- ;;;输入参数
- ;;;;pt为点位cad点坐标,
- ;;;L0为中央经线,单位为弧度
- ;;;输出经纬度B,L表,单位为dd.mmss
- (defun PrjPoint:xy2BL(pt L0 prjType / a f e2 e12 A1 A2 A3 A4 A5 A6 A7 sinB cosB tanB tanB2 N ng2 V yN preB0 B0 eta x y )
- (cond
- (setq x (cadr pt)
- y (- (car pt) 500000)
- B0 (/ x A1)
- eta 1
- (while (> eta 0.000000000048)
- (setq preB0 B0
- B0 (/ (- x (+ (* A2 (sin (* 2 B0))) (* A3 (sin (* 4 B0))) (* A4 (sin (* 6 B0))) (* A5 (sin (* 8 B0))) (* A6 (sin (* 10 B0))) (* A7 (sin (* 12 B0))))) A1)
- eta (abs (- B0 preB0))
- (setq sinB (sin B0)
- cosB (cos B0)
- tanB (/ (sin B0) (cos B0))
- tanB2 (* tanB tanB)
- V (sqrt (+ 1 ng2))
- yN (/ y N)
- B (- B0 (* (+ (- (* yN yN) (/ (* (- (+ 5 (* 3 tanB2) ng2) (* 9 ng2 tanB2)) yN yN yN yN) 12.0)) (/ (* (+ 61 (* 90 tanB2) (* 45 tanB2 tanB2)) yN yN yN yN yN yN) 360.0)) V V tanB 0.5))
- L (+ L0 (/ (+ (- yN (/ (* (+ 1 (* 2 tanB2) ng2) yN yN yN) 6.0 )) (/ (* (+ 5 (* 28 tanB2) (* 24 tanB2 tanB2) (* 6 ng2) (* 8 ng2 tanB2)) yN yN yN yN yN) 120.0)) cosB))
- (list (Rad2Dms B) (Rad2Dms L))
- ;;;cadx,cady转BL
- ;;;输入参数
- ;;;;pt为点位cad点坐标,
- ;;;L0为中央经线,单位为弧度
- ;;;输出经纬度B,L表,单位为十进制
- (defun PrjPoint:xy2BL2(pt L0 prjType / a f e2 e12 A1 A2 A3 A4 A5 A6 A7 sinB cosB tanB tanB2 N ng2 V yN preB0 B0 eta x y )
- (cond
- (setq x (cadr pt)
- B0 (/ x A1)
- eta 1
- (setq preB0 B0
- cosB (cos B0)
- yN (/ y N)
- (list (Rad2Degree L) (Rad2Degree B) )
- (defun vxs(e / p a b n ob q et d d1 en et)
- (setq a(entget e)ob(vlax-ename->vla-object e)et(cdr(assoc 0 a))n 0 p nil d nil)
- (cond((="LWPOLYLINE"et)
- (repeat(length a)(setq b (nth n a) n (+ n 1))
- (if (= 10 (car b))(progn
- (setq q(list (cadr b) (caddr b))d1(vlax-curve-getDistAtPoint ob q))
- (if p (if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
- (setq p (list q)))))))
- ((="POLYLINE"et)
- (SETQ EN (ENTGET (SETQ E (ENTNEXT E))))
- (WHILE (/= (CDR (ASSOC 0 EN)) "SEQEND")
- (SETQ q (CDR (ASSOC 10 EN))d1(vlax-curve-getDistAtPoint ob q)q(reverse(cdr(reverse q))))
- (if p(if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))(setq p(list q)))
- (SETQ EN (ENTGET (SETQ E (ENTNEXT E)))))
- (setq p(reverse p))))P)
- (defun zbzh ( pp aa kk / xx yy x0 y0 )
- (setq xx (cadr pp) yy (car pp) )
- (setq x0 (* (cos aa) (- (* xx kk) (* (/ (sin aa) (cos aa)) (* kk yy) ) ) ) )
- (setq y0 (+ (/ (* kk yy) (cos aa)) (* (/ (sin aa) (cos aa)) x0 ) ))
- (list (+ y0 (car syd)) (+ x0 (cadr syd)) )
- ;3、点表生成多段线
- (defun makepl (lst / pt)
- (entmake (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(8 . "ctpzx") (cons 90 (length lst)) (cons 70 129))
- (mapcar '(lambda (pt)(cons 10 pt)) lst ))
- (defun c:dflw-bl2000 ( / p l0 zb jwd syd aa kk xzb lll);;;地方坐标系或者自定义坐标根据4参数多段线转经纬度文件TXT,经纬度为10进制,可以复制到KML文件用
- (alert (strcat "地方坐标系或者自定义坐标根据4参数多段线转经纬度文件TXT,经纬度为10进制,可以复制到KML文件用\n" "可以将手薄里面参与求控制点的WGS84经纬度换算成坐标\n" "然后用COORD笑脸软件求地方坐标--》WGS84坐标的4参数抄下来用"))
- (vl-load-com)
- (setq l0 (getreal "\n请输入中央子午线经度dd.mmss:"))
- (setq p (car(entsel "\n请选择地方坐标系或者自定义坐标多段线:")))
- ;(setq pp '(62295.5790 17258.584))
- (setq syd'(454891.370478 2529629.687669 )) ;4参数x y位移人工输入
- (setq aa (Dms2Rad 0.0047650491)) ;4参数旋转参数人工输入dd.mmss
- (setq kk 1.00000515799711) ;4参数缩放比列因子人工输入
- (setq zb (vxs p))
- (setq lll '())
- (foreach y zb
- (setq lll (zbzh y aa kk))
- (setq xzb (cons lll xzb))
- (makepl xzb)
- (setq ffn (getfiled "选取/建立数据导出10进制经纬度文件" "" "txt" 1))
- (setq ff (open ffn "w"))
- (foreach x xzb
- (setq jwd (PrjPoint:xy2BL2 x (Dms2Rad l0) 2))
- (write-line (strcat (rtos (car jwd)2 9)","(rtos (cadr jwd)2 9)) ff)
- (close ff)
