楼主: print1985
[资源] 输入法自动切换V2.5--2021.9.3更新2013-2022版
发表于 2025-3-7 22:22:46 | 显示全部楼层
网上找了一段,统计文本中英文数量切换;
  1. (vl-load-com)
  2. ; 修改为你的AganInp.dll路径(注意路径为双斜杠)
  3. (vl-cmdf "netload" "D:\\Support\\AganInp.dll")
  4. ; 快捷键定义
  5. (defun c:pz() (vl-cmdf "agpz")(princ)) ; 打开设置
  6. (defun c:gbs() (vl-cmdf "GC:UnloadInp")(princ)) ; 手动关闭输入法自动切换
  7. (defun c:dks() (vl-cmdf "GC:loadInp")(princ)) ; 手动打开输入法自动切换
  8. ; 文字内容
  9. (defun text-char-count (text / en-count zh-count char)
  10.   (setq en-count 0 zh-count 0)
  11.   (foreach char (explode text)
  12.     (if (wcmatch char "[a-zA-Z]")
  13.       (setq en-count (+ en-count 1))
  14.       (if (wcmatch char "[\\一-\\龥]")
  15.         (setq zh-count (+ zh-count 1))
  16.       )
  17.     )
  18.   )
  19.   (list en-count zh-count)
  20. )
  21. ; 鼠标双击事件处理器
  22. (defun double_click (a b / en end entype text en-count zh-count)
  23.   (if (setq en (nentselp (trans (car b) 0 1)))
  24.     (progn
  25.       (setq end (entget (car en)))
  26.       (setq entype (cdr (assoc 0 end)))
  27.       (if (wcmatch entype "*TEXT")
  28.         (progn
  29.           (setq text (cdr (assoc 1 end)))
  30.           (if (= entype "MTEXT")
  31.             (setq text (DK:mtext2text text))
  32.           )
  33.           ; 统计中英文字符
  34.           (setq (values en-count zh-count) (text-char-count text))
  35.           (if (> en-count zh-count)
  36.             (GC:cmdend "EN") ; 切换为英文
  37.             (GC:cmdstart "中文") ; 切换为中文
  38.           )
  39.         )
  40.       )
  41.     )
  42.   )
  43.   (princ)
  44. )
没有成功......
GMT+8, 2025-8-21 19:43 , Processed in 0.208175 second(s), 18 queries , Gzip On.
