- 积分
- 6892
- 明经币
- 个
- 注册时间
- 2016-8-3
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
5明经币
;;;此行显示函数参数个数不正确,代码中已经注明,请问该怎么修改呀 - ;;http://bbs.mjtd.com/forum.php?mod=viewthread&tid=72665&extra=&highlight=%BD%C7&page=1
- (defun c:yad_fillet(/ yad-dxf yad-entsel yad-movetotop yad-interpt goto_fillet oldpedit oldos acaddoc mspace trm p1 p2 prom lprom r boxlen ss l_bak l_pt ent i)
- (defun yad-dxf(en val) (cdr (assoc val (entget en))))
- (defun yad-entsel(msg filter / ext ent pt s)
- (while (not ext)
- (setq ent (entsel msg))
- (cond
- ((= (getvar "errno") 52) (setq ext T) (setvar "errno" 0) nil)
- ((and ent (setq s (ssget "_c" (polar (setq pt (cadr ent)) (* pi 1.25) boxlen) (polar pt (/ pi 4) boxlen) filter)) (setq ext T)) (list (ssname s 0) pt))
- (T (prompt "\n圆角需要直线、圆弧、圆或多段线!"))
- (defun yad-movetotop(l_ent / extdic tbl)
- (setq l_ent (mapcar 'vlax-ename->vla-object l_ent))
- (setq extdic (vla-getextensiondictionary mspace))
- (if (vl-catch-all-error-p (setq tbl (vl-catch-all-apply 'vla-item (list extdic "acad_sortents"))))
- (setq tbl (vla-addobject extdic "acad_sortents" "acdbsortentstable"));;;此行显示函数参数个数不正确
- (vlax-invoke tbl "MoveToTop" l_ent)
- (defun yad-interpt(obj s / n ent ipt pt l_p)
- (setq obj (vlax-ename->vla-object obj) n -1)
- (repeat (sslength s)
- (setq ent (vlax-ename->vla-object (ssname s (setq n (1+ n)))) ipt (vlax-variant-value (vla-intersectwith obj ent 0)))
- (if (and (> (vlax-safearray-get-u-bound ipt 1) 0) (setq ipt (vlax-safearray->list ipt)))
- (while (> (length ipt) 0)
- (setq pt (list (car ipt) (cadr ipt) (caddr ipt)) ipt (cdddr ipt))
- (if (not (vl-member-if '(lambda(e) (equal e pt boxlen)) l_p)) (setq l_p (cons pt l_p)))
- (vla-delete obj)
- l_p
- (defun goto_fillet(p1 p2 / ent1 ent2 wid ent2ispl s oldent newent)
- (setq ent1 (car p1))
- (if (not p2) (redraw ent1 3))
- (if (or p2 (setq p2 (yad-entsel "\n选择第二个对象:" '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE")))))
- (if (and (setq ent2 (car p2)) (member "LWPOLYLINE" (mapcar '(lambda(e) (yad-dxf e 0)) (list ent1 ent2))))
- (progn
- (redraw ent1 4)
- (if (= (yad-dxf ent2 0) "LWPOLYLINE")
- (setq ent1 p2 p2 (cadr p1) ent2 (car p1) p1 (cadr ent1) ent1 (car ent1))
- (setq p1 (cadr p1) p2 (cadr p2))
- (setq wid (yad-dxf ent1 40) ent2ispl (= (yad-dxf ent2 0) "LWPOLYLINE"))
- (if (= trm 0)
- (progn
- (vla-copy (vlax-ename->vla-object ent1))
- (if (and ent2ispl (not (equal ent1 ent2))) (vla-copy (vlax-ename->vla-object ent2)))
- (yad-movetotop (if (equal ent1 ent2) (list ent1) (list ent1 ent2)))
- (vl-cmdf "_.undo" "_m")
- (setvar "qaflags" 1)
- (if ent2ispl (vl-cmdf "_.explode" ent1 ent2 "") (vl-cmdf "_.explode" ent1 ""))
- (setq s (ssget "_p") oldent (entlast))
- (setvar "qaflags" 0)
- (vl-catch-all-apply 'vl-cmdf (list "_.fillet" (setq ent1 (nentselp p1)) (setq ent2 (nentselp p2))))
- (cond
- ((= trm 0))
- ((and (equal (setq newent (entlast)) oldent) (/= (getvar "filletrad") 0)) (vl-cmdf "_.undo" "_b"))
- (T (vl-catch-all-apply 'vl-cmdf (append (list "_.pedit" (car ent1) "_j")
- (if (equal newent oldent) nil (list newent))
- (if (= (yad-dxf (setq ent2 (car ent2)) 0) "CIRCLE") nil (list ent2))
- (list s "" "_w" wid "")))
- (vl-cmdf "_.erase" s "")
- (vl-catch-all-apply 'vl-cmdf (list "_.fillet" p1 p2))
- (redraw ent1 4)
- (vl-load-com)
- (setq oldpedit (getvar "peditaccept") oldos (getvar "osmode")
- mspace (vla-get-modelspace (setq acaddoc (vla-get-activedocument (vlax-get-acad-object))))
- (setvar "peditaccept" 1)
- (setvar "osmode" 0)
- (setvar "cmdecho" 0)
- (setvar "errno" 0)
- (vl-cmdf "_.undo" "_c" "_n" "_.undo" "")
- (while (/= (getvar "errno") 52)
- (princ "\n当前设置:模式 = ")
- (princ (if (= (setq trm (getvar "trimmode")) 1) "修剪" "不修剪"))
- (princ ",半径 = ")
- (princ (getvar "filletrad"))
- (initget (if (= trm 1) "U N" "U T"))
- (setq p1 (entsel (strcat "\n" (setq prom (strcat "选择对象或指定圆角半径或[放弃(U)/" (if (= trm 1) "不修剪对象(N)" "修剪对象(T)")"]:")))))
- (princ "\n")
- (setq lprom (getvar "lastprompt") r (substr lprom (1+ (vl-string-mismatch prom lprom)))
- boxlen (abs (/ (* (/ (getvar "pickbox") (cadr (getvar "screensize"))) (getvar "viewsize")) (sin (/ pi 4))))
- (if (numberp (setq r (read r)))
- (setvar "filletrad" (abs r))
- (cond
- ((= p1 "U") (vl-cmdf "_.u"))
- ((= p1 "T") (setvar "trimmode" 1))
- ((= p1 "N") (setvar "trimmode" 0))
- ((and (not p1) (/= (getvar "errno") 52) (setq p2 (getcorner (setq p1 (cadr (grread T 6 2))) "\n指定对角点:")))
- (vla-startundomark acaddoc)
- (setq ss nil l_bak nil l_pt nil)
- (cond
- ((and (setq ss (ssget "_f" (list p1 p2) '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE"))))
- (vla-addline mspace (vlax-3d-point p1) (vlax-3d-point p2))
- (setq l_bak (list ss (setq l_pt (yad-interpt (entlast) ss))))
- (> (sslength ss) 1) (> (length l_pt) 1)
- ((and (setq ss (ssget "_f" (list p1 (list (car p1) (cadr p2)) p2 (list (car p2) (cadr p1)) p1) '((0 . "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE"))))
- (vl-cmdf "_.rectang" "_f" 0 p1 p2)
- (setq l_pt (yad-interpt (entlast) ss))
- (if (and l_bak (or (< (length l_pt) 2) (and (= (sslength ss) 1) (> (length (cadr l_bak)) 1)))) (setq ss (car l_bak) l_pt (cadr l_bak)))
- (cond
- ((not ss)
- (princ "\n没有交叉框选到直线、圆弧、圆、椭圆、多段线或样条曲线!")
- ((or (= (sslength ss) 1) (= (length l_pt) 1))
- (goto_fillet (list (setq ent (ssname ss 0)) (car l_pt)) (if (and (= (yad-dxf ent 0) "LWPOLYLINE") (> (length l_pt) 1)) (list ent (cadr l_pt)) nil))
- (T
- ;(setq p1 (nentselp (car l_pt)) l_pt (cdr l_pt) i -1)
- ;(while (and (setq p2 (nth (setq i (1+ i)) l_pt)) (setq p2 (nentselp p2)) (equal (car p2) (car p1))))
- ;(goto_fillet p1 p2)
- (command "fillet" (car l_pt) (cadr l_pt))
- (vla-endundomark acaddoc)
- ((and p1 (= (type (setq ent (car p1))) 'ename))
- (if (wcmatch (yad-dxf ent 0) "LINE,XLINE,RAY,LWPOLYLINE,SPLINE,ARC,CIRCLE,ELLIPSE")
- (goto_fillet p1 nil)
- (princ "\n圆角需要直线、圆弧、圆、椭圆、多段线或样条曲线!")
- (setvar "peditaccept" oldpedit)
- (setvar "osmode" oldos)
- (princ)
- (princ "\n框选圆角命令:yad_fillet")
- (princ)
