查看: 3428|回复: 13
[JIG] DrawJig模仿Move时能否不显示原对象
发表于 2020-10-15 00:55:16 | 显示全部楼层 |阅读模式
用lisp可以轻松实现。
(defun C:TEST (/ DATA GRR GRRPT KEY LOOP OBJECTS PT SS)
  ;; by carrot1983 2020.09.29
  (setq SS (ssget))
  (setq PT (getpoint "\n指定点:"))
  (setq OBJECTS (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS)))))
  (setq LOOP t)
  (while LOOP
    (setq GRR (grread t 15 2))
    (setq KEY (car GRR))
    (setq DATA (cadr GRR))
    (cond ((= KEY 5)
           (setq GRRPT DATA)
           (foreach O OBJECTS
             (vla-move O (vlax-3d-point PT) (vlax-3d-point GRRPT))
          ) ;_移动
          ((or (= KEY 3) (= DATA 13))
           (setq LOOP NIL)
          ) ;_3左击 13回车 表示确认
          ((member KEY '(12 25))
           (redraw)
           (setq LOOP NIL)
          ) ;_右键退出
    (setq PT GRRPT) ;_新基点
  (redraw)
如果用drawjig 怎么修改以下代码。实现不显示原对象?
public class MoveJig : DrawJig
        protected Point3d basePt;
        protected Entity[] entities;
        public MoveJig(Entity[] entities, Point3d basePt)
            this.entities = entities;
            this.basePt = basePt;
        public Matrix3d Displacement { get; private set; }
        protected override SamplerStatus Sampler(JigPrompts prompts)
            var options = new JigPromptPointOptions("\nSecond point: ");
            options.UserInputControls = UserInputControls.Accept3dCoordinates;
            options.BasePoint = basePt;
            options.UseBasePoint = true;
            options.Cursor = CursorType.RubberBand;
            var result = prompts.AcquirePoint(options);
            if (basePt.DistanceTo(result.Value) < Tolerance.Global.EqualPoint)
                return SamplerStatus.NoChange;
            Displacement = Matrix3d.Displacement(result.Value - basePt);
            return SamplerStatus.OK;
        protected override bool WorldDraw(WorldDraw draw)
            var geo = draw.Geometry;
            if (geo != null)
                geo.PushModelTransform(Displacement);
                foreach (var ent in entities) geo.Draw(ent);
                geo.PopModelTransform();
            return true;
        [CommandMethod("TEST", CommandFlags.UsePickSet)]
        public void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var selection = ed.GetSelection();
            if (selection.Status != PromptStatus.OK) return;
            var ptResult = ed.GetPoint("\nBase point: ");
            if (ptResult.Status != PromptStatus.OK) return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                Entity[] entities = new Entity[selection.Value.Count];
                for (int i = 0; i < selection.Value.Count; i++)
                    entities[i] = (Entity)tr.GetObject(selection.Value[i].ObjectId, OpenMode.ForRead);
                var jig = new MoveJig(entities, ptResult.Value.TransformBy(ed.CurrentUserCoordinateSystem));
                var result = ed.Drag(jig);
                if (result.Status == PromptStatus.OK)
                        ent.UpgradeOpen();
                        ent.TransformBy(jig.Displacement);
                tr.Commit();
发表于 2020-10-17 13:27:22 来自手机 | 显示全部楼层
var geo = draw.Geometry;  if (geo != null)  {  //geo.PushModelTransform(Displacement);  foreach (var ent in entities)  ente. draw()  //geo.PopModelTransform();  }  return true;
发表于 2021-3-23 23:49:49 来自手机 | 显示全部楼层
carrot1983 发表于 2021-3-16 01:21
把原位置的先隐藏,这个我有思考过,但是,我看JIG的代码中没有这个东西。所以没头绪。
方法可行的 最近写了几段代码都是这样做的 如果要修改动态块参数 就要用deepclone  否则最终变换后夹点位置不对
发表于 2020-11-18 21:07:31 来自手机 | 显示全部楼层
找到办法了:
  • 假如 entityToBeJig 是要被jig的对象
  • 先克隆 entityToBeJig, 不要加入数据库
  • 设置entityToBeJig visible 属性为false
  • 然后用jig拖动新克隆的实体
  • 拖拽结束后,dispose新掉克隆的实体
  • 按实际效果变换entityToBeJig ,把可见性设为true
发表于 2020-10-15 16:51:55 | 显示全部楼层
个人见解:关键你这个是moveJig,不是CreatEntity,好像SamplerStatus过程在鼠标确定之前,你不能修改原始对象,
我觉得moveJig不显示原对象,有点难
楼下大神来解答
发表于 2020-10-15 19:35:31 来自手机 | 显示全部楼层
cad 自己的移动命令都显示 估计很难
 楼主| 发表于 2020-10-15 23:07:30 | 显示全部楼层
Lisp 轻松实现的功能,到.net的时候困难真不少。有没有高人出来指点一二。
发表于 2020-10-17 13:28:00 来自手机 | 显示全部楼层
这样行么 但是图元多的时候可能会慢
 楼主| 发表于 2020-10-26 23:04:53 | 显示全部楼层
brainstorm 发表于 2020-10-17 13:28
这样行么 但是图元多的时候可能会慢
一楼的代码就是这样子的。
发表于 2020-11-18 20:57:58 来自手机 | 显示全部楼层
找到办法了
发表于 2020-11-24 13:54:22 | 显示全部楼层
可以把原图像的透明度变成100%,这样就不显示了。:D
GMT+8, 2025-5-20 23:41 , Processed in 0.199818 second(s), 25 queries , Gzip On.
