查看: 1390|回复: 2
(求助)如何框选实现黑体或其它字体水平及垂直居中于矩形框
发表于 2020-10-16 08:57:26 | 显示全部楼层 |阅读模式
请教一下各位大神,我在论坛上找了文字对齐的插件,然后,没有看到过水平及垂直居中的插件,也试过自己去尝试去修改,然后没有成功,所以特来请教各位大神,如何实现?
只想要一个功能把“水平居中x轴\垂直居中y轴”结合起来,1.选择需要居中的文字:     2.选择需要居中的矩形:         最终结果就是文字居中于矩形框内
谢谢各位大神了
下面是参考的代码及原贴链接:
http://bbs.mjtd.com/thread-179101-2-1.html
(defun process (amode / apnt apnt_x apnt_y count objname vlaxobj MinPoint MaxPoint
        minext maxext ext_l ext_r ext_m ext_vt ext_vd ext_vm tpnt)
         (setq oldcmdecho (getvar "cmdecho"))
         (setvar "cmdecho" 0)
         (setq selobjs (ssget))
         (if (or (not selobjs) (= (sslength selobjs) 1))
                 (princ "\n你必须选定两个或两个以上的对象")
         (initget 1)
         (setq apnt (getpoint "\n选择对齐点:"))
         (setq apnt_x (car apnt)
                 apnt_y (cadr apnt))
         (vl-load-com)
         (setq count 0)
         (repeat (sslength selobjs)
                 (setq objname (ssname selobjs count))
                 (setq vlaxobj (vlax-ename->vla-object objname))
                 (setq MinPoint (vlax-make-variant))
                 (setq MaxPoint (vlax-make-variant))
                 (vla-GetBoundingBox vlaxobj 'MinPoint 'MaxPoint)
                 (setq minext (vlax-safearray->list MinPoint))
                 (setq maxext (vlax-safearray->list MaxPoint))
                 (setq ext_l (car minext))
                 (setq ext_r (car maxext))
                 (setq ext_m (+ (/ (abs (- ext_l ext_r)) 2) ext_l))
                 (setq ext_vd (cadr minext))
                 (setq ext_vt (cadr maxext))
                 (setq ext_vm (+ (/ (abs (- ext_vt ext_vd)) 2) ext_vd))
                 (cond
                         ((= amode "HL") (setq tpnt (list ext_l apnt_y)))
                         ((= amode "HM") (setq tpnt (list ext_m apnt_y)))
                         ((= amode "HR") (setq tpnt (list ext_r apnt_y)))
                         ((= amode "VT") (setq tpnt (list apnt_x ext_vt)))
                         ((= amode "VM") (setq tpnt (list apnt_x ext_vm)))
                         ((= amode "VD") (setq tpnt (list apnt_x ext_vd)))
                 (if tpnt (command "_move" objname "" "non" tpnt "non" apnt))
                 (setq count (1+ count))
         (setvar "cmdecho" oldcmdecho)
(defun c:ad ()
         (if (> (setq dcl_id (load_dialog (setq Dcl_File (Write_Dcl_dq)))) 0)
                         (vl-file-delete Dcl_File);加载后删除DCL文件
                        (if (new_dialog "dq" dcl_id "")
                                         (action_tile "hl" "(done_dialog 1)")
                                         (action_tile "hm" "(done_dialog 2)")
                                         (action_tile "hr" "(done_dialog 3)")
                                         (action_tile "vt" "(done_dialog 4)")
                                         (action_tile "vm" "(done_dialog 5)")
                                         (action_tile "vd" "(done_dialog 6)")
                                         (action_tile "cancel" "(done_dialog 0)")
                                         (setq re (start_dialog))
                                 (princ "\n无法显示对话框!")
                         (unload_dialog dcl_id)
                 (princ "\n无法加载对话框!")
         (cond
                 ((= re 1) (process "HL"))
                 ((= re 2) (process "HM"))
                 ((= re 3) (process "HR"))
                 ((= re 4) (process "VT"))
                 ((= re 5) (process "VM"))
                 ((= re 6) (process "VD"))
(defun Write_Dcl_dq(/ Dcl_File file str)
         (setq Dcl_File (vl-filename-mktemp nil nil ".Dcl"))
         (setq file (open Dcl_File "w"))
         (foreach str '(
        "dq:dialog{"
        " label=\"实体对齐\";"
        " :row{"
        "  :button{label=\" 左对齐x轴 \";key=\"hl\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\"水平居中x轴\";key=\"hm\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 右对齐x轴 \";key=\"hr\";width=13;height=2.5;allow_accept=true;}"
        " :row{"
        "  :button{label=\" 上对齐y轴 \";key=\"vt\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\"垂直居中y轴\";key=\"vm\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 下对齐y轴 \";key=\"vd\";width=13;height=2.5;allow_accept=true;}"
        "  :button{label=\" 关闭 \";key=\"cancel\";width=13;height=2.2;is_cancel=true;fixed_width=true;alignment=centered;}"
        (write-line str file)
         (close file)
         Dcl_File
发表于 2020-10-18 15:37:18 | 显示全部楼层
TextALign   命令了解一下先。
 楼主| 发表于 2020-10-18 17:48:00 | 显示全部楼层
e2002 发表于 2020-10-18 15:37
TextALign   命令了解一下先。
好的,,
GMT+8, 2025-5-24 16:52 , Processed in 0.148115 second(s), 23 queries , Gzip On.
