查看: 20419|回复: 22
[2022] X-Force的AUTOCAD 2022 激活程序
发表于 2021-3-31 10:38:39 | 显示全部楼层 |阅读模式
Xforce的autodesk2022通用破解补丁,文件略大,无法上传附件,请从百度网盘下载。
链接:https://pan.baidu.com/s/1oWNeoTT0NJ7WUNyG8U-jDg
提取码:r787
以下为安装方法,我也没测试,谁有空可以研究一下。
1) Install Autodesk Application - Do Not Start it yet
2) Install the Autodesk network license manager (v11.18.0) from crack folder (nlm11.18.0.0_ipv4_ipv6_win64.msi)
    -Default install is "C:\Autodesk\Network License Manager"
    -Stop any running instance (lmgrd, adskflex) if you have one
    -Replace adskflex.exe by cracked one
3)  Stop Autodesk Desktop Licensing Service (use services.msc)
    -Replace C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\11.0.0.4854\AdskLicensingService\AdskLicensingService.exe by cracked one
    -Replace C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\AdskLicensingAgent.exe by cracked one
    -Replace C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\adlmint.dll by cracked one
    -Start Autodesk Desktop Licensing Service (use services.msc)
    To be safe, reboot machine or kill all adesk license instances if you already ran some Autodesk apps
4) Edit lic.dat and change HOSTNAME and MAC to suit your configuration (if you are not sure start LMTOOLS Utility and go to
   System Settings, your HOSTNAME and MAC will be listed)
   You can change vendor port too and add your previous licenses of course :)
   Save lic.dat where you want (we suggest to "C:\Autodesk\Network License Manager" folder)
5) You have 2 options:
    1)Start Network License Manager manually :
    Run the license manager with "lmgrd.exe -z -c lic.dat" from "C:\Autodesk\Network License Manager" folder
    Or
    2)Create a Service: (suggested)
     Start LMTOOLS Utility (lmtools.exe GUI) from "C:\Autodesk\Network License Manager" folder
   - in 'config services', add a "Autodesk' service name
                           choose C:\Autodesk\Network License Manager\lmgrd.exe for path to lmgrd
                           choose X:\path\where\you\saved\lic.dat for path to license file
                           choose a empty file to have debug logs (optional)
                           tick 'start server at power up' and 'use services'
                           Click Save
   - in 'service/license file' choose configuration using services and tick 'ignore license file path env var" (dont click that if you
                               you wanna use a ditributed licensing .. or you will have to edit or create a Licpath.lic file)
   - in 'start/stop/read' click 'start server'
                          click 'rereadlicense file'
   - in 'server status' click 'perform status enquiry'
                        check that you have 'adskflex: UP v11.18.0'
                        check features are activated : Users of 87545ACD_2022_0F:  (Total of 100 licenses issued;  Total of 0 licenses in use) for example
   - in 'server diags' check all featured can be checked out
   - check logs also win 'config services' if you configured it
7) Start Your Autodesk Application
   - When prompted select "Use a network license"
   - Select "Single license server"
   - Use 127.0.0.1, localhost or where the flexlm daemon is installed (syntax could be port@server).
TOTAL domination again for your pleasure
Smoke it!
You Could also set a distributed license system, having one machine serving them all
For that matter
you need to Set the ADSKFLEX_LICENSE_FILE environment variable on the client machine (the procedure varies depending on the operating system).
To set the environment variable
Use the procedure described for your operating system to set the environment variable:
For Windows 7/8/10:
    Right-click Computer and click Properties, or, in the Control Panel select System and Maintenance > System
    Click Advanced system settings and select the Advanced tab.
    Click Environment Variables.
    In the Environment Variables dialog box, under System Variables, click New.
    In the New System Variable dialog box, enter ADSKFLEX_LICENSE_FILE in the Variable Name field.
    In the Variable Value field, enter an at sign (@) followed by the host name of each license server to which you want to point the client. Separate each server name with a semicolon (;). For example:
    @server1;@server2;@server3
Dont forget to open your firewall, you may also need to check the LICPATH.LIC file in root of the installed application in case you have issues
If you still want to use 2018-19-20-21 applications, simply add their features with the corrected signature into our new lic.dat license file.
X-Force total domination again :)
发表于 2021-12-20 20:32:29 | 显示全部楼层
aichong 发表于 2021-3-31 12:41
这个是网络许可激活,比较麻烦一点
但激活后可以直接升级更新补丁,不用重新激活了
2019版刚出来的时候, ...
这个适用于CAD2022的网络激活吗?
发表于 2021-3-31 13:38:46 | 显示全部楼层
机器翻译加人工修正:
1) Install Autodesk Application - Do NotStart it yet
1)安装Autodesk应用程序-不要启动它
2) Install the Autodesk network licensemanager (v11.18.0) from crack folder (nlIm11.18.0.0_ipv4_ipv6_win64.msi)
2)从破解文件夹安装Autodesk网络许可证管理器(v11.18.0) (nlIm11.18.0.0_ipv4_ipv6_win64.msi)
-Default install is"C:Autodesk\Network License Manager"
-默认安装文件夹为“C:\Autodesk\Network LicenseManager”
-Stop any running instance (lmgrd, adskflex)if you have one
-如果有运行实例,停止任何运行实例(lmgrd,adskflx)
-用已破解的实例替换adskflex.exe
3) Stop Autodesk Desktop Licensing Service(use services.msc)
3)停止Autodesk桌面许可证服务(使用services.msc)
-ReplaceC:\Program Files (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingService\AdskLicensingService.exeby cracked one
-用破解文件替换C:\Program Files (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingService\AdskLicensingService.exe
-ReplaceC:\Program Files (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\AdskLicensingAgent.exe bycracked one
-用破解文件替换C:\Program Files (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\AdskLicensingAgent.exe
-Replace C:\Program Files (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\adlmint.dll by crackedone
-用破解文件替换C:\ProgramFiles (x86)\Common Files\AutodeskShared\AdskLicensing\11.0.0.4854\AdskLicensingAgent\adlmint.dll
-Start AutodeskDesktop Licensing Service (use services.msc)
-启动Autodesk桌面许可证服务(使用services.msc)
Tobe safe, reboot machine or kill all adesk license instances if you already ransome Autodesk apps
为了安全起见,如果您已经运行了一些Autodesk应用程序,请重新启动机器或关闭所有adesk许可实例。
4) Edit lic.dat and change HOSTNAME and MAC tosuit your configuration (if you are not sure start LMTOOLS Utility and go to
   System Settings, your HOSTNAME andMAC will be listed)
4)编辑lic.dat并更改主机名和MAC,以适应您的配置(如果您不确定启动LMTOOLSOLSUPOLY并转到系统设置,则将列出您的主机名和MAC)
   You can change vendor port too andadd your previous licenses of course :)
当然,您也可以更改供应商端口并添加以前的许可证:)
   Save lic.dat where you want (wesuggest to "C:\Autodesk\Network License Manager" folder)
将lic.dat保存在您想要的位置(我们建议将其保存在“C:\Autodesk\NetworkLicense Manager”文件夹中)
5)你有两个选择:
    1)Start Network License Managermanually :
1)手动启动网络许可证管理器:
    Run the license manager with"lmgrd.exe -z -c lic.dat" from "C:\Autodesk\Network LicenseManager" folder
使用“C:\Autodesk\Network LicenseManager”文件夹中的"lmgrd.exe -z -c lic.dat"命令,运行许可证管理器
    Or
或
2)创建服务:(建议)
     Start LMTOOLS Utility(lmtools.exe GUI) from "C:\Autodesk\Network License Manager" folder
从“C:\Autodesk\Network LicenseManager”文件夹启动LMTOOLS实用程序(Imtools.exe GUI图形界面)
   - in 'config services', add a"Autodesk' service name
-在“configservices【配置服务】”中,添加“Autodesk”服务名称
     choose C:\Autodesk\NetworkLicense Manager\lmgrd.exe for path to lmgrd
选择C:\Autodesk\NetworkLicense Manager\lmgrd.exe作为通往lmgrd的路径
    chooseX:\path\where\you\saved\lic.dat for path to license file
选择你已经保存所在路径的lic.dat作为许可证文件的路径
    choose a empty file to havedebug logs (optional)
选择一个具有调试日志的空文件(可选)
     tick 'start server atpower up' and 'use services'
勾选“start server at power up【在开机时启动服务】”和“use services【使用服务】”
    Click Save
单击“Save【保存】”
   - in 'service/license file' choose configurationusing services and tick 'ignore license file path env var" (dont clickthat if you
   you wanna use a ditributedlicensing .. or you will have to edit or create a Licpath.lic file)
-在“service/Licensefile【服务/许可文件】”中,选择使用服务的配置,并勾选“ignorelicense file path env var【忽略许可文件路径环境变量】”
(如果您想要使用分配许可..。否则,您将不得不编辑或创建一个licpath.ic文件)
   - in 'start/stop/read' click 'startserver'
-在“开始/停止/阅读”中单击“启动服务器”
单击“重新读取许可文件”
   - in 'server status' click 'performstatus enquiry'
-在“服务器状态”中单击“执行状态查询”
    check that you have'adskflex: UP v11.18.0'
检查你是否有'adskflex: UPv11.18.0'
    check features are activated: Users of 87545ACD_2022_0F:  (Total of 100 licensesissued;  Total of 0 licenses in use) for example
检查功能被激活:例如,87545ACD_2022_0F的用户(总共颁发了100许可证;正在使用的许可证总数)
   - in 'server diags' check allfeatured can be checked out
-“服务器对话框”中的所有功能都可以签出。
   - check logs also win 'configservices' if you configured it
-如果您配置了“配置服务”,检查日志也会赢得“配置服务”。
6) Start Your Autodesk Application
6)启动Autodesk应用程序
   - When prompted select "Use anetwork license"
-当提示选择“使用网络许可证”时
   - Select "Single licenseserver"
-选择“单一许可证服务器”
   - Use 127.0.0.1, localhost or wherethe flexlm daemon is installed (syntax could be port@server).
-使用127.0.0.1,本地主机或安装了Flexlm守护进程的地方(语法可以是port@server)。
Smoke it!
再一次完全控制你的快乐
吸一口吧!
YouCould also set a distributed license system, having one machine serving themall
您还可以设置一个分布式许可系统,让一台机器为它们提供全部服务。
Forthat matter
对于这个问题
youneed to Set the ADSKFLEX_LICENSE_FILE environment variable on the clientmachine (the procedure varies depending on the operating system).
您需要在客户端计算机上设置ADSKFLEX_LICENSE_FILE环境变量(过程因操作系统而异)
Toset the environment variable
设置环境变量
Usethe procedure described for your operating system to set the environmentvariable:
使用操作系统描述的过程设置环境变量:
ForWindows 7/8/10:
对于Windows 7/8/10:
Right-click Computer and click Properties, or, in the ControlPanel select System and Maintenance > System
  此电脑上点击鼠标右键,选择“属性”,或者,在控制面板中选择“系统和安全>系统”
  单击高级系统设置和选择高级选项卡。
点击环境变量
In the Environment Variables dialog box, under System Variables,click New.
在“环境变量”对话框的“系统变量”下,单击“新建”。
In the New System Variable dialog box, enter ADSKFLEX_LICENSE_FILEin the Variable Name field.
在“新建系统变量”对话框中,在“变量名称”字段中输入ADSKFLEX_LICENSE_FILE。
In the Variable Value field, enter an at sign (@) followed bythe host name of each license server to which you want to point the client.Separate each server name with a semicolon (;). For example:
变量值的字段中,输入at符号(@),其次你指定客户端是每个许可服务器的主机名,可以用分号隔开每个服务器名称(,)。例如:
Dontforget to open your firewall, you may also need to check the LICPATH.LIC filein root of the installed application in case you have issues
不要忘了打开防火墙,您可能还需要检查许可证路径安装应用程序根部的LICPATH.LIC文件,以防出现问题。
Ifyou still want to use 2018-19-20-21 applications, simply add their featureswith the corrected signature into our new lic.dat license file.
如果您仍然希望使用CAD 2018-19-20-21应用程序,只需在我们的新lic.dat许可文件中添加带有指定签名的特性即可。
X-Force再一次完全控制:)
发表于 2021-3-31 14:57:27 | 显示全部楼层
aichong 发表于 2021-3-31 13:38
机器翻译加人工修正:
1) Install Autodesk Application - Do NotStart it yet1)安装Autodesk应用程序-不 ...
今晚我发自动化工具省去99%烦恼
发表于 2021-3-31 10:51:10 | 显示全部楼层
谢谢楼主分享
发表于 2021-3-31 10:56:03 | 显示全部楼层
谢谢楼主分享
发表于 2021-3-31 10:58:53 | 显示全部楼层
感谢分享又一枚
发表于 2021-3-31 12:41:22 | 显示全部楼层
这个是网络许可激活,比较麻烦一点
2019版刚出来的时候,也是只有网络许可激活,注册机后面才出来的
AutoCAD2019网络许可授权破解文件及方法(详细图文教程)
发表于 2021-3-31 13:11:14 | 显示全部楼层
今晚就出GUI版
还好提前预载了相关功能
话说,2020及以上版本要不要直接强制锁定许可服务为最新的11版?要不然感觉文件会变得灰常大。。
发表于 2021-3-31 13:25:57 | 显示全部楼层
这个来了,支持
发表于 2021-3-31 15:40:47 | 显示全部楼层
网络激活已成功~!
GMT+8, 2025-5-17 11:37 , Processed in 0.191689 second(s), 28 queries , Gzip On.
