查看: 2081|回复: 0
[转帖]执行外部程序直到程序关闭
发表于 2004-3-19 22:21:00 | 显示全部楼层 |阅读模式
32-Bit App Can Determine When a Shelled Process Ends
Step-by-Step Example
  1. Start a new project in Visual Basic. Form1 is created by default.
  2. Add the following code to the general declarations section of Form1:
          Private Type STARTUPINFO
             cb As Long
             lpReserved As String
             lpDesktop As String
             lpTitle As String
             dwX As Long
             dwY As Long
             dwXSize As Long
             dwYSize As Long
             dwXCountChars As Long
             dwYCountChars As Long
             dwFillAttribute As Long
             dwFlags As Long
             wShowWindow As Integer
             cbReserved2 As Integer
             lpReserved2 As Long
             hStdInput As Long
             hStdOutput As Long
             hStdError As Long
          End Type
          Private Type PROCESS_INFORMATION
             hProcess As Long
             hThread As Long
             dwProcessID As Long
             dwThreadID As Long
          End Type
          Private Declare Function WaitForSingleObject Lib "kernel32" (ByVal _
             hHandle As Long, ByVal dwMilliseconds As Long) As Long
          Private Declare Function CreateProcessA Lib "kernel32" (ByVal _
             lpApplicationName As Long, ByVal lpCommandLine As String, ByVal _
             lpProcessAttributes As Long, ByVal lpThreadAttributes As Long, _
             ByVal bInheritHandles As Long, ByVal dwCreationFlags As Long, _
             ByVal lpEnvironment As Long, ByVal lpCurrentDirectory As Long, _
             lpStartupInfo As STARTUPINFO, lpProcessInformation As _
             PROCESS_INFORMATION) As Long
          Private Declare Function CloseHandle Lib "kernel32" (ByVal _
             hObject As Long) As Long
          Private Const NORMAL_PRIORITY_CLASS = &H20&
          Private Const INFINITE = -1&
          Public Sub ExecCmd(cmdline$)
             Dim proc As PROCESS_INFORMATION
             Dim start As STARTUPINFO
             ' Initialize the STARTUPINFO structure:
             start.cb = Len(start)
             ' Start the shelled application:
             ret& = CreateProcessA(0&, cmdline$, 0&, 0&, 1&, _
                NORMAL_PRIORITY_CLASS, 0&, 0&, start, proc)
             ' Wait for the shelled application to finish:
             ret& = WaitForSingleObject(proc.hProcess, INFINITE)
             ret& = CloseHandle(proc.hProcess)
          End Sub
  3. Add the following code the Form_Click() event procedure of Form1:
          Sub Form_Click ()
             ExecCmd "notepad.exe"
             MsgBox "Process Finished"
          End Sub
  4. Press the F5 key to run the application.
  5. Using the mouse, click the Form1 window. At this point the Notepad application is shelled.
GMT+8, 2025-5-25 07:59 , Processed in 0.172458 second(s), 23 queries , Gzip On.
