查看: 2256|回复: 7
【关于CAD视口默认的比例列表】
发表于 2021-4-30 00:59:01 | 显示全部楼层 |阅读模式
1明经币
我在明经找了半天,只找到这个帖子,但是这个帖子一次只能新增一个视口比例。http://bbs.mjtd.com/forum.php?mod=viewthread&tid=180723&highlight=%B1%C8%C0%FD%C1%D0%B1%ED
我就在想能不能写一个列表,可以快速创建常用的视口比例,本人不会写lsp,所以只是生硬的凑了一个不太好用的代码。
希望各位大佬看看能不能再优化一下。1是若比例存在则覆盖(避免报错),2是能不能写一个list列表,或者用一个变量去代替,要不然代码太长了
--20221028--改写了一下:
  1. (defun C:SKBL (/ Old_Exp Old_Cmd)
  2.   (setq Old_Exp (getvar "expert"))(setq Old_Cmd (getvar "cmdecho"))
  3.   (setvar "expert" 5)(setvar "cmdecho" 0)
  4.   (command "undo" "be")
  5.       (command "-scalelistedit" "D" "*" "E")
  6.       (foreach XX
  7.         '("1:2" "1:3" "1:5" "1:6" "1:8" "1:10" "1:15" "1:20"
  8.           "1:25" "1:30""1:50" "1:60" "1:75" "1:80" "1:100"
  9.           "1:150" "1:200" "1:250" "1:300" "1:500"
  10.         );常用视口比例
  11.         (command "-scalelistedit" "A" XX XX "E")
  12.       )
  13.   (command "undo" "be")
  14.   (setvar "expert" Old_Exp)(setvar "cmdecho" Old_Cmd)
  15.   (princ "\n——★★★ 视口比例已更新 ★★★——")
  16.   (princ)
  17. )
最佳答案
查看完整内容
;;;新建常用比例列表-详图类 (defun c:TT() (setvar "cmdecho" 0);;;关闭命令提示 (command "-scalelistedit" "D" "*" "E" ) ;;;删除所有未使用的比例列表 (setvar "expert" 5) ;;;新建常用比例列表-详图类 (command "-scalelistedit" "A" "1:1" "1:1" "A" "1:2" "1:2" "A" "1:3" "1:3" "A" "1:4" "1:4" "A" "1:5" "1:5" "A" "1:8" "1:8" "A" "1:10" "1:10" "A" "1:15" "1:15" "A" "1:16" "1:16" "A" "1:20" "1: ...
参与人数 1金钱 +5 收起 理由
zilong136 + 5 很给力!
发表于 2021-4-30 00:59:02 | 显示全部楼层
;;;新建常用比例列表-详图类
(defun c:TT()
(setvar "expert" 5)
;;;新建常用比例列表-详图类
"A" "1:1" "1:1"
"A" "1:2" "1:2"
"A" "1:3" "1:3"
"A" "1:4" "1:4"
"A" "1:5" "1:5"
"A" "1:8" "1:8"
"A" "1:10" "1:10"
"A" "1:15" "1:15"
"A" "1:16" "1:16"
"A" "1:20" "1:20"
"A" "1:25" "1:25"
"A" "1:30" "1:30"
"A" "1:40" "1:40"
"A" "1:50" "1:50"
"A" "1:75" "1:75"
"A" "1:80" "1:80"
"A" "1:100" "1:100"
"E" )
(setvar "expert" 0)
(setvar "cmdecho" 1);;;打开命令提示
(princ "\n常用的比例列表添加完成!")
 楼主| 发表于 2021-5-1 00:03:37 | 显示全部楼层
aichong 发表于 2021-4-30 23:40
;;;新建常用比例列表-详图类
(defun c:TT()
妙啊,居然还有expert这种变量,学习了!!!
发表于 2023-5-23 21:50:20 | 显示全部楼层
创建视口比例,学习了!
发表于 2023-6-28 11:40:18 | 显示全部楼层
6,正是要 EXPERT 这个变量!
发表于 2024-2-25 08:35:23 | 显示全部楼层
必须支持下方便
发表于 2024-10-12 02:25:06 | 显示全部楼层
感谢大佬分享
发表于 2024-10-18 22:24:37 | 显示全部楼层
太有用了!!!!!
GMT+8, 2025-5-1 03:19 , Processed in 0.195600 second(s), 23 queries , Gzip On.
