查看: 3090|回复: 9
(已解决)50元求修改代码~事成之后直接支付宝转账
发表于 2021-1-5 00:07:10 | 显示全部楼层 |阅读模式
[img][/img][img][/img]
小弟在网络上找到一个想在圆心替换图块后炸开~炸开后的文字大小比例可以选取图框(撷取图框比例)或直接输入比例所以 acx为一变量~卡关了~~烦请各位大大帮小弟修改一下感激不尽~谢谢~
以下有大大讲明不知我想要的成果因无法上传照片或档案到此~显示档案过大所以只能口述
请大大们只要一个图块框~加一个带有文字的图块~使用下面代码便知道成果了
麻烦大大们~再次感谢
附上我自行综合许多大大的源码修改成现用的源码
(defun ax:getboundingbox (entname / entpl entprptlist)
(vla-getboundingbox (vlax-ename->vla-object entname) 'entpl 'entpr)
  (setqptlist (mapcar 'vlax-safearray->list (list entpl entpr)))
  (mapcar'(lambda (x) (trans x 0 1)) ptlist)
(defun getentdxf (ent dxf)
  (cond
    ((= (typeent) 'ename)
      (cdr(assoc dxf (entget ent '("*"))))
    ((= (typeent) 'vla-object)
      (cdr(assoc dxf (entget (vlax-vla-object->ename ent) '("*"))))
(setq *en2obj* vlax-ename->vla-object)
(defun c:M3-TP (/ ss en elist p0 rad p1 sc entdataentgrp entname n ptlist scale GET IST)
(setvar"cmdecho" 0)
(command"._undo" "_begin")
(if (setq ss(ssget '((0 . "circle"))))
   (setq n-1)
   (repeat (sslengthss)
    (setq en(ssname ss (setq n (1+ n))))
    (setqelist (entget en))
    (setq pt(cdr (assoc '10 elist)))
     (entdelen)
     (command"insert" "C:\\lisp\\\工具选项板图块\\\攻牙\\\M3.dwg"pt "" "" "");;
     (command"explode" "l") ;炸开插入的图块
   );; repeat
  );;progn
);; if
  (if (setqentname (entsel "\n请选择图框"))
    (if (="INSERT" (getentdxf (car entname) 0))
       (command "zoom" "o" (car entname) "")
        (setqptlist (ax:getboundingbox (car entname)))
        (setqentgrp (ssget "W" (car ptlist) (cadr ptlist) '((8 ."*TEXT"))))
        (setqscale (vla-get-XScaleFactor (*en2obj* (car entname))))
       (repeat (setq n (sslength entgrp))
         (setq entname (ssname entgrp (setq n (1- n))))
         (cond
           ((wcmatch (getentdxf entname 0) "*TEXT")
             (vla-put-Height (*en2obj* entname) (* scale 3 (getvar"textsize") ))
(command"._undo" "_end")
(setvar"cmdecho" 1)
而自己又想增加的源码如下
(defun c:M4-TP (/ ss en elist p0 rad p1 sc entdataentgrp entname n ptlist scale  scaleget)
(setvar"cmdecho" 0)
   (setq n -1)
   (repeat(sslength ss)
     (entdelen)
     (command"insert" "C:\\lisp\\\工具选项板图块\\\攻牙\\\M4.dwg"pt "" "" "");;
   );; repeat
  );;progn
);; if
;以下想增加一个判断与手动输入比例
  (if (setqentname (entsel "\n请选择图框或输入比例"))
      (if (=scaleget nil)
                        (setq sc acx)
                        (setq sc  entname)
;以上想增加一个判断与手动输入比例
        (setq entgrp (ssget "W" (carptlist) (cadr ptlist) '((8 . "*TEXT"))))
          (cond
(setvar"cmdecho" 1)
发表于 2021-1-5 09:11:53 | 显示全部楼层
没太明白你要改什么比例,要改整个块的比例就在炸开前调整;要改文字大小的话先获取块的范围
 楼主| 发表于 2021-1-5 12:36:48 | 显示全部楼层
大大,我想做的事是想图块插入后炸开,而后开孔不变,开孔旁边注记的文字可以依图框比例或自行输入比例改变大小,如M5开孔为4.2旁边会注记M5 ,所以插入后4.2是不变的,变大的是M5这个文字,方便人阅读,目前我只能选图框方式不能输入比例,而点选图框也不尽人意,没点到图框的话就比例直接是1了,这不理想,当没点选到图框,应请重新点选,烦请大大帮忙
发表于 2021-1-6 13:52:14 | 显示全部楼层
wuwubaibai 发表于 2021-1-5 12:36
大大,我想做的事是想图块插入后炸开,而后开孔不变,开孔旁边注记的文字可以依图框比例或自行输入比例改 ...
你最好是以dwg文件的形式呈现你的想法。隔行如隔山,没明白你描述的具体功能。
发表于 2021-1-6 14:33:57 | 显示全部楼层
看不懂你想干嘛。。。
你直接上传个dwg文件,里面包含修改前的图,修改后的图,修改要求。这样别人才好帮助你修改程序。
发表于 2021-1-6 16:26:21 | 显示全部楼层
看后一脸懵逼
 楼主| 发表于 2021-1-6 21:05:42 | 显示全部楼层
大大~不是我不想上传照片及档案~是传不上论坛~用过1台笔电2台桌电..2支手机..1台ipad均无法上传成功~连照片都传不上呀
 楼主| 发表于 2021-1-6 21:07:04 | 显示全部楼层
fl202 发表于 2021-1-6 14:33
看不懂你想干嘛。。。
你直接上传个dwg文件,里面包含修改前的图,修改后的图,修改要求。这样别人才好帮 ...
大大~无法上传档案及照片~都显示档案太大~就算1K也传不上..所以只好文字说明
发表于 2021-1-7 23:54:31 | 显示全部楼层
没看明白大大要的是啥东西
发表于 2025-2-19 17:29:20 | 显示全部楼层
技术强大学习了
GMT+8, 2025-4-30 22:52 , Processed in 0.207721 second(s), 23 queries , Gzip On.
