查看: 3538|回复: 14
请大佬帮忙修改一下,造福各位设计,取之群,还之群。源码奉上
发表于 2020-10-10 10:49:31 | 显示全部楼层 |阅读模式
我这里有一份快速填充,也是在社区内一个大佬写的代码。用着十分不错,特别拿出来给大家,但有个问题,在2014版中 可以直接点击就能填充进方框内,但是到了2020版以后,直接点击以后, 还会出现两个选择,如何去掉后面这两个选择,跟2014版同样。这样效率就很高了。谢谢大佬修改一些
;;快捷填充
(defun c:se (/ amode)
  (initget 128 "q a w s e d r f z x c v qq aa")
  (setq amode (getkword
    "\n多层Q/木皮A/混凝W/实木S/理石E/玻璃D/布艺R/皮革F/海绵Z/藤编X/密度板C/金属V:")
  (if (not amode)
    (setq amode "q")
(setq amode(strcase amode T))
  (setq d "T")
  (cond ((= amode "q")
             (while (= d "T")
                (setq pt (getpoint "请选择填充点:\r"))
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "cork" 40 0 Pt "y" ""))
        ((= amode "a")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "Mupi" 350 0 Pt "y" ""))
        ((= amode "w")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "Hunlingtu" 10 0 Pt "y" ""))
        ((= amode "s")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "Shimu" 50 0 Pt "y" ""))
        ((= amode "e")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "Dalishi" 1 0 Pt "y" ""))
        ((= amode "d")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "ar-rroof" 50 45 Pt "y" ""))
        ((= amode "r")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "cross" 200 0 Pt "y" ""))
        ((= amode "f")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "hound" 300 0 Pt "y" ""))
        ((= amode "z")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn (vl-cmdf ".bhatch" "p" "honey" 40 0 Pt "y" ""))
        ((= amode "x")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                 (progn (vl-cmdf ".bhatch" "p" "earth" 200 0 Pt "y" ""))
         ((= amode "c")
             (while (= d "T")
                (if (= nil pt)
                 (progn (setq d "F"))
                  (progn(vl-cmdf ".bhatch" "p" "ar-sand" 5 0 Pt "y" ""))
         ((= amode "v")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn(vl-cmdf ".bhatch" "p" "ANSI36" 30 0 Pt "y" ""))
        ((= amode "qq")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn(vl-cmdf ".bhatch" "p" "cork" 40 90 Pt "y" ""))
        ((= amode "aa")
             (while (= d "T")
                (if (= nil pt)
                  (progn(setq d "F"))
                  (progn(vl-cmdf ".bhatch" "p" "Mupi" 350 90 Pt "y" ""))
 楼主| 发表于 2020-10-11 18:49:26 | 显示全部楼层
烟盒迷唇 发表于 2020-10-11 08:55
图片看不到,不知道有什么区别。
有区别,2014中直接填充,2020中填充后需要再点2次空格
 楼主| 发表于 2020-10-11 20:23:24 | 显示全部楼层
烟盒迷唇 发表于 2020-10-11 19:33
那就版本判断,高版本的添加2个空格进去啊。
就是不知道怎么添加,
 楼主| 发表于 2020-10-12 09:35:49 | 显示全部楼层
烟盒迷唇 发表于 2020-10-12 09:20
把每个里面的“Y”去掉就可以了。
解决了  3Q
 楼主| 发表于 2020-10-10 10:53:59 | 显示全部楼层
支持一个!!!!!顶上去
发表于 2020-10-11 08:55:14 | 显示全部楼层
图片看不到,不知道有什么区别。
发表于 2020-10-11 19:33:27 | 显示全部楼层
发表于 2020-10-12 09:20:51 | 显示全部楼层
yoyrtweq 发表于 2020-10-11 20:23
就是不知道怎么添加,
把每个里面的“Y”去掉就可以了。
发表于 2021-1-22 21:56:05 来自手机 | 显示全部楼层
实用的功能,谢谢分享
GMT+8, 2025-5-17 22:18 , Processed in 0.611933 second(s), 25 queries , Gzip On.
