查看: 2969|回复: 2
[2005] 为什么我的AutoCAD2005注册不了?
发表于 2004-3-22 12:03:00 | 显示全部楼层 |阅读模式
为什么我的AutoCAD2005注册不了?是不是生成的申请号的问题?
 楼主| 发表于 2004-3-22 15:05:00 | 显示全部楼层
搞定了。原来我把Request code拷贝到注册机里,但没拷全,所以没能生成Activation code。后来,手动输入Request code到注册机里才成功生成Activation code,所以成功注册了。我犯了个低级错误。 就我个人来看,AutoCAD2005不比2004“先进”到哪,却很占资源。我运行了N次,就有N-1次在打开时不久就没响应了。事实上2005的最低配置是RAM要256M的,我的机子只有128M。何况要安装2005,还得先安装Microsoft .NET Framework 1.1,其官方版本对2005的定义不过是R16.1。大家若为了新鲜,还是玩一把也无妨。 付——安装AutoCAD 2005 的最低系统配置: Before you install AutoCAD? on a stand-alone computer, make sure that your computer meets the minimum system requirements. See the following table for hardware and software requirements. Hardware and software requirements
Operating system 操作系统:
Windows? XP Professional Windows XP Home Windows XP Tablet PC Windows 2000 It is recommended that non-English language versions of AutoCAD be installed on an operating system with a user interface language that matches the code page of the AutoCAD language. A code page provides support for character sets used in different languages.
You must have administrator permissions or be granted elevated permissions by your system administrator to install AutoCAD.
Web browser 浏览器:
Microsoft Internet Explorer 6.0 with Service Pack 1 (or later)
Processor 处理器:
Pentium III or later 800 Mhz
RAM 内存:
256 MB
Video 显示:
1024 x 768 VGA with True Color (minimum) Requires a Windows-supported display adapter.
Hard disk 硬盘:
Installation 300 MB
Pointing device 定点设备:
Mouse, trackball, or other device
CD-ROM :
Any speed (for installation only)
Optional
hardware Open GL-compatible 3D video card Printer or plotter Digitizer Modem or access to an Internet connection Network interface card The OpenGL driver that comes with the 3D graphics card must have the following: Full support of OpenGL or later.
An OpenGL Installable Client Driver (ICD). The graphics card must have an ICD in its OpenGL driver software. The "miniGL" driver provided with some cards is not sufficient for use with AutoCAD.
发表于 2004-3-22 16:14:00 | 显示全部楼层
2005那有下载呀。谢谢!
GMT+8, 2025-5-19 05:47 , Processed in 0.146527 second(s), 25 queries , Gzip On.
