查看: 1376|回复: 0
关于com方式添加菜单
发表于 2020-11-14 20:55:57 | 显示全部楼层 |阅读模式
addMenuThroughMfcCom()
    TRY
        CAcadApplication IAcad(acedGetAcadWinApp()->GetIDispatch(TRUE));
        CAcadMenuBar IMenuBar(IAcad.get_MenuBar());
        long numberOfMenus;
        numberOfMenus = IMenuBar.get_Count();
                acutPrintf(L"numberOfMenus=%d",numberOfMenus);
        CAcadMenuGroups IMenuGroups(IAcad.get_MenuGroups());
        VARIANT index;
        VariantInit(&index);
        V_VT(&index) = VT_I4;
        V_I4(&index) = 0;
        CAcadMenuGroup IMenuGroup(IMenuGroups.Item(index));
        CAcadPopupMenus IPopUpMenus(IMenuGroup.get_Menus());
        CString cstrMenuName = _T("AsdkComAccess");
        V_VT(&index) = VT_BSTR;
        V_BSTR(&index) = cstrMenuName.AllocSysString();
        IDispatch* pDisp=NULL;
                //see if the menu is already there
        TRY{pDisp = IPopUpMenus.Item(index); pDisp->AddRef();} CATCH(COleDispatchException,e){}END_CATCH;
        if (pDisp==NULL) {
            //create it
            CAcadPopupMenu IPopUpMenu(IPopUpMenus.Add(cstrMenuName));
            V_I4(&index) = 0;
            IPopUpMenu.AddMenuItem(index, _T("&Add A ComCircle"), _T("_AsdkMfcComCircle "));
            V_I4(&index) = 1;
            IPopUpMenu.AddSeparator(index);
            V_I4(&index) = 2;
            IPopUpMenu.AddMenuItem(index, _T("Auto&LISP Example"), _T("(prin1 \"Hello\") "));
            pDisp = IPopUpMenu.m_lpDispatch;
            pDisp->AddRef();
                CAcadPopupMenu IPopUpMenu(pDisp);
        if (!IPopUpMenu.get_OnMenuBar())
            V_I4(&index) = numberOfMenus +1;;
            IPopUpMenu.InsertInMenuBar(index);
        else
            IPopUpMenus.RemoveMenuFromMenuBar(index);
                        VariantClear(&index);
                pDisp->Release();
        e->ReportError();
        e->Delete();
    END_CATCH;
这是objectarx带的添加菜单的例子,它在menugroups 中序号为0的menugroup菜单组中添加下拉菜单。而序号为0的menugroup是custom,不是Acad(menuload可以查看到),当前菜单是acad.cui,为什么上面的代码仍然起作用,添加进去了(添加进acad并显示,而不是显示custom.cui)
GMT+8, 2025-5-1 04:13 , Processed in 0.308355 second(s), 24 queries , Gzip On.
