查看: 2914|回复: 14
时间插件
发表于 2020-7-13 12:07:29 | 显示全部楼层 |阅读模式
谁帮忙做一个时间插件
功能如下
1.输入命令插入当前时间,格式2020/7/13
2.当下次打开图纸修改后,输入另一个命令后更新日期.
发表于 2020-7-13 19:40:29 | 显示全部楼层
(defun c:NMM (/ p sn en p1 nam ty e1 e2 st p2 p3 p4 ss )
(command "undo" "g")
(setq os (getvar "osmode") blp (getvar "blipmode"))
(setvar "blipmode" 0)
(graphscr)
(if (null text0)(setq text0 ""))
(setq sn (menucmd "M=$(edtime,$(getvar,date),YYYY/M/DD )"))
(setq st (menucmd "M=$(edtime,$(getvar,date),YYYY/M/DD )"))
(while  (setq p (entsel "\n点取需要更新的日期:"))
   (setq sn  (car p)
   en  (entget sn)
   p1  (to 10)
   nam (to 2)
   ty  (to 0)
   (if (or (= "TEXT" ty) (= "INSERT" ty) (= "DIMENSION" ty))
     (if (or (= "TEXT" ty) (= "DIMENSION" ty))
        (setq e1 (subst (cons 1 st) (assoc 1 en) en))
        (entmod e1)
       ) ;progn
        (setq e1 (entget (entnext (cdr (car en)))))
        (setq e1 (subst (cons 1 st) (assoc 1 e1) e1))
        (entmod e1)
        (entmod en)
        (if (or (eq nam "PQ") (eq nam "PQ1"))
      (setq e2 (entget (entnext (cdr (car e1)))))
      (setq e2 (subst (cons 1 st) (assoc 1 e2) e2))
      (entmod e2)
      (entmod en)
       ) ;progn
       (princ "n所選物體是")
       (princ (cdr (assoc 0 en)))
       (princ ", 不是文字或圖塊,請重新選擇:n")
) ;while
(setvar "blipmode" blp)
(terpri)
(command "undo" "end")
(defun to (n)
  (cdr (assoc n (entget sn)))
发表于 2020-7-13 12:32:48 | 显示全部楼层
(DEFUN C:nm(/ OLDOS oldclay PT STA )
(setq oldclay (getvar "CLAYER"))
  (setq olderr *error*)
  (setq *error* myerr)
  (SETVAR "CMDECHO" 0)
  (SETQ OLDOS (GETVAR "OSMODE"))
(command "layer" "m" "00AC-nowtime" "c" 1 "00AC-nowtime" "L" "CONTINUOUS" "00AC-nowtime" "LW" "0.45" "00AC-nowtime" "")
(command ^c^c "layer" "p" "n" "00AC-nowtime"  "")
(command"style" "@@ZHJ-AC" "gbeitc.shx,hztxt.shx" "0" "0.8" "" "" "")
  (SETVAR "OSMODE" 0)
(while  (SETQ PT (GETPOINT"\n請指定插入點:"))
(SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),DDD\", \"D MON YYYY)"))
(SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),YYYY/M/DD )"))
;(SETQ znowtime (menucmd "M=$(edtime,$(getvar,date),YYYY\"年\"M\"月\"DD\"日\" hh\"?\"mm\"分\"ss\"秒\")"))
(command "text" "s"  "@@ZHJ-AC"  "j" "m" PT 300 0 znowtime)
  (SETVAR "OSMODE" OLDOS)
  (SETVAR "CMDECHO" 1)
  (setq *error* olderr)
(setvar "CLAYER" oldclay)
  (PRIN1)
 楼主| 发表于 2020-7-14 08:22:47 | 显示全部楼层
xj6019 发表于 2020-7-13 20:04
这是我这边的效果,建议忽略第一个插入吧,用你cad文件里面有的文字(单行文字),复制过去,用第二个代码刷 ...
非常感谢你的支持,我想要的效果是,当插入时间后,下次修改图纸了,希望能够一键更新所有的时间,如果一个一个时间选择有点慢,看看能不能再改改
 楼主| 发表于 2020-7-13 12:08:25 | 显示全部楼层
求帮忙做一个~~~~~~~~~~~~~~~拜托个位高手做一个
发表于 2020-7-13 12:34:13 | 显示全部楼层
发表于 2020-7-13 12:56:22 | 显示全部楼层
用字段就可以实现的
附件:
 楼主| 发表于 2020-7-13 15:28:18 | 显示全部楼层
好像不行,怎么回事??????
发表于 2020-7-13 19:41:04 | 显示全部楼层
上面是另外一个命令
GMT+8, 2025-5-1 15:35 , Processed in 0.194933 second(s), 31 queries , Gzip On.
