查看: 2431|回复: 0
[转帖]修改MsgBox的位置
发表于 2004-3-19 22:12:00 | 显示全部楼层 |阅读模式
Position a MsgBox Using a Windows Hook Procedure
Step-by-Step Example
  1. Start a new Standard EXE project. Form1 is created by default.
  2. Add a module to the project and add the following code to the new module:
          Type RECT
             Left As Long
             Top As Long
             Right As Long
             Bottom As Long
          End Type
          Public Declare Function UnhookWindowsHookEx Lib "user32" ( _
             ByVal hHook As Long) As Long
          Public Declare Function GetWindowLong Lib "user32" Alias _
             "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) _
             As Long
          Public Declare Function GetCurrentThreadId Lib "kernel32" () As Long
          Public Declare Function SetWindowsHookEx Lib "user32" Alias _
             "SetWindowsHookExA" (ByVal idHook As Long, ByVal lpfn As Long, _
             ByVal hmod As Long, ByVal dwThreadId As Long) As Long
          Public Declare Function SetWindowPos Lib "user32" ( _
             ByVal hwnd As Long, ByVal hWndInsertAfter As Long, _
             ByVal x As Long, ByVal y As Long, ByVal cx As Long, _
             ByVal cy As Long, ByVal wFlags As Long) As Long
          Public Declare Function GetWindowRect Lib "user32" (ByVal hwnd _
             As Long, lpRect As RECT) As Long
          Public Const GWL_HINSTANCE = (-6)
          Public Const SWP_NOSIZE = &H1
          Public Const SWP_NOZORDER = &H4
          Public Const SWP_NOACTIVATE = &H10
          Public Const HCBT_ACTIVATE = 5
          Public Const WH_CBT = 5
          Public hHook As Long
          Function WinProc1(ByVal lMsg As Long, ByVal wParam As Long, _
             ByVal lParam As Long) As Long
             If lMsg = HCBT_ACTIVATE Then
                'Show the MsgBox at a fixed location (0,0)
                SetWindowPos wParam, 0, 0, 0, 0, 0, _
                             SWP_NOSIZE Or SWP_NOZORDER Or SWP_NOACTIVATE
                'Release the CBT hook
                UnhookWindowsHookEx hHook
             End If
             WinProc = False
          End Function
          Function WinProc2(ByVal lMsg As Long, ByVal wParam As Long, _
          Dim rectForm As RECT, rectMsg As RECT
          Dim x As Long, y As Long
             'On HCBT_ACTIVATE, show the MsgBox centered over Form1
                'Get the coordinates of the form and the message box so that
                'you can determine where the center of the form is located
                GetWindowRect Form1.hwnd, rectForm
                GetWindowRect wParam, rectMsg
                x = (rectForm.Left + (rectForm.Right - rectForm.Left) / 2) - _
                    ((rectMsg.Right - rectMsg.Left) / 2)
                y = (rectForm.Top + (rectForm.Bottom - rectForm.Top) / 2) - _
                    ((rectMsg.Bottom - rectMsg.Top) / 2)
                'Position the msgbox
                SetWindowPos wParam, 0, x, y, 0, 0, _
             End If
             WinProc = False
          End Function
  3. Add two CommandButtons to Form1.
  4. Add the following code to Form1:
          Private Sub Command1_Click()
          Dim hInst As Long
          Dim Thread As Long
             'Set up the CBT hook
             hInst = GetWindowLong(Me.hwnd, GWL_HINSTANCE)
             Thread = GetCurrentThreadId()
             hHook = SetWindowsHookEx(WH_CBT, AddressOf WinProc1, hInst, _
                                      Thread)
             'Display the message box
             MsgBox "This message box has been positioned at (0,0)."
          End Sub
          Private Sub Command2_Click()
          Dim hInst As Long
          Dim Thread As Long
             hHook = SetWindowsHookEx(WH_CBT, AddressOf WinProc2, hInst, _
                                      Thread)
             MsgBox "This message box is centered over Form1."
          End Sub
  5. Press the F5 key to run the program. Click Command1 and the message box appears at the upper-left corner of the screen (0,0). Click OK to dismiss the message box. Click Command2 and the message box appears at the center of Form1. Click OK to dismiss the message box.
GMT+8, 2025-5-25 10:44 , Processed in 0.162477 second(s), 23 queries , Gzip On.
