楼主: kyky1002
[提问] 块属性导出导入excel
发表于 2020-10-1 21:28:17 | 显示全部楼层
感谢楼主分享
发表于 2021-12-13 16:15:21 | 显示全部楼层
gaics 发表于 2020-9-11 22:56
显示“参数类型错误: lselsetp nil”的原因是图纸范围内没有选择到text文本。
(setq ss (ssget "_X" (list ...
大师,能完善下像以前你帮我修改的目录生成器一样指定块,指定属性标记导出表格,导出顺序以图块的位置从左到右从上到下导出。导出的表格保存在CAD文件的位置,楼主的程序导出的表格是存在文档不是很方便查找。
导入也是指定块选择属性图块从左到右,从上到下导入。
以下是大师你以前帮我完善的目录生成器
图纸目录生成器
(defun c:ml (/              blkname  zxtag        nametag         numtag          shuxing
             ss              sslist   file        index0         index          tmp_pt
             XZ_sortlist       s1        s2         s3          s4
             lst0     lst      i        ii         tk          sslist_ptl
             path     drawingname
  (setvar "cmdecho" 0)
  (princ "\n第1步:请选择“子项”属性字...")
  (setq zxtag (multi_select))
  (princ "\n第2步:请选择“图名”属性字...")
  (setq nametag (multi_select))
  (princ "\n第3步:请选择“图号”属性字...")
  (if (setq numtag (choose_att2))
    (progn (setq blkname (cdr numtag))
           (setq numtag (car numtag))
  (princ "\n第4步:请选择需要生成目录的对象...")
  (setq ss (ssget (list '(0 . "insert") (cons 2 blkname))))
  ;;"blkname"from(multi_select)
  (setq        index0 0
        index  (sslength ss)
        sslist '()
  (repeat index
    (setq sslist (cons (ssname ss index0) sslist))
    (setq index0 (1+ index0))
  ;;开始构建图元点位表
  (setq        index0 0
        sslist_ptl
        tmp_pt '()
  (repeat index
    (setq tmp_pt
           (cons
             (nth index0 sslist)
             (cons (cdr (assoc 10 (entget (nth index0 sslist)))) tmp_pt)
    (setq sslist_ptl (cons tmp_pt sslist_ptl))
    (setq tmp_pt '())
  ;;开始排序
  ;;从左到右从上到下
  (setq        XZ_sortlist
         (vl-sort
           (vl-sort sslist_ptl
                    '(lambda (s1 s2) (> (cadadr s1) (cadadr s2)))
           '(lambda (s3 s4)
              (if (equal (cadadr s3) (cadadr s4) 300)
                (< (caadr s3) (caadr s4))
  (setq i 0)
  (setq lst '())
  (while (< i (length XZ_sortlist))
    (setq tk (car (nth i XZ_sortlist)))
    (setq shuxing (get_att tk))
    (setq lst0 '())
    (if        zxtag
      (setq lst0 (cons (str_value zxtag shuxing) lst0))
    (if        nametag
      (setq lst0 (cons (str_value nametag shuxing) lst0))
    (if        numtag
      (setq lst0 (cons (cdr (assoc numtag shuxing)) lst0))
    (setq lst (cons (reverse lst0) lst))
    (setq i (+ i 1))
  (setq lst (reverse lst))
  (setq path (getvar 'DWGPREFIX))
  (setq drawingname (vl-filename-base (getvar 'DWGNAME)))
  (setq file (open (strcat path drawingname "图纸目录.txt") "w"))
  (setq i 0)
  (while (< i (length lst))
    (write-line
      (vl-string-trim "()" (vl-princ-to-string (nth i lst)))
      file
    (setq i (+ i 1))
  (close file)
(defun get_att (tk)
  (setq obj (vlax-ename->vla-object tk))
  (mapcar '(lambda (att)
             (cons (vla-get-TagString att) (vla-get-TextString att))
          (vlax-invoke obj "GetAttributes")
(defun choose_att2 (/ a b)
  (if (setq a (entsel))
    (progn (setq b (car (nentselp (cadr a)))) ;图元名
           (if (/= (cdr (assoc 0 (entget b))) "ATTRIB") ;图元属性
             (progn (alert "******必须选择属性字!******")
                    (choose_att)
             (cons (cdr (assoc 2 (entget b)))
                   (cdr (assoc 2 (entget (car a))))
(defun multi_select (/ a b)
  (setq b '())
  (while (setq a (choose_att2))
    (setq blkname (cdr a))
    (if        b
      (setq b (cons (car a) b))
      (setq b (list (car a)))
    (princ "请继续选择,如已完成请按空格键或鼠标右键...")
  (reverse b)
(defun str_value (tag shuxing / ii value lst)
  (setq ii 0)
  (while (< ii (length tag))
    (setq value (cdr (assoc (nth ii tag) shuxing)))
    (setq lst (cons value lst))
    (setq value (apply 'strcat (reverse lst)))
    (setq ii (1+ ii))
  value
发表于 2022-5-23 14:25:46 | 显示全部楼层
看看我也来看看
发表于 2022-5-24 16:45:55 | 显示全部楼层
我也做了一个属性到EXCEL 程序,可以试试
;;; 《块属性输出到excel》
;;; 作者:langjs      命令:atoe
(defun c:atoe (/ active-sheet appxls ash cell col default elist ename ent i intcol j loop lst lst1 lst2 msxl-xl24hourclock n
                 na name name0 newbook newitem newsheet nu numrow obj out path relcol relrow rng row ss ss0 str tlb tlbfile
                 tlbver ty xlcontinuous xlscells xlsworkbooks
              )                               ;  加载excel类型库
  (defun dsx-typelib-excel (/ path tlb)
    (setq obj (vlax-create-object "Excel.Application"))
    (setq path (vlax-get-property obj 'path))
    (cond
      ((setq tlb (findfile (strcat path "\\Excel8.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel9.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel10.olb")))
        tlb
      ((setq tlb (findfile (strcat path "\\Excel.exe")))
        tlb
      (t
        (alert "本系统内未找到EXCEL97、2000、2002、2003、2010,初始化失败!")
  )                                       ; 定义类型库接口
  (defun dsx-load-typelib-excel (/ tlbfile tlbver out)
    (cond
      ((null msxl-xl24hourclock)
        (if (setq tlbfile (dsx-typelib-excel)) ; 加载excel类型库
            (setq tlbver (substr (vl-filename-base tlbfile) 1 6))
            (cond
              ((= tlbver "10")
                (princ "\n初始化 Microsoft Excel 2002...")
              ((= tlbver "9")
                (princ "\n初始化 Microsoft Excel 2000...")
              ((= tlbver "8")
                (princ "\n初始化 Microsoft Excel 97...")
              ((= (vl-filename-base tlbfile) "Excel")
                (princ "\n初始化 Microsoft Excel ...")
            (vlax-import-type-library :tlb-filename tlbfile :methods-prefix "msxl-" :properties-prefix "msxl-"
                                      :constants-prefix "msxl-"
            (if msxl-xl24hourclock
              (setq out t)
      (t
        (setq out t)
    out
  )                                       ; 为选中的范围的实行自动调整宽度
  (defun dsx-excel-rangeautofit (active-sheet)
    (vlax-invoke-method (vlax-get-property (vlax-get-property (vlax-get-property active-sheet 'usedrange) 'cells) 'columns)
                        'autofit
  )                                       ; 为选中的范围的实行网格线(自加)
  (defun dsx-excel-gridline (active-sheet)
                        'borderaround xlcontinuous default 1
  )                                       ; 为指定单元格填入颜色 (dsx-excel-put-cellcolor 1 1 14) 将颜色#14填入到单元格(1,a)
  (defun dsx-excel-put-cellcolor (row col intcol / rng)
    (setq rng (dsx-excel-get-cell ash row col))
    (msxl-put-colorindex (msxl-get-interior rng) intcol)
  )                                       ; 在活动的工作表中的单个单元格中获取数据; 获取行列范围内的单元格对象
  (defun dsx-excel-get-cell (rng relrow relcol)
    (vlax-variant-value (msxl-get-item (msxl-get-cells rng) (vlax-make-variant relrow) (vlax-make-variant relcol)))
  (defun data2cell (cell numrow col str) ; 写excel
    (vlax-put-property cell "item" numrow col (vl-princ-to-string str))
  (defun celltext (cell nu)               ; 把某一行或者列设置成文本各自nu"a:a"
    (vlax-put-property (msxl-get-range cell nu) "NumberFormat" (vlax-make-variant "@"))
  (defun initexcel ()
    (dsx-load-typelib-excel)
    (setq appxls (vlax-get-or-create-object "excel.application")
          xlsworkbooks (vlax-get-property appxls "workbooks")
          newbook (vlax-invoke-method xlsworkbooks "add")
          newsheet (vlax-get-property newbook "sheets")
          newitem (vlax-get-property newsheet "item" 1)
          xlscells (vlax-get-property newitem "cells")
          ash (msxl-get-activesheet appxls)
    (vla-put-visible appxls :vlax-true)
  (defun endexcel ()
    (vlax-release-object xlscells)
    (vlax-release-object newitem)
    (vlax-release-object newsheet)
    (vlax-release-object newbook)
    (vlax-release-object xlsworkbooks)
    (vlax-release-object appxls)
  (defun #err (s)
    (setvar "nomutt" 0)
    (if name0
      (redraw name0 4)
    (setq *error* $orr)
  (setq $orr *error*)
  (setq *error* #err)
  (vl-load-com)
  (setvar "cmdecho" 0)                       ; 关闭命令响应
  (setvar "nomutt" 1)
  (princ "\n 属性转EXCEL")
  (princ "\n选择属性块:")
  (while (not (and
                (setq ss0 (ssget ":E:S" (list '(0 . "insert") '(66 . 1))))
                (setq name0 (ssname ss0 0))
                (setq ent (entget name0))
                (setq na (assoc 2 ent))
    (if (= 52 (getvar "errno"))
      (vl-exit-with-error "")
  (if ss0
      (redraw name0 3)
      (princ "\n框选属性块:")
      (setq ss (ssget (list '(0 . "INSERT") na '(66 . 1))))
      (if (not ss)
        (setq ss ss0)
      (redraw name0 4)
      (setq ss (ssadd name0 ss))
      (setq lst '())
      (repeat (setq i (sslength ss))
        (setq name (ssname ss (setq i (1- i))))
        (setq ent (entget name))
        (setq ty (cdr (assoc 2 ent)))
        (setq ename (entnext name))
        (setq loop t)
        (setq lst1 '())
        (setq lst2 '())
        (while (and
                 ename
                 loop
          (setq elist (entget ename))
          (if (= (cdr (assoc 0 elist)) "ATTRIB")
              (setq lst1 (cons (cdr (assoc 1 elist)) lst1))
              (setq lst2 (cons (cdr (assoc 2 elist)) lst2))
            (setq loop nil)
          (setq ename (entnext ename))
        (setq lst (cons (reverse lst1) lst))
      (setq lst (cons (reverse lst2) lst))
      (initexcel)
      (celltext xlscells "B:B")
      (setq i 1)
      (foreach lst1 lst
        (setq j 1)
        (foreach n lst1
          (data2cell xlscells i j n)
          (setq j (1+ j))
        (setq i (1+ i))
      (dsx-excel-rangeautofit ash)
      (dsx-excel-gridline ash)
      (setq i 0)
      (repeat (length lst2)
        (dsx-excel-put-cellcolor 1 (setq i (1+ i))
                                 6
      (endexcel)
  (setvar "nomutt" 0)
发表于 2022-5-25 10:14:56 | 显示全部楼层
lang大师,有没有打算写excel导入到属性块的功能啊?
发表于 2022-5-25 16:39:22 | 显示全部楼层
这正是要找的,
能麻烦大师帮忙再加入属性图框内多行文本中内容的提取吗?如“材料:”“下料尺寸:”“表面处理:”“数量:”这四个后面对应的红色内容一起分别提取到EXCEL吗?
发表于 2023-5-28 17:24:55 | 显示全部楼层
高版本的Excel 怎么改
发表于 2024-5-5 02:47:34 | 显示全部楼层
wzg356 发表于 2020-9-12 10:18
函数:VxGetAtts
功能:获取块中所有属性
函数代码:
大佬,请问下,这个lsp的启动命令是什么呢,刚想测试下,看代码还是没看懂启动命令
GMT+8, 2025-7-7 14:36 , Processed in 0.191297 second(s), 18 queries , Gzip On.
