查看: 1195|回复: 4
麻烦高手帮我整理一下以下字句,谢谢!
发表于 2021-4-21 14:52:17 | 显示全部楼层 |阅读模式
麻烦高手帮我整理一下以下字句,我不专业弄不来,谢谢!例如:("1" ("2" "3"  ("4"  ("5" ("6" ("7"))))))
表示:块“7”在块“6”中,块“6”在块“5”中,块“5”在块“4”中,块“4”,块“3”,块“2”,在块“1”中[code="lisp] ;;;作者:highflybird ;;;Main Function (defun c:BT (/ AllLst bkTree)   (setq *APP (vlax-get-acad-object))   (setq *DOC (vla-get-ActiveDocument *APP))   (setq *BLK (vla-get-blocks *DOC))   (vlax-for blk *BLK     (setq AllLst (cons (GetNestedName blk) AllLst))   )   (foreach n AllLst     (setq bkTree (cons (Tree (car n)) bkTree))   )   (princ bkTree)   ; Now BkTree is the return value, it's a blockDef tree.   (princ) ) ;;;Get all names of Nested Blocks in A blockDef (defun GetNestedName (blk / lst iName)   (vlax-for n blk     (if (or           (= (vla-get-objectname n) "AcDbBlockReference")           (= (vla-get-objectname n) "AcDbMInsertBlock")         )       (progn         (setq iName (vla-get-name n))         (if (not (member iName lst))           (setq lst (cons iName lst))         )       )     )   )   (cons (vla-get-name blk) lst) ) ;;;to Construct The BlockDef Tree (defun Tree (name / lst)   (foreach n (cdr (assoc name AllLst))     (setq lst (cons (Tree n) lst))   )   (if lst     (cons name (list lst))     name   ) )[/code][code="lisp] ;;;作者:Leeben (defun AllBlkNInBlkdef (blkn / blkdef e typ bn bnl e-l nl)   (setq ;bnl    '() blkdef (tblobjname "block" blkn)   )   (while (setq e (entnext blkdef))     (setq typ (cdr (assoc 0 (entget e))))     (if (= typ "INSERT")       (setq bn (vla-get-name (vlax-ename->vla-object e))      bnl (if bn     (cons (if (setq nl (AllBlkNInBlkdef bn))        (list bn nl)        bn      )      bnl     )   )       )     )     (setq blkdef e)   )   bnl ) (defun c:ABnInBl (/ i en ss blknlst ABblknlst)   (setq ss   (ssget '((0 . "INSERT"))) ;ABblknlst '()   )   (if ss     (repeat (setq i (sslength ss))       (setq en       (ssname ss (setq i (1- i)))      blkn      (vla-get-name (vlax-ename->vla-object en))      blknlst   (AllBlkNInBlkdef blkn)      ABblknlst (cons (if blknlst     (list blkn blknlst)     blkn          )          ABblknlst         )       )     )     (princ "*** 你没有选择任何图块 ***")   )   (princ ABblknlst) (princ) )[/code]
发表于 2021-4-22 14:32:20 | 显示全部楼层
不保证对,自己再调试下
  1. (defun c:BT (/ AllLst bkTree)
  2.   (setq *APP (vlax-get-acad-object))
  3.   (setq *DOC (vla-get-ActiveDocument *APP))
  4.   (setq *BLK (vla-get-blocks *DOC))
  5.   (vlax-for blk *BLK (setq AllLst (cons (GetNestedName blk) AllLst)))
  6.   (foreach n AllLst (setq bkTree (cons (Tree (car n)) bkTree)))
  7.   (princ bkTree) ; Now BkTree is the return value, it's a blockDef tree.
  8.   (princ)
  9. ) ;;;Get all names of Nested Blocks in A blockDef
  10. (defun GetNestedName (blk / lst iName)
  11.   (vlax-for n
  12.             blk
  13.             (if
  14.               (or (= (vla-get-objectname n) "AcDbBlockReference")
  15.                   (= (vla-get-objectname n) "AcDbMInsertBlock")
  16.               )
  17.               (progn (setq iName (vla-get-name n))
  18.                      (if (not (member iName lst)) (setq lst (cons iName lst)))
  19.               )
  20.             )
  21.   )
  22.   (cons (vla-get-name blk) lst)
  23. ) ;;;to Construct The BlockDef Tree
  24. (defun Tree (name / lst)
  25.   (foreach n (cdr (assoc name AllLst)) (setq lst (cons (Tree n) lst)))
  26.   (if lst (cons name (list lst)) name)
  27. )
  28. ;;;作者:Leeben
  29. (defun AllBlkNInBlkdef (blkn / blkdef e typ bn bnl e-l nl)
  30.   (setq  ;
  31.         bnl    '()
  32.         blkdef (tblobjname "block" blkn)
  33.   )
  34.   (while (setq e (entnext blkdef))
  35.     (setq typ (cdr (assoc 0 (entget e))))
  36.     (if (= typ "INSERT")
  37.       (setq bn  (vla-get-name (vlax-ename->vla-object e))
  38.             bnl (if bn
  39.                   (cons (if (setq nl (AllBlkNInBlkdef bn)) (list bn nl) bn) bnl)
  40.                 )
  41.       )
  42.     )
  43.     (setq blkdef e)
  44.   )
  45.   bnl
  46. )
  47. (defun c:ABnInBl (/ i en ss blknlst ABblknlst)
  48.   (setq ss  (ssget '((0 . "INSERT"))) ;ABblknlst
  49.         '()
  50.   )
  51.   (if ss
  52.     (repeat (setq i (sslength ss))
  53.       (setq en        (ssname ss (setq i (1- i)))
  54.             blkn      (vla-get-name (vlax-ename->vla-object en))
  55.             blknlst   (AllBlkNInBlkdef blkn)
  56.             ABblknlst (cons (if blknlst (list blkn blknlst) blkn) ABblknlst)
  57.       )
  58.     )
  59.     (princ "*** 你没有选择任何图块 ***")
  60.   )
  61.   (princ ABblknlst)
  62.   (princ)
  63. )
 楼主| 发表于 2021-4-22 14:53:46 | 显示全部楼层
AndyWang 发表于 2021-4-22 14:32
不保证对,自己再调试下
我这边运行提示语法错误。
发表于 2021-4-25 17:02:54 | 显示全部楼层
chenry676 发表于 2021-4-22 14:53
我这边运行提示语法错误。
去lisp里去调试下,错一般在封号断错位置。调试时修改下。
 楼主| 发表于 2021-4-26 09:04:27 | 显示全部楼层
不专业,不会调整哦,好像是不是有好几个组合在一起的,我要达到的是统计子块功能,原链接在这个地方http://bbs.mjtd.com/forum.php?mo ... hlight=%D7%D3%BF%E9
GMT+8, 2025-5-2 03:20 , Processed in 0.170255 second(s), 24 queries , Gzip On.
