查看: 979|回复: 0
[基础] vs c#用向导创建程序问题
发表于 2020-11-11 20:21:44 | 显示全部楼层 |阅读模式
vs为2012 cad为2016 通过向导创建应用程序,在调试时为什么cad2016不能自动新建图形,并且自动加载我的dll程序。我看官方写的是要创建图形及自动加载dll的。  下面是调试启动CAD时的输出内容'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_64\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AcdbMgd.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\adui20.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AdUiPalettes.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_64\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AdApplicationFrame.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AdWindows.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\zh-CN\AdWindows.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsFormsIntegration\v4.0_4.0.0.0__31bf3856ad364e35\WindowsFormsIntegration.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework.Aero2\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Aero2.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationCore.resources\v4.0_4.0.0.0_zh-Hans_31bf3856ad364e35\PresentationCore.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\accoremgd.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\acmgd.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AcWindows.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework.resources\v4.0_4.0.0.0_zh-Hans_31bf3856ad364e35\PresentationFramework.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\zh-CN\AcWindows.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AcCui.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework-SystemXml\v4.0_4.0.0.0__b77a5c561934e089\PresentationFramework-SystemXml.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework.Aero\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Aero.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\mscorlib.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\mscorlib.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.resources\v4.0_4.0.0.0_zh-Hans_b77a5c561934e089\System.resources.dll'
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='ToolBarCustomizeButton' (HashCode=13531531); target element is 'ToolBarToggleButton' (Name='mCustomizeButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='ToolBarCustomizeButton' (HashCode=13531531); target element is 'RibbonItemControl' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='InfoCenterTextBox' (HashCode=44915976); target element is 'RibbonItemControl' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='InfoCenterTextBox' (HashCode=44915976); target element is 'Button' (Name='PART_AcceptButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='WebServicesLoginButton' (HashCode=62705275); target element is 'LoginButtonRibbonItemControl' (Name='mContainer'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='StayConnectedButton' (HashCode=54115834); target element is 'RibbonItemControl' (Name='mContainer'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='StayConnectedButton' (HashCode=54115834); target element is 'MenuToggleButton' (Name='mDropDownButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='StayConnectedButton' (HashCode=54115834); target element is 'RibbonListButtonListBox' (Name='PART_ListButtonList'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='RibbonToggleButton' (HashCode=26818564); target element is 'RibbonItemControl' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='WebServicesLoginButton' (HashCode=62705275); target element is 'WebservicesLoginButtonControl' (Name='mDropDownButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='WebServicesLoginButton' (HashCode=62705275); target element is 'RibbonListButtonListBox' (Name='PART_ListButtonList'); target property is 'Name' (type 'String')
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationUI\v4.0_4.0.0.0__31bf3856ad364e35\PresentationUI.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationUI.resources\v4.0_4.0.0.0_zh-Hans_31bf3856ad364e35\PresentationUI.resources.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml.Linq\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.Linq.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework-SystemXmlLinq\v4.0_4.0.0.0__b77a5c561934e089\PresentationFramework-SystemXmlLinq.dll'
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mToggleButton'. BindingExpressionno path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'PlacementTarget' (type 'FrameworkElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mToggleButton'. BindingExpressionno path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'ActivationTarget' (type 'FrameworkElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mText'. BindingExpressionno path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'PlacementTarget' (type 'FrameworkElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mText'. BindingExpressionno path); DataItem=null; target element is 'RibbonItemControl' (Name=''); target property is 'ActivationTarget' (type 'FrameworkElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Windows.RibbonControl', AncestorLevel='1''. BindingExpression:Path=ItemOrientation; DataItem=null; target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Windows.RibbonControl', AncestorLevel='1''. BindingExpression:Path=IsItemTextVisible; DataItem=null; target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mDropDownButtonBuddy'. BindingExpression:Path=IsEnabled; DataItem=null; target element is 'MenuToggleButton' (Name='mDropDownButton'); target property is 'IsEnabled' (type 'Boolean')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mDock'. BindingExpressionno path); DataItem=null; target element is 'RibbonListButtonPopup' (Name='mFlyoutPopup'); target property is 'PlacementTarget' (type 'UIElement')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'ElementName=mDropDownButtonBuddy'. BindingExpression:Path=IsEnabled; DataItem=null; target element is 'WebservicesLoginButtonControl' (Name='mDropDownButton'); target property is 'IsEnabled' (type 'Boolean')
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\ProgramData\Autodesk\ApplicationPlugins\AutoCAD2016Addin.bundle\Contents\Win64\BIM360GlueAutoCAD2016Addin.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\ProgramData\Autodesk\ApplicationPlugins\AutoCAD2016Addin.bundle\Contents\Win64\BIM360GlueAddinsCommon.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\ProgramData\Autodesk\ApplicationPlugins\AutoCAD2016Addin.bundle\Contents\Win64\log4net.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files (x86)\Autodesk\ApplicationPlugins\Autodesk FeaturedApps.bundle\Contents\Windows\2016\Win64\FeaturedAppsPlugin.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework-SystemCore\v4.0_4.0.0.0__b77a5c561934e089\PresentationFramework-SystemCore.dll'
'acad.exe' (Managed (v4.0.30319)): Loaded 'Anonymously Hosted DynamicMethods Assembly'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Windows\Microsoft.Net\assembly\GAC_MSIL\UIAutomationTypes\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationTypes.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'ContextualTabSelectorRules'
System.Windows.Data Error: 40 : BindingExpression path error: 'ApplicationMenuButtonBorderBrush' property not found on 'object' ''RibbonControl' (Name='')'. BindingExpression:Path=ApplicationMenuButtonBorderBrush; DataItem='RibbonControl' (Name=''); target element is 'RibbonApplicationMenuButton' (Name=''); target property is 'BorderBrush' (type 'Brush')
System.Windows.Data Error: 40 : BindingExpression path error: 'ApplicationMenuButtonBackground' property not found on 'object' ''RibbonControl' (Name='')'. BindingExpression:Path=ApplicationMenuButtonBackground; DataItem='RibbonControl' (Name=''); target element is 'RibbonApplicationMenuButton' (Name=''); target property is 'Background' (type 'Brush')
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\Microsoft.Expression.Interactions.dll'
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=62435929)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=62435929); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=62435929)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=62435929); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=6295248)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=6295248); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=6295248)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=6295248); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=57334375)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=57334375); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=57334375)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=57334375); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=29774863)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=29774863); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=29774863)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=29774863); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=42234223)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=42234223); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=42234223)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=42234223); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=103599)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=103599); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=103599)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=103599); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=51573880)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=51573880); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=51573880)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=51573880); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=52265969)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=52265969); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=52265969)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=52265969); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=4020931)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=4020931); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=4020931)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=4020931); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Id' property not found on 'object' ''RibbonPanel' (HashCode=35488221)'. BindingExpression:Path=Id; DataItem='RibbonPanel' (HashCode=35488221); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'AutomationName' property not found on 'object' ''RibbonPanel' (HashCode=35488221)'. BindingExpression:Path=AutomationName; DataItem='RibbonPanel' (HashCode=35488221); target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='RibbonMenuButton' (HashCode=43285665); target element is 'RibbonMinimizeExecuteButton' (Name='mMinimizeButtonExecute'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='RibbonMenuButton' (HashCode=43285665); target element is 'RibbonMinimizeExecuteButton' (Name='mMinimizeButtonExecute'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='RibbonMenuButton' (HashCode=43285665); target element is 'RibbonMinimizeToggleButton' (Name='mMinimizeButtonFlyout'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='RibbonMenuButton' (HashCode=43285665); target element is 'RibbonMinimizeToggleButton' (Name='mMinimizeButtonFlyout'); target property is 'Name' (type 'String')
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='13265486'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='13265486'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='8457374'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='8457374'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='35425694'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='35425694'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='12791742'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='12791742'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='1041149'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='1041149'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='40212317'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='40212317'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='62013962'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='62013962'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='26008214'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='26008214'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='14327361'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='14327361'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='61126266'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='21061526'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='52280510'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Private.Windows.RibbonPanelControl'; TargetElement.HashCode='21061526'; TargetElement.Type='Autodesk.Private.Windows.RibbonPanelControl'
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='DialogLauncher' (HashCode=17897732); target element is 'DialogLauncherButton' (Name=''); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='DialogLauncher' (HashCode=17897732); target element is 'DialogLauncherButton' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsChecked' property not found on 'object' ''ContentPresenter' (Name='mDialogLauncher')'. BindingExpression:Path=IsChecked; DataItem='ContentPresenter' (Name='mDialogLauncher'); target element is 'DialogLauncherButton' (Name='mButton'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='DialogLauncher' (HashCode=33647865); target element is 'DialogLauncherButton' (Name=''); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='DialogLauncher' (HashCode=33647865); target element is 'DialogLauncherButton' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Orientation' property not found on 'object' ''RibbonCompositeItem' (HashCode=47203227)'. BindingExpression:Path=Orientation; DataItem='RibbonCompositeItem' (HashCode=47203227); target element is 'RibbonItemControl' (Name='mRibbonItemControl'); target property is 'Orientation' (type 'Orientation')
System.Windows.Data Error: 40 : BindingExpression path error: 'Orientation' property not found on 'object' ''RibbonCombo' (HashCode=37524445)'. BindingExpression:Path=Orientation; DataItem='RibbonCombo' (HashCode=37524445); target element is 'RibbonItemControl' (Name='mRibbonItemControl'); target property is 'Orientation' (type 'Orientation')
System.Windows.Data Error: 40 : BindingExpression path error: 'Text' property not found on 'object' ''NewDataItem' (HashCode=20131258)'. BindingExpression:Path=Text; DataItem='NewDataItem' (HashCode=20131258); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Orientation' property not found on 'object' ''RibbonCombo' (HashCode=10599309)'. BindingExpression:Path=Orientation; DataItem='RibbonCombo' (HashCode=10599309); target element is 'RibbonItemControl' (Name='mRibbonItemControl'); target property is 'Orientation' (type 'Orientation')
System.Windows.Data Error: 40 : BindingExpression path error: 'Text' property not found on 'object' ''NewDataItem' (HashCode=58585662)'. BindingExpression:Path=Text; DataItem='NewDataItem' (HashCode=58585662); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Orientation' property not found on 'object' ''RibbonCompositeItem' (HashCode=59402334)'. BindingExpression:Path=Orientation; DataItem='RibbonCompositeItem' (HashCode=59402334); target element is 'RibbonItemControl' (Name='mRibbonItemControl'); target property is 'Orientation' (type 'Orientation')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Id; DataItem='RibbonButton' (HashCode=51005947); target element is 'ComboButton' (Name='mButton'); target property is 'AutomationId' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Orientation' property not found on 'object' ''RibbonCombo' (HashCode=20877354)'. BindingExpression:Path=Orientation; DataItem='RibbonCombo' (HashCode=20877354); target element is 'RibbonItemControl' (Name='mRibbonItemControl'); target property is 'Orientation' (type 'Orientation')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsEnabled' property not found on 'object' ''NewDataItem' (HashCode=56631376)'. BindingExpression:Path=IsEnabled; DataItem='NewDataItem' (HashCode=56631376); target element is 'Border' (Name=''); target property is 'IsEnabled' (type 'Boolean')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsVisible' property not found on 'object' ''NewDataItem' (HashCode=56631376)'. BindingExpression:Path=IsVisible; DataItem='NewDataItem' (HashCode=56631376); target element is 'Border' (Name=''); target property is 'Visibility' (type 'Visibility')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='ToolBarCustomizeButton' (HashCode=9514038); target element is 'ToolBarToggleButton' (Name='mCustomizeButton'); target property is 'Name' (type 'String')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=AutomationName; DataItem='ToolBarCustomizeButton' (HashCode=9514038); target element is 'RibbonItemControl' (Name=''); target property is 'Name' (type 'String')
System.Windows.Data Error: 40 : BindingExpression path error: 'Current' property not found on 'object' ''QuickAccessUndoControl' (HashCode=18775539)'. BindingExpression:Path=Current; DataItem='QuickAccessUndoControl' (HashCode=18775539); target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Current' property not found on 'object' ''QuickAccessRedoControl' (HashCode=27960000)'. BindingExpression:Path=Current; DataItem='QuickAccessRedoControl' (HashCode=27960000); target element is 'ContentPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'IsFileTabPreview' property not found on 'object' ''FileTabsData' (HashCode=35531307)'. BindingExpression:Path=DocumentGallery.IsFileTabPreview; DataItem='DataSource' (HashCode=36319151); target element is 'AutoScrollListBox' (Name='ModelLayoutPreviewListBox'); target property is 'Visibility' (type 'Visibility')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Value; DataItem='ByLayerColorMonitor' (HashCode=20970634); target element is 'SolidColorBrush' (HashCode=54517980); target property is 'Color' (type 'Color')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Value; DataItem='ByLayerColorMonitor' (HashCode=20970634); target element is 'SolidColorBrush' (HashCode=20899776); target property is 'Color' (type 'Color')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Value; DataItem='ByLayerColorMonitor' (HashCode=20970634); target element is 'SolidColorBrush' (HashCode=53880264); target property is 'Color' (type 'Color')
System.Windows.Data Error: 5 : Value produced by BindingExpression is not valid for target property.; Value='<null>' BindingExpression:Path=Value; DataItem='ByLayerColorMonitor' (HashCode=20970634); target element is 'SolidColorBrush' (HashCode=15160332); target property is 'Color' (type 'Color')
System.Windows.Data Error: 40 : BindingExpression path error: 'Lineweight' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.Lineweight; DataItem='DataBindings' (HashCode=61525259); target element is 'RibbonComboBindings' (HashCode=20019172); target property is 'Current' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Lineweight' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.Lineweight; DataItem='DataBindings' (HashCode=61525259); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'SelectedItem' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'LineType' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.LineType; DataItem='DataBindings' (HashCode=61525259); target element is 'RibbonComboBindings' (HashCode=622761); target property is 'Current' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'LineType' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.LineType; DataItem='DataBindings' (HashCode=61525259); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'SelectedItem' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Layer' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.Layer; DataItem='DataBindings' (HashCode=61525259); target element is 'RibbonComboBindings' (HashCode=7220417); target property is 'Current' (type 'Object')
System.Windows.Data Error: 40 : BindingExpression path error: 'Layer' property not found on 'object' ''EffectiveProperties' (HashCode=24258768)'. BindingExpression:Path=EffectivePropertySource.EffectiveProperties.Layer; DataItem='DataBindings' (HashCode=61525259); target element is 'ComboBoxControl' (Name='mComboBox'); target property is 'SelectedItem' (type 'Object')
System.Windows.ResourceDictionary Warning: 9 : Resource not found; ResourceKey='AcDrawingTabCloseButtonStyle'
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpressionno path); DataItem=null; target element is 'RibbonMinimizeExecuteButton' (Name='mMinimizeButtonExecute'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpressionno path); DataItem=null; target element is 'RibbonMinimizeToggleButton' (Name='mMinimizeButtonFlyout'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpressionno path); DataItem=null; target element is 'KeyboardActivatableToggleButton' (Name='PART_CollapsedPanelButton'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Windows.RibbonItemControl', AncestorLevel='1''. BindingExpression:Path=Size; DataItem=null; target element is 'TextBlockWithToolTip' (Name='mCollapsedPanelText'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpression:Path=; DataItem=null; target element is 'TextBlockWithToolTip' (Name='mCollapsedPanelText'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Internal.Windows.RibbonPanelFrame', AncestorLevel='1''. BindingExpression:Path=ShowSlideOutPanelAbove; DataItem=null; target element is 'RibbonPanelControl' (Name='mPanelControl'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.RibbonSlideOutPanelPopup', AncestorLevel='1''. BindingExpression:Path=IsOpen; DataItem=null; target element is 'PanelTitleBar' (Name='PART_PanelTitleBar'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpression:Path=; DataItem=null; target element is 'TextBlockWithToolTip' (Name='mText'); target property is 'NoTarget' (type 'Object')
System.Windows.Data Error: 4 : Cannot find source for binding with reference 'RelativeSource FindAncestor, AncestorType='Autodesk.Private.Windows.ToolBars.ToolBarControl', AncestorLevel='1''. BindingExpression:Path=IsVisible; DataItem=null; target element is 'ImageControl' (Name='mImage'); target property is 'NoTarget' (type 'Object')
The thread '<No Name>' (0x2a10) has exited with code 0 (0x0).
'acad.exe' (Managed (v4.0.30319)): Loaded 'AcLivePreviewContext'
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\AcLayer.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'acad.exe' (Managed (v4.0.30319)): Loaded 'C:\Program Files\Autodesk\AutoCAD 2016\zh-CN\AcLayer.resources.dll'
The thread '<No Name>' (0x450) has exited with code 0 (0x0).
GMT+8, 2025-5-1 14:40 , Processed in 0.203524 second(s), 26 queries , Gzip On.
