- 积分
- 24096
- 明经币
- 个
- 注册时间
- 2016-5-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
网上下载的代码,可惜不能炸开ACAD_PROXY_ENTITY对象。
 - using System;
- using System.Collections.Generic;
- using System.Linq;
- using System.Text;
- using Autodesk.AutoCAD.Runtime;
- using Autodesk.AutoCAD.EditorInput;
- using Autodesk.AutoCAD.DatabaseServices;
- using Autodesk.AutoCAD.ApplicationServices;
- namespace ExplodeProxyMgd
- public class ExplodeProxy
- /// <summary>
- /// Explode proxy entity to blockreference
- /// Return string name of blockreference in drawing database
- /// </summary>
- /// <param name="rbArgs">Lisp arguments: entity objectId, string BlockPrefix</param>
- /// <returns>string BlockReference name</returns>
- [LispFunction("proxy-explode-to-block")]
- public static TypedValue ProxyExplodeToBlock(ResultBuffer rbArgs)
- Document doc = Application.DocumentManager.MdiActiveDocument;
- Database db = doc.Database;
- Editor ed = doc.Editor;
- TypedValue res = new TypedValue((int)LispDataType.Text,"");
- if (rbArgs.AsArray().Length == 2)
- TypedValue entity = rbArgs.AsArray()[0];
- TypedValue blkPrefix = rbArgs.AsArray()[1];
- if ((entity.TypeCode == (int)LispDataType.ObjectId) && (blkPrefix.TypeCode == (int)LispDataType.Text))
- using (Transaction tr = doc.TransactionManager.StartTransaction())
- try
- ObjectId id = (ObjectId)entity.Value;
- DBObjectCollection objs = new DBObjectCollection();
- BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
- Entity entx = (Entity)tr.GetObject(id, OpenMode.ForWrite);
- entx.Explode(objs);
- string blkName = blkPrefix.Value.ToString() + entx.Handle.ToString();
- if (bt.Has(blkName) == false)
- BlockTableRecord btr = new BlockTableRecord();
- btr.Name = blkName;
- bt.UpgradeOpen();
- ObjectId btrId = bt.Add(btr);
- tr.AddNewlyCreatedDBObject(btr, true);
- foreach (DBObject obj in objs)
- Entity ent = (Entity)obj;
- btr.AppendEntity(ent);
- tr.AddNewlyCreatedDBObject(ent, true);
- res = new TypedValue((int)LispDataType.Text, blkName);
- tr.Commit();
- catch (Autodesk.AutoCAD.Runtime.Exception ex)
- tr.Abort();
- ed.WriteMessage(ex.Message);
- return res;
- /// <summary>
- /// Explode proxy entity in place
- /// </summary>
- /// <param name="rbArgs">entity name</param>
- [LispFunction("proxy-explode-in-place")]
- public static void ProxyExplodeInPlace(ResultBuffer rbArgs)
- if (rbArgs.AsArray().Length == 1)
- TypedValue entity = rbArgs.AsArray().First();
- if (entity.TypeCode == (int)LispDataType.ObjectId)
- try
- entx.Erase();
- BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
- tr.Commit();
- tr.Abort();
